400 miles in on Nitro 5.29s
Discussion in 'Performance and Tuning' started by Wildtrout, Dec 22, 2019.
  1. Dec 22, 2019 at 8:08 PM
    Wildtrout
    Wildtrout [OP] New Member
    Seattle
    2018 Tundra Crew Max
    OME BP51 Front and Rear, Complete de badge, ARE Z Series camper shell, Decked system, TRD CAI, painted hood bulge and grill surround, WeatherTech mats
    I’m now 400 miles in on my 500 mile break in period for the Nitro 5.29s recently installed on my CM. I’m running Nitto 37s with heavy front and rear Exp1 bumpers and a 160lb iKamper RTT. It’s a heavy truck even with some gear removed for the winter, but the new gearing provides better power and smoother transmission changes. The “no more hunting” claim is definitely true. I will say that the new gearing hasn’t created a night and day experience, probably bcs of weight and tire size. I had dual ARB lockers installed as well. Nitro advises the last 50 miles be done in 4WD to help break in the front diff. I’m excited to get this first 500 behind me and push the truck back to it’s full capabilities.
  2. Dec 22, 2019 at 8:09 PM
    TheBeast The Beach
    nice setup !
  3. Dec 22, 2019 at 8:38 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    This is silly to be honest.
    Think about it: we break in gears so we don't heat them up too much and break down the oil too quick. But, your LF axle, diff, and driveshaft is spinning as you drive down the road. So they already get some sort of heat up/ cool down as you DD normally. I would only worry about a break in process on the front end if you plan on doing 80+ mph through the desert in 4WD tomorrow or the day after. Just my 2 cents.
    mallen88 likes this.
  4. Dec 22, 2019 at 8:43 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I thought only the half shafts were live in 2HI?
  5. Dec 22, 2019 at 8:44 PM
    Wildtrout
    Seattle
    I get it. Just following the manufacturer’s recommendations as I want my investment to be in line with their specs for warranty, etc.
    dirtydeeds likes this.
  6. Dec 22, 2019 at 9:17 PM
    dittothat
    dittothat New Member
    Nick
    SD
    2016 MGM Platinum
    I understand the tires but is 160lbs that impactful? I’d guess my cover/toolbox combo is ~400lbs when loaded and after this holiday season I wouldn’t be surprised if my truck was lugging around 700+ lbs on the daily. Guess I better shoot Santa’s workshop a last minute request for gears under the tree on Christmas Day!
  7. Dec 22, 2019 at 9:21 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    I second this.
  8. Dec 22, 2019 at 9:22 PM
    Spvrtan
    Kris
    San Diego, CA
    It's not just the weight but it's also a giant brick for wind resistance on the worst part of the truck.
    14burrito and dirtydeeds like this.
  9. Dec 22, 2019 at 9:24 PM
    Wildtrout
    Seattle
    Great thing is it’s a hard shell that doesn’t cut a huge profile like a square CVT or similar.
  10. Dec 22, 2019 at 9:24 PM
    Spvrtan
    Kris
    San Diego, CA
    I'd wager you're probably close to 8,000 pounds, @Wildtrout; stock is just under 6k.
  11. Dec 22, 2019 at 9:26 PM
    Spvrtan
    Kris
    San Diego, CA
    Yeah, definitely better than the soft cover tents but that's still about 5' wide and 8" tall of a flat area at the front of the shell.
    Wildtrout[QUOTED][OP] likes this.
  12. Dec 22, 2019 at 9:26 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Any size other than stock tire size is very impactful, having the truck stock is what works best for MPG's and performance, of course if you want bigger tires you need gears to have it perform close to stock but every modification is a compromise or at least most of them. I'm on 32" tires and it hurt MPG's but not a lot, can't imagine 37's.
  13. Dec 22, 2019 at 9:28 PM
    Wildtrout
    Seattle
    Good wager. Fully loaded I’m about 8500lb.
    Toyotoholic likes this.
  14. Dec 22, 2019 at 9:28 PM
    Wildtrout
    Seattle
    I can’t imagine going back!
    Samoan Thor[QUOTED] likes this.
  15. Dec 22, 2019 at 9:31 PM
    Samoan Thor
    Also true! I'm eventually going to 285/75/18's which is a skinny 35, regeared to 4.88's.
  16. Dec 22, 2019 at 9:31 PM
    Wildtrout
    Seattle
    Yup. Front of the truck can handle the weight as opposed to my ARE shell which isn’t weight rated.
  17. Dec 22, 2019 at 9:32 PM
    Wildtrout
    Seattle
    Nitto makes a 35 in 11.5 btw. My 37s are also 11.5. I was coming from 295/70/18s.
    Toyotoholic and TheBeast like this.
  18. Dec 22, 2019 at 9:34 PM
    Youngfrankenstein
    Youngfrankenstein New Member
    2015 4x4 CM SR5
    That Tundra is friggin' RADICAL!!!!!!!!
    Wildtrout[OP] likes this.
  19. Dec 22, 2019 at 9:37 PM
    Wildtrout
    Seattle
    You see the part about EXP1 front and rear bumpers? Rear is dual swingout with 37” spare. Also, steel sliders from White Knuckle, Decked system, and RCI steel skids. Point is it’s a heavy truck.
    jordan0317 and dittothat[QUOTED] like this.
  20. Dec 23, 2019 at 6:09 PM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Bam 8 exhaust 285/70 18 ridges 4:88 gears, auburn lsd 6112s SPC UCA
    I am running 285/80 18 Nitto RGs with 4:88s it’s perfect to me
  21. Dec 23, 2019 at 6:14 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Aren't they load range C?
    Kendal makes a Klever RT in a 35x11.5x17 load range D IIRC.
  22. Dec 23, 2019 at 6:38 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    That is a bad truck.
  23. Dec 23, 2019 at 8:28 PM
    Wildtrout
    Seattle
    Nitto's are D...
  24. Dec 23, 2019 at 9:30 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Maybe it was a different tire I got confused on then.
  25. Dec 23, 2019 at 9:33 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Scratch that, maybe there is more than one 35x11.5x17 that Nitto makes cause the MT is a C. I don't see any other 35x11.5x17 on their site, maybe an older model?
  26. Dec 23, 2019 at 9:40 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Hence our miscommunication lol
    I'm over here on 17s
  27. Dec 23, 2019 at 9:40 PM
    Wildtrout
    Seattle
    This is what I’m running...
    14burrito[QUOTED] likes this.
  28. Dec 24, 2019 at 11:01 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    The drivers side CV will turn the spider gears and bearing drag can cause the ring and pinion to spin.
  29. Jun 17, 2020 at 10:45 AM
    STravis
    STravis SOB Fabrication
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    @Wildtrout are you still liking the gears? I'm going to be moving to the same tires as you in a couple months and just curious what your thoughts were on the 5.29's.
    Bigboitundra likes this.
