3rd gen to 2nd gen engine harness swap
Discussion in '2nd Gen Tundras (2007-2013)' started by Oregon B, Jul 29, 2022.
  1. Jul 29, 2022 at 12:37 PM
    Oregon B
    Oregon B [OP] New Member
    11 tun
    so I am new to forum, I have an 11 with 5.7 with bad rods. I purchased a complete 15 engine, trans, transfer with the wiring. Is it possible to install complete setup or do I have to use the old harness and old style transfer case. I assume the transfer case shifter is better on the newer truck, plus having lower miles.
  2. Jul 29, 2022 at 12:56 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Do the whole thing!!!!!!!
  3. Jul 29, 2022 at 4:22 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    A guy in the electrical section just did this. It’s far easier to use the old sensors and working harness with the new engine.
    The 2014+ trucks are the same except they changed a bunch of the wiring connectors pin order. If you are really good a repinning wiring harnesses you could try to use all new stuff but it would be a lot of work m.
