3D Printer
Discussion in 'Sports, Hobbies & Interests' started by Jalzate44, Jan 6, 2021.
  1. Jan 6, 2021 at 7:53 AM
    Jalzate44
    Jalzate44 [OP] New Member
    San Antonio TX
    2024 Tundra SR5 Crewmax 4x4
  2. Jan 6, 2021 at 8:22 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    300BLK and Jalzate44[OP] like this.
  3. Jan 6, 2021 at 8:26 AM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    I have a prusa mini. Very happy with it. They also have a good community and support.
  4. Jan 6, 2021 at 8:28 AM
    Jalzate44
    San Antonio TX
    I don’t have a need for it but the $100 price point makes me want it lol
  5. Jan 6, 2021 at 8:56 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Is the upgrade to the Pro version worth it? I plan on buying one for printing firearms/parts and wasn't sure if the Pro is enough or if i should just upgrade the base kit on my own.
  6. Jan 6, 2021 at 9:11 AM
    CM2007
    CM2007 New Member
    Northern California
    2007 CrewMax SR5
    TRD Exhaust, Dark Tint, Bluetooth (2020 or earlier) License Plate Camera (2021) Tyger T1 Roll Up Tonneau (2021) Loncky leather steering wheel wrap (2021) Dechromed with Plasti-Dip (2021) Osram Reverse Bulbs (2021) Bilstein 6112s up front (April 2021) 2022/2023: New Head Unit (Android?) Sliders/concealed running boards
    I’ve also heard awesome things about the Creality. There’s nothing worse than a bad 3D printer. You’ll spend more time adjusting and fixing issues than printing if you pick the wrong one!
    -I’ve printed about 200 projects over the last couple years
  7. Jan 6, 2021 at 9:13 AM
    Danimal86
    Daniel
    Sacramento, CA
    Go to thingaverse.com and take a poke around and see what you would be interested in printing. Take a look at the build volume of the $100 printer and see if what you would want to print will fit in there.
    So the thing with the ender is, its an inexpensive starting platform. You can customize the bajesus out of it. Things you would want to do right off the bat:
    Glass build plate ($10 at lowes)
    All metal extruder (the plastic one will break eventually)
    upgraded leveling springs to keep level for longer
    auto bed leveling
    capricorn bowden tube
    So only the first one is something i would do right off the bat. The smooth glass surface gives your print a better chance at sticking and it will be perfectly flat (important).
    The other things i would do as you go. All the upgrades are pnp except for the auto bed leveling. That requires flashing of the firmware, but there's about 100 different youtube videos that make it quite easy.
    I think the main things with the pro over the non-pro is upgraded y axis, better power supply and a flexible build plate (i'd still use the glass one). Imo, not worth the extra $
    if you want to spend a little more, i would look at the ender 3 v2 or the ender 5. I think those you can just plug the bl-touch (auto bed leving) and it works.
    rockmup likes this.
  8. Jan 6, 2021 at 9:34 AM
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Hmm... sounds a lot like modding a truck.
    I’m lucky- have access to an Ultimaker S3 at work. Don’t have to spend much time tinkering with the machine but still spend plenty of time tinkering with the designs I print on it.
    Jalzate44[OP] likes this.
