5100s with shims?
Discussion in 'Suspension' started by Jeffro22, Dec 1, 2019.
  1. Dec 1, 2019 at 7:08 AM
    Jeffro22
    Jeffro22 [OP] New Member
    2013 platinum crewmax 4x4
    Have 5100’s installed on front - highest setting
    just getting ready to install 1.5” shackles on rear. I am thinking this might make the rear a little too tall
    it looks like I can add 1/4” - 1/2” shim to the front if I need to raise up to make closer to level. Any problem doing this? I know it will need to be realigned
    Anyone running similar set up with 1.5 “ shackles? Wondering how it looks?
  2. Dec 1, 2019 at 7:23 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Itll look like any 3/1.5 lift kit out there.
    Coachbuilders got the shims your looking for.
  3. Dec 1, 2019 at 7:24 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Here is @MAGDADDY running shim on his 6112
    MAGDADDY likes this.
  4. Dec 1, 2019 at 7:29 AM
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    You might need new UCA to get it aligned with shims on top of the highest setting. (As shown in the pic above)
    MAGDADDY and 14burrito like this.
  5. Dec 1, 2019 at 7:31 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Yea the shims will help if you need a little adjustment I’ve got 2 on drivers side 1 on pass, sit a touch nose high but it’s really close.
    Omohundro likes this.
  6. Dec 1, 2019 at 7:33 AM
    rznhales
    rznhales New Member
    Randy
    Southern Utah
    2014 Tundra Crewmax Limited TRD
    Bilstein 5100's
    Yep, 5100's on top setting and one Coachbuilder shim on each side
  7. Dec 1, 2019 at 7:36 AM
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
    FBG 5100 adjustable coilovers set at 2.5" front, 1.5" shackles rear. I stayed at 2.5 to avoid possible UCA's and more CV ange. Still some rake but not to bad.
    MAGDADDY, AZBoatHauler and 14burrito like this.
  8. Dec 1, 2019 at 7:50 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Buddy just installed 6112 top setting with 1.5 shackle out back, 285/75/18. @cmack
    Looks great that way IMO!
    MacCTD, Jeffro22[OP], cmack and 2 others like this.
  9. Dec 1, 2019 at 12:12 PM
    Jeffro22
    Thanks. Guess I’ll install shackles and then decide if I need anything else in front.
    I already have aftermarket UCa’s that I installed with 5100’s so should be good with alignment
    thanks for the pics. I like the look. Looks like I might be ok without shims
    619Tundra likes this.
  10. Dec 1, 2019 at 8:27 PM
    cmack
    cmack New Member
    AZ
    2018 Burrito
    I ran without shims first just to see, but I also didn’t have much of a lean prior to installing the 6112’s. I also wanted a rake to keep TSS and PCS happy on mine... the pics in @14burrito ’s post are of my truck so if you want any additional pics just let me know
    14burrito likes this.
  11. Dec 1, 2019 at 9:55 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Check my sig and build page.
    JameSR5 likes this.
