3D Printable Tundra Model
Discussion in '2.5 Gen Tundras (2014-2021)' started by THORYOTA, Apr 19, 2022.
  1. Dec 9, 2025 at 9:41 PM
    #151
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Whoa, this one has the gen 1 frame rust mod! Authentic!
    And TRD pro rims.
  2. Dec 10, 2025 at 3:38 AM
    #152
    Corndog123
    Corndog123 Knife creator.
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
  3. Dec 10, 2025 at 10:01 AM
    #153
    THORYOTA
    THORYOTA [OP] God of Thunder
    Thor
    Asgard
    2021 MGM TRD CM "Mjölnir"
    Dude! Looks pretty good!
    Any issues you ran into?
    BeauDacious[QUOTED] likes this.
  4. Dec 10, 2025 at 10:53 AM
    #154
    BeauDacious
    BeauDacious 040 > all
    Beau
    14 DC 4x
    The only thing I noticed that needs work before more print tests was the hitch. The hitch piece is floating off the surface of the build plate.
    It would be great if the parts were separated, so I could manipulate them on the build surface individually. But nothing major.
    I think I could glue it solid and paint it as it is.
    The ledges on the bed ends were a nice touch to make the front align. The small slits on the bed sides are proving to be an issue. But that may clean up with better print quality and better attention to where it inserts supports.
    The alignment on the pieces feels pretty good around the cab body and doors. The writing on the Airbox and doors printed even at standard quality. It should do much better when printed at high quality.
    Maybe add a pin or other attachment into the cab to top to steady it in glue up. Its very easy to rotate it off center as it is, but I'd bet that's part of the stuff you've in the works on it.
    Corndog123 likes this.
  5. Dec 10, 2025 at 11:39 AM
    #155
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    I've got a Prusa Mk3/S+ that I haven't used in a year or so, I was thinking about upgrading to the Mk4. I ordered a Bambu Labs with the AMS/multi-material stuff for less than Prusa wants to upgrade my Mk3. I think it is supposed to be here Friday, so I might have to try printing this with the Bambu.
    Florida AF and BeauDacious like this.
  6. Dec 10, 2025 at 12:42 PM
    #156
    BeauDacious
    Beau
    14 DC 4x
    Which Bambu did you get? The A1 Mini? Thats a good little printer. If you decide on an enclosure later, it fits in between lack tables from ikea with a bit of plexigass from your local big box hardware, and you can build one for under 100$. I dont know if I'd try this as a first print off of it. Its a lot of hours.
  7. Dec 11, 2025 at 4:25 AM
    #157
    Corndog123
    Sam
    Tennessee
    Does the antenna base dry rot and everything? Ha ha ha
  8. Dec 11, 2025 at 7:30 PM
    #158
    RD-TUN
    RD-TUN New Member
    21 Red 1794
    Hello everyone! I'm new to the forum, and this is my first post.
    Thank you, Thor, for posting your files!!! I've hunted high and low for a model kit of the 2.5 gen Tundra.
  9. Dec 11, 2025 at 8:07 PM
    #159
    RD-TUN
    RD-TUN New Member
    21 Red 1794
    I did a test print today, and the detail is great! The resolution shown is .08 fine setting on a Bambu Carbon, printed flat. I sent another print before I left work, but I tilted it 40 degrees with support. (screen pic) This should reduce the body panel terracing of my first print; I'll see tomorrow.
  10. Dec 11, 2025 at 8:22 PM
    #160
    Florida AF
    Logan
    North Florida
    I have the same printer and am trying very hard not to buy the Bambu on sale right now.. .with no job, it isnt wise; however I know I could use it to make money too.... Good luck!
  11. Dec 11, 2025 at 8:24 PM
    #161
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Oh damn! It’s the infamous bed stamp!
  12. Dec 11, 2025 at 9:59 PM
    #162
    BeauDacious
    Beau
    14 DC 4x
    Which is why I asked for the parts to be separate.
    ZappBrannigan and Corndog123 like this.
  13. Dec 11, 2025 at 10:30 PM
    #163
    Tripleconpanna
    2021 TRD PRO CM; 2011 SR5 SC'd DC; 2008 SR5 CM
    :yes:
    You know we argued heavily for that at the inception of this process!!! :yay:
  14. Dec 11, 2025 at 10:44 PM
    #164
    BeauDacious
    Beau
    14 DC 4x
    Because the "worthy" would spend real dollars on the stamped bed side.
  15. Dec 12, 2025 at 3:12 AM
    #165
    Corndog123
    Sam
    Tennessee
    Welcome from TN!! I too am interested in said model. I do not have a 3D printer but would happily buy a kit if it's reasonable.
    ZappBrannigan likes this.
  16. Dec 13, 2025 at 7:54 AM
    #166
    RD-TUN
    RD-TUN New Member
    21 Red 1794
    Thank You, Corndog!
    The angled fender print came out great, featuring much smoother body panels that reduce the need for sanding before painting.
  17. Dec 13, 2025 at 8:04 AM
    #167
    RD-TUN
    RD-TUN New Member
    21 Red 1794
    Parts like the truck bed and engine can be printed flat with great results
  18. Dec 13, 2025 at 10:08 AM
    #168
    Corndog123
    Sam
    Tennessee
    That is SO FREAKING COOL!!!
  19. Mar 1, 2026 at 8:18 PM
    #169
    Florida AF
    Logan
    North Florida
    Lost this thread for a while... I printed most of the truck and was very impressed with the details. I ran it with some filament I was trying to burn through and was still impressed with the results. I did stop printing it as I am not interested (for now) in gluing this thing all together.
    Excellent craftsmanship.
    I ran into some issues with my settings on supports and orientation, but overall the parts came out very clean and detailed. When I print it again, I will change some orientations for sure.
    Downytide and RobertD like this.
  20. Mar 2, 2026 at 7:25 AM
    #170
    coTony
    Tony
    Montrose, CO
    Anyone have a recommendation for a good 3D printer that has a good size bed for printing? The wife has me thinking about some things so looking at the moment
  21. Mar 2, 2026 at 7:50 AM
    #171
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    do you have a budget in mind?
  22. Mar 2, 2026 at 9:08 AM
    #172
    coTony
    Tony
    Montrose, CO
    Not yet, just trying to see what the options are. The shop/home is getting closer to being complete so I am starting to shop
  23. Mar 2, 2026 at 10:05 AM
    #173
    BeauDacious
    Beau
    14 DC 4x
    Unless you want to print super high detail miniatures. I'd go FDM over SLA.
    FDM melts plastic in the hot end and layers it on top, its what most people think of. SLA is a liquid bath that uses UV light to harden plastic one layer at a time while keeping it submerged. SLA is messy, expensive, and time consuming, but can produce beautiful pieces.
    For FDM
    Honestly. Just start with the Bambu P1S. It can do nearly everything the pricier models can do, and it simply works. It can handle all the common materials, and is easy to use, comes enclosed, and once you add the AMS unit, you get multicolor or multi material printing. This will do 90% of what every other printer can do, and its not break the bank pricey. The base model is down to $399, and the combo with the AMS is only $549. When you are looking at $239 for the most basic ender 3 (bottom tier). The price jump isnt far for the amount of headache, time, and extras.
    Are there faster printers? Marginally at best.
    Are there newer models? Yes
    Are there features this doesnt have that you would want. - Per user stuff, but the largest thing is is lacking is the heated chamber (which is fairly easily solved),
    Are there are other types out there? tool head changing printers, multi extruder printers. Metal FDM, SLA... Those start to have serious drawbacks or price concerns.
    The biggest drawback with Bambu is the vendor lockin in software and RFID media, but that is starting to proliferate to other vendors also.
    I have no SLA recommendations. I dont use them.
    as for print volume. The white circle at the bottom is a 5 Gal bucket lid. This hudroponics tower is about 4 foot high.
    coTony[QUOTED] likes this.
  24. Mar 2, 2026 at 11:10 AM
    #174
    Florida AF
    Logan
    North Florida
    x2....
  25. Mar 2, 2026 at 11:51 AM
    #175
    831mic
    831mic 2016 DC TRD PRO
    California
    '16 DC TRD PRO
    Any chance you have an idea on the wheelbase with it sized the way it is?
    I'm going to try to print this to mount on a Traxxis TRX4.
  26. Mar 2, 2026 at 12:17 PM
    #176
    Florida AF
    Logan
    North Florida
    I took the pic and tossed them. do you have software you can load the STL in and measure it? If not, I will check when I get time.
  27. Mar 2, 2026 at 12:38 PM
    #177
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Gonna send this to my son in law and see if he can print it for me. Thank you.
  28. Mar 2, 2026 at 4:55 PM
    #178
    831mic
    California
    '16 DC TRD PRO
    Ya, I can, but since it's in pieces I thought it might be easy for you to measure. All good! I'll take some measurements tonight. I'll report back :)
  29. Mar 3, 2026 at 6:07 AM
    #179
    Gaston
    Gaston New Member
    Gary
    SE MI
    I'll agree with the above, I've been really happy with my Bambu Lab printers. I currently have two X1C printers both with the AMS.
    before buying consider what you'll want to print. Size to determine if a certain printer will be big enough. Useage to decide what material you'll want to be printing with. If you'll want print with just standard materials like PLA, PETG, TPU, ABS and ASA then the P1S will be fine. If you want to print with more advanced materials, for example those with carbon or glass in it, you need a hardened nozzle and extruder gears. You can buy those parts and swap them into the P1S. If you think you will want more bed space than a P1S, P2S or X1C, then look into the H2S. I wish I would have waited a little longer before buying my second X1C as I would have bought the H2S instead, but I can't really complain as I got it at a good price and it's a solid printer but the extra build volume would have been nice.
  30. Mar 3, 2026 at 8:41 AM
    #180
    831mic
    California
    '16 DC TRD PRO
    Current wheel base is roughly 7.25", I'm going to see if I can scale this to the TRX4 wheelbase, which is 12.3"
