4hi Light blinking, won't "disengage" 4hi and 4low work fine
Discussion in '1st Gen Tundras (2000-2006)' started by lsaami, Oct 3, 2018.
  1. Oct 3, 2018 at 12:19 PM
    lsaami
    lsaami [OP] New Member
    2000 Tundra Limited 4x4
    2" lift Grille Guard, Cab Visor
    Well, I've searched and searched, and can't seem to find anyone who's had my exact issue.
    I just bought a 2000 Tundra Limited 4x4 with the 4.7L WITH ABS, and it's having 4WD issues. Like the title says, my 4hi light is blinking constantly even though I feel a small clunk when it disengages, and can feel that the front wheels aren't being powered, but the light blinks anyway. I can get into 4hi and 4low just fine, the light just won't quit flashing when I try to go into 2wd mode. It is an ABS truck, but that light is NOT on, so to my knowledge that system is working correctly.
    Any leads? I'm going to try unplugging the battery for a while just to see what that does. I'm not super familiar with how these systems work.
    Clarification: I have tried going into neutral while driving, engaged/disengaging while moving, while moving in reverse, stopped and in park, stopped and in neutral, stopped and in drive, stopped and in reverse, and nothing has worked.
  2. Oct 3, 2018 at 12:55 PM
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    Welcome, throw up some pics?
    If never heard of that problem though
    lsaami [OP] likes this.
  3. Oct 3, 2018 at 12:56 PM
    lsaami
    Thanks! I bought it last night and don't have any decent pictures in the day time. I'll do that soon!
  4. Oct 3, 2018 at 12:56 PM
    2015Crewmax
    2015Crewmax New Member
    Cory
    VERMONT
    15 Crewmax
    Rough Country 3" Leveling kit, TRD Swaybars, TRD dual exhaust,
    I have had that happen. Stop, put truck in neutral, and wait a minute. that should fix it. i have also had to put my truck in reverse too.
  5. Oct 3, 2018 at 12:59 PM
    lsaami
    I should've clarified. I have tried going into neutral while driving, engaged/disengaging while moving, while moving in reverse, stopped and in park, stopped and in neutral, stopped and in drive, stopped and in reverse, and nothing has worked.
    15whtrd likes this.
  6. Oct 3, 2018 at 12:59 PM
    Need to know stuff
    It may be a bad position switch on the transfer case
  7. Oct 3, 2018 at 1:00 PM
    lsaami
    how would I go about testing that?
  8. Oct 3, 2018 at 1:00 PM
    15whtrd
    15whtrd I tried being reasonable, but I didn't like it.
    White 2015 Tundra DC SR5 TRD 4x4 5.7L
    TRD Pro suspension, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, Real truck tailgate seal, Pop-n-lock tailgate actuator, rear diff breather relocate.
    I’ve had mine do it as well. The way I get it to stop flashing is by making a turn. It’s like it didn’t fully disengage until I made a somewhat sharp turn.
  9. Oct 3, 2018 at 1:02 PM
    Need to know stuff
    I don't really know, you may want to watch YouTube on it, I think it's a somewhat common problem so someone has had to make a vid on it sometime
  10. Oct 4, 2018 at 8:05 AM
    Professional Hand Model
    Professional Hand Model Fred Brookes
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Bad switch/actuator? Let us know if the battery reset trick works.
  11. Oct 4, 2018 at 8:13 AM
    831Tun
    831Tun IMA BasTRD
    Warren
    Santa Cruz
    '16 CM limited
    ADS C/O w/clickers, ADS bypass rear, Icon UCAs, Toytech shackles, chrome delete, Pro grille, TRD dual exhaust dumped, de-badged, black LED tail lights. BHLM w/projectors, 295 70 18 Cooper STT pro on stock rims w/1.25" Spider Tracks. N_Fab bumper w/Baja Design fogs and ditch lights, 13" antenna x, RCI skid, All Pro sliders, ARB compressor
    Sounds like you tried everything but if you stop, put it in neutral, then switch to 4 low, wait 'til flashing stops, switch back to 4 high, start driving in a straight line and switch to 2wd.
    joonbug and lsaami [OP] like this.
  12. Oct 4, 2018 at 8:17 AM
    lsaami
    Will do, thanks.
    I’ll give that a go. Thanks!
    831Tun likes this.
  13. Oct 4, 2018 at 10:38 AM
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    May auto locking hubs are not disengaging, but power is? Just thinking out of the box
  14. Oct 4, 2018 at 10:45 AM
    bmf4069
    bmf4069 New Member
    TX
    02 AC sr5 4wd v8
    Or the opposite? :notsure:
    Duneflyer likes this.
  15. Oct 4, 2018 at 10:51 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Sounds like you've covered most of it and did all the normal tips and tricks. However, since it's an 18 year old truck, I guarantee the 4wd actuator on the xfer case is full of dirt and mud and shit. On the back side of the xfer case is the 4wd actuator. It's a black plastic looking thing. Open it up, clean the hell out of it, dialectic grease anything electrical and that normally fixes it. It's easier to pull the whole actuator from the xfer case and clean it on a bench.
    Check this article for a deeper read on it: http://www.toyota-4runner.org/4th-gen-t4rs/227275-diy-transfer-case-actuator-repair.html
  16. Oct 4, 2018 at 10:56 AM
    jberry813
    Lake Tahoe
    Also give the actuator a whack with a rubber mallet a few times. Normally that's enough to clear what is keeping the gears from spinning by the motor. If that works and gets you into 2wd, means it needs to be cleaned or replaced. It's a few hundred bucks for a new one, so depends on what your time is worth.
  17. Oct 4, 2018 at 10:57 AM
    bmf4069
    bmf4069 New Member
    TX
    02 AC sr5 4wd v8
    "I then poured the rusty,dirty, water like substance in the actuator onto myself as I opened the case."
    :rofl:sound like me but with gas when I did my fuel filter!
  18. Oct 4, 2018 at 3:13 PM
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    This actuator repair thing (per the above link) sounds like it goes easy or is very complicated and is not to be attemped unless you have the time to go the entire distance.
    Takeaway from the stories of all the commentors is to make sure your breather lines are connected to prevent the problem!
  19. Oct 4, 2018 at 4:28 PM
    lsaami
    Thanks! that helps a lot. The truck is currently at my parents house (dad's got the tools) and it'll be a few days before I get time to head over there. I'll keep everyone updated.
  20. Oct 7, 2018 at 7:18 PM
    ethan1911
    ethan1911 New Member
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    Can’t say for sure but I bet it’s dirt in the actuator. I’m 99% sure it’s not in the abs because I’ve removed all of that stuff on mine and the transfer case shifts just fine.
  21. Oct 7, 2018 at 7:49 PM
    lsaami
    So I was messing around with it tonight, and it engages and disengages 4x4. you can hear the motor turn and the clunk of the actuator as it shifts from 4x4 to 2x4. I'm going to be it's the actuator sensor thingy. I pulled the plastic cover revealing a spiral gear and a big plastic gear, and it was perfectly clean inside. forgot to take a picture though.
  22. Oct 7, 2018 at 9:22 PM
    thezoltar
    thezoltar New Member
    I haven't researched your particular setup but my 2001 4runner had the same issue a few years back. There were two switches on the transfer case, one to tell it when it was in 2wd and one to tell it when it was in 4wd. If one switch sticks the warning light will flash because it doesn't know if it is in 2 or 4 or both at the same time. In my case it was the forward switch sticking causing the truck to still think it was in 4wd. Thus the confused flashing light. The part was about $90 at Toyota. It looks to be a $30 switch to me.
    If you pull the wire off the front switch I bet the light will go out when you are in 2wd. Of course the trucks are different so the switches could be reversed. Easy enough to try especially if you have enough ground clearance to get under easily.
  23. Oct 7, 2018 at 9:34 PM
    lsaami
    Thank you! That’s a huge help!
  24. Oct 9, 2018 at 11:20 AM
    Need to know stuff
    Throw up some pics of your truck?
  25. Oct 9, 2018 at 11:25 AM
    lsaami
  26. Oct 9, 2018 at 3:39 PM
    lsaami
    Well, I made a boo boo. I unplugged the 4lo sensor instead of the 4hi sensor, and now it’s stuck in 4lo with the 4hi and 4lo lights flashing. What now? The sensor is plugged back in, but it won’t do anything.
  27. Oct 9, 2018 at 3:49 PM
    Casper421
    Casper421 Adventure in a 1st gen
    N. Cal
    06 DC
    I know it’s simple but did you try disconnecting the battery for a few minutes?
  28. Oct 9, 2018 at 3:53 PM
    lsaami
    That’s what I’m about to try. I can’t think of anything else.
  29. Oct 9, 2018 at 4:16 PM
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Maybe unplug the 4hi sensor too? Can’t mess it up anymore now.
  30. Oct 9, 2018 at 4:19 PM
    lsaami
    I unplugged the battery for 15 minutes, and it changed nothing. drove it up nd dow the driveway, still nothing. unplugged the sensor again, nothing.
    It's completely stuck in 4low, and it won't do anything. is there a way to reset the 4x4 controller or something.
