5.29 Nitro Gears
Discussion in 'Performance and Tuning' started by HaydenF, Nov 5, 2018.
  1. Nov 5, 2018 at 4:50 PM
    HaydenF
    HaydenF [OP] New Member
    Hayden
    2016 Limited Tundra Crewmax
    3.5 Zone Lift, 35x12.5x18 Nitto Ridge Grapplers, 18x9 Fuel hostage 3 Grey
    I was about to pull the trigger on the 4.88’s and noticed nitro plans to release the 5.29 gears around April. Currently on a 3.5” lift running 35’s. I’m having constant gear hunting when below 40mph. I’m in the process of building an overland rig and plan to tow a Jeep JK to jamboree’s across the US. I think it would be worth while to hold off and wait for the 5.29’s it would bring the truck back to 100% stock Peformance from the charts I have found online. Thoughts? Concerns? Looking for input.
  2. Nov 5, 2018 at 5:28 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    GREAT CHOICE. I NEED TO DO THE SAME WITH MY 2002 TOYOTA TUNDRA
  3. Nov 5, 2018 at 5:50 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    I'd wait until April for the 5.29's.....................:popcorn:
  4. Nov 5, 2018 at 6:29 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I kinda thought 4:88 was for 35s and 5:29 for 37s?
    Vizsla likes this.
  5. Nov 5, 2018 at 7:01 PM
    HaydenF
    Hayden
    I assumed the same until I saw this chart.
    831Tun likes this.
  6. Nov 5, 2018 at 7:03 PM
    Vizsla
    Vizsla ☠️☠️☠️
    I would wait and see how the 5:29 gears work out. They get weaker as the numeric ratio increases, and there is potential for some noise as well.
    831Tun likes this.
  7. Nov 5, 2018 at 7:14 PM
    n2deep
    n2deep Pavement Princess
    Not sure how to read the chart cause 32in and 4.30 is stock but it shows -8%
    35 with 4.88 is -5%
    TRD15559 and 831Tun like this.
  8. Nov 5, 2018 at 7:38 PM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    My rule of thumb for the past 20 years: choose the ratio that brings it back to stock, then go the next more aggressive to make up for the extra weight of the bigger tires.
    Generally, 4.88 brings 35’s back ronstock. So 5.29 is the natural choice.
  9. Nov 5, 2018 at 8:23 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
    32/4.30 = X/4.88. X is the equal ratio new tire size for new gears. Here X = 36.3”. So you’ve more than made up for moving to 35’s. 5.29 gears = 39.4” tire. I agree with Keith, you still have to make up for the larger, heavier tire so it’s not really a 1:1 ratio except RPM. If you never plan to go bigger than 35’s then 4.88 should be enough. The 5.29 of course gives you room to grow.
    Darkness and 831Tun like this.
  10. Nov 5, 2018 at 9:18 PM
    dirtydeeds
    Keith
    USA
    What most people don’t realize. Mpg is more affected by load than rpm.
    The shorter gears reduces load.
    Less load means more ignition timing more of the time. And it means less fuel more of the time. It keeps you in closed loop more of the time. And it keeps the torque converter locked up more of the time.
    Plus, the truck is just way more fun overall;)
  11. Nov 6, 2018 at 4:03 AM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    When are the 5.29's due to be out? I thought i heard 2019 sometime?
  12. Nov 6, 2018 at 5:08 AM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    April
    deedubb[QUOTED] likes this.
  13. Nov 6, 2018 at 5:45 AM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    I'm going to have to wait and go 5.29's then. I've got 8" lift on 37's and I tow a camper during the summer and already struggle to tow it before the lift and tires/wheels. Sounds like 5.29's should correct the tire/wheel/lift work then.
    AKJ78 and Troynjade like this.
  14. Nov 6, 2018 at 10:33 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Keith is correct on MPG, RPM is not all.
    I hesitated to change to lower gears on my truck because the motor would run a few hundred RPM higher than stock at freeway speeds. I went for it anyway and was surprised to find better MPG on the same old work commute. Plus a quicker truck.
    That doesn't mean get 5.29 and stock tires and expect a miracle, but the optimal arrangement is slightly lower gears than the OEM equivalent.
    Lindenwood, 831Tun and AKJ78 like this.
  15. Nov 23, 2018 at 12:53 PM
    Lindenwood
    Lindenwood New Member
    2002 and 2016 4Runners, Selling 2002 for a Tundra
    2002 4Runner: Custom full rmor, 33 MTs, Fridge, drawers, OBA, flat paint (for easy touch-ups). 2016 4Runner TRDP: Wheels, 32 ATs, 2" Lift F/R
    On my 4Runner, I once did a 200 mile highway trip in OD, then the same 200 miles trip with OD off, turning about 3100 rpm at 75mph! Got the same mileage either way, except the transmission wasnt unlocking the converter every minute (literally), or downshifting on every small hill with it in OD.
    I am seriously considering 37s on a Tundra, and 5.29s would be awesome for all the reasons posted above.
  16. Nov 23, 2018 at 6:08 PM
    Troynjade
    Troynjade Beast mode 5.7
    Troy
    Wa
    2008 Toyota Tundra
    7" procomp lift, 3" body lift. Amp research powerstep, 22" fuel rims, 38" nitto tires, Custom leather seat covers black with red stiching, alpine inz928 deck, 2x10" subs, 1500 watt alpine amp, 400watt amp for door speakers. Procomp Traction bars, fuel grille, Black headlight housing with 6000k hid, rear airbags, rear and front camera, k&n air intake, 40" light bar. Rear under bumper led light bar. Prodigy trailer brakes. 5.29 Nitro Gears. Auburn Posi Rear End. Dirty Deeds Budget Dump.
    I have 4.88's. Now im gonna have to buy the 5.29's. I have 38" tires and I think it will help that much more. I would have waited but, I blew my rear end out about 6 months ago.
  17. Nov 23, 2018 at 6:36 PM
    Rica25
    Ricardo
    Tulare
    Do you install the gears or just sale them?
  18. Sep 11, 2019 at 1:53 PM
    Urbandalefirefighter
    Urbandalefirefighter New Member
    Jackson Salter
    2011 Tundra Crewmax 4.6L 4x4
    Has anyone out 5.29 gears in their 4.7 liter 2nd gen? I called nitro and they said 4.88s are the way to go on the 4.7. But why not the 5.29?
  19. Sep 11, 2019 at 2:44 PM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Bam 8 exhaust 285/70 18 ridges 4:88 gears, auburn lsd 6112s SPC UCA
    What size tires are you running
  20. Sep 11, 2019 at 3:06 PM
    Jackson Salter
    285/55/20 but plan to go to a 35
  21. Sep 11, 2019 at 3:43 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    I own the Nitro Gear SEMA truck with 4.88 and 37" Nittos. Granted, I also have a SC, but the gearing feels spot on to me.
  22. Sep 11, 2019 at 4:13 PM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    I would go 5:29. I have 34s on a 18 inch wheel and have the 5.7. I am running 4:88s and it feels perfect.
  23. Sep 11, 2019 at 4:38 PM
    Jackson Salter
    I was just curious if this is possible because on their website they specifically sell the 4.88 for the smaller engine and then on the 5.7 you have the option of either 4.88 or 5.29
  24. Sep 11, 2019 at 5:11 PM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Not sure why
  25. Sep 11, 2019 at 5:49 PM
    buckrub71
    buckrub71 Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
  26. Jan 22, 2021 at 9:48 PM
    KingKong
    KingKong New Member
    Asher
    2008 Super White Double Cab Long Bed 4x4
    Just to answer this question in case anyone was still wondering, the reason they don't sell 5.29s for the 4.7 and 4.6 is because those trucks have the 9.5" diff in the rear vs the 10.5" on the 5.7
    Rica25 likes this.
  27. Jan 28, 2021 at 4:08 PM
    dirtydeeds
    Keith
    USA
    Anyone considering gears, call Keith Carty at Dirty Deeds Industries. His pricing on Nitro Gears is amazing!!! LSD Auburns and Powertrax as well, all great pricing!!!
    Rica25 likes this.
  28. Jan 28, 2021 at 5:02 PM
    At what tire size do you want to start thinking of rehearing? A true 35 inch and up?
  29. Feb 2, 2021 at 9:43 AM
    dirtydeeds
    Keith
    USA
    Give Keith Carty from Dirty Deeds Industries a call on gears. His pricing is beyond amazing, and he will get you set up with what your truck needs.
    760-877-4234
