4x4 doesn't disengage
Discussion in '2.5 Gen Tundras (2014-2021)' started by chicano1313, Jan 15, 2020.
  1. Jan 15, 2020 at 11:17 PM
    chicano1313
    chicano1313 [OP] New Member
    Jesse
    2016 CM
    6" Lift
    I have a 2016 CM the traction control light does not turn off and my 4x4 doesn't disengage. Any one have this problem before. I have a 6" lift with 37s. My son took it to the dealership today. They said it could be because of the lift. I doubt it. It was professionally done. I had the lift installed 2 months after I bought the truck in 2016 1st owner. Suggestions?
    Didn't do any crazy off-roading. I was up in the snow. On pavement, was doing a side job.
  2. Jan 16, 2020 at 2:43 AM
    Rockanock
    Rockanock 21 Chevy 2500
    Don’t think it’s anyway the lift. If that’s the case why would so many lift for “off road” travel. This would be believable issues if every lifted truck had that problem. I think it is probably something to either do with the switch or the transfer case itself. Have you tried shifting while in neutral?
    chicano1313[OP] likes this.
  3. Jan 16, 2020 at 3:42 AM
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    When was the last time you used 4WD?
    Tundyfundy likes this.
  4. Jan 16, 2020 at 3:57 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    To be properly maintained I think Toyota says to drive with the 4 wheel drive engaged for at least 8 miles a month. I don’t know about 8 miles but I engage it for a few miles a month.
    The actuator can become siezed without occasional use and you end up in your situation. Could also be something else. Good luck!
  5. Jan 16, 2020 at 6:01 AM
    chicano1313
    Jesse
    2016 CM
    6" Lift
  6. Jan 16, 2020 at 6:02 AM
    chicano1313
    Jesse
    2016 CM
    6" Lift
    Haven't tried in neutral. But I will today.
  7. Jan 16, 2020 at 6:04 AM
    chicano1313
    Jesse
    2016 CM
    6" Lift
    Last time was in December and on the 1st of January.
  8. Jan 16, 2020 at 6:15 AM
    15whtrd
    15whtrd Mr. Blonde
    Possible ABS sensor issue. Make sure all the wires are hooked up to the sensors at each wheel.
  9. Jan 16, 2020 at 6:18 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    It's 10 for my 2017.
    I think you have to be under a certain speed too for it it engage/disengage?
  10. Jan 16, 2020 at 6:20 AM
    Tundyfundy
    Bay Area, CA
    Card says do it under 60 for 4hi
    And stopped in 4lo
    P-Factor and sdde4n like this.
  11. Jan 16, 2020 at 6:29 AM
    Sas
    OKC, OK
    Yep, 62 for the 2017 (effectively under 60). https://www.toyota.com/t3Portal/document/om-s/OM11QRG/pdf/17Tundra_OM11QRG.pdf (p22)
    OP, also keep in mind any speedo difference if it wasn't corrected when running a different overall tire circumference other than stock. There are a number of threads about troubleshooting it here on the forums. Just have to search!
    Tundyfundy[QUOTED] likes this.
  12. Jan 16, 2020 at 6:39 AM
    15whtrd
    15whtrd Mr. Blonde
    Sometimes it takes a slight turn or on off the throttle to get it to disengage. Also I had this issue when I installed the same oil as the diff fluid. The new transfer cases need a specific 75w oil. I switched the oil out, and now it functions properly.
    Slayer, Tundyfundy and HulkSmurf14 like this.
  13. Jan 16, 2020 at 5:48 PM
    Slayer
    Slayer Member
    Slayer
    this.. also a manual downshift can kick it... easily.
    ..Slayer
    15whtrd[QUOTED] likes this.
  14. Jan 16, 2020 at 5:56 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Backing up can work too
