4 wheel drive stuck in 4hi and flashing
Discussion in '1st Gen Tundras (2000-2006)' started by king_dmgd, May 8, 2021.
  1. May 8, 2021 at 2:04 AM
    king_dmgd
    king_dmgd [OP] New Member
    Donavan
    Green 2001 Toyota Tundra TRD
    Went mudding today came out the mud whole and noticed my 4hi won’t stop flashing nor come out of 4hi into 2wheel how do I fix it? It also won’t go into 4lo...
  2. May 8, 2021 at 4:14 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Here is a very good in-depth video for diagnosing 4WD issues. Suspect you got mud/moisture on the contact strip(s) inside the 4WD actuator.
    https://m.youtube.com/watch?v=TmuEVv1neVQ
    bmf4069 and Schcoman like this.
  3. May 8, 2021 at 4:38 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Give the actuator on the transfer case a good whack with a RUBBER mallet. That should wake it up. Once you're back in 2WD, you might have to remove the actuator and clean the contacts mentioned in the referenced video.
    As far as 4LO, you may need to do the same with the front AAD actuator. If it's been a while since you used 4WD, the actuators can get sticky and tend to freeze up. I actuate them once a month or so, just to keep things moving.
    And welcome to the club!
  4. May 8, 2021 at 6:22 AM
    1/68AR Ventre A Terra
    1/68AR Ventre A Terra New Member
    2019 Platinum
    Viking Heaven Cat Shields and SR5 Rims
    What 84434 writes above is why I had that very thing happen on my 04 Tacoma. It was the quick and easiest one of all the probable causes.FC415CD0-25B7-4BDA-92C3-79CF4E633A9C.jpg
    N84434 and jerryallday like this.
