38 Gallon-friendly sliders
Discussion in '2.5 Gen Tundras (2014-2021)' started by NHPig, Dec 13, 2017.
  1. Dec 13, 2017 at 10:03 AM
    NHPig
    NHPig [OP] Toyota For Life
    New Hampshire
    Super White 2016 Tundra Limited TRD CrewMax 5.7L V8
    Please forgive me if I missed it elsewhere, but I have put my time in searching.
    I am trying to compare/contrast sliders that are compatible with the 38 gallon fuel tank.
    I have a 2016 Limited CrewMax.
    So far, my contenders are
    P & P - Yes, 38-gallon friendly, confirmed by Facebook Messenger, advises install is easier if you take the factory plastic skid plate off from the tank straps.
    SDHQ - Pending
    White Knuckle - Yes, 38-gallon friendly, confirmed by BigTimber.
    All Pro APEX - Yes, 38-gallon friendly, confirmed by 16tunterd
    Demello - Yes, 38-gallon friendly, Rock Crushers, confirmed by Gbatchder (same truck as mine, 2016 CrewMax
  2. Dec 13, 2017 at 10:19 AM
    blizz86
    blizz86 New Member
    CBI also makes a set, but they don't advertise or have it listed anywhere.
  3. Dec 13, 2017 at 10:22 AM
    Sunnier
    Sunny
    San Diego, CA
    I'd like to piggy-back on this question (but not derail it). Please, those of you who know and answer the OP, indicate which are compatable with a 2016 CM w/ 38 gallon tank, and also which are comparable with a DC without cutting to shorten. I keep reading about having to cut em and I don't want to.
  4. Dec 13, 2017 at 10:33 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The wheelbase are the same between a DC and CM. There shouldn't be any reason to cut the length. I think most sliders are interchangeable, atleast the SDHQ ones are.
  5. Dec 13, 2017 at 10:54 AM
    Sunnier
    Sunny
    San Diego, CA
    Thanks, Joon! So, for the OP, SDHQ sliders will fit his ride....
    joonbug[QUOTED] likes this.
  6. Dec 13, 2017 at 10:57 AM
    Gbatchelder
    Gbatchelder New Member
    Greg
    ‘16 Tundra SR5
    BDS level kit (3/1) Demello Rock Crusher Sliders Stealth Mount Grill LED light bar
    I have the Demello Off-road Rock Crusher Sliders. They came bare metal and had them Line-X’d and they are awesome. They are on my ‘16 SR5 with 38 gallon tank. No cutting or drilling required. http://demello-offroad.com/
  7. Dec 13, 2017 at 11:13 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i've got demello's as well but the hybrid version. you will only have to drill a few holes in the frame if you want them weight bearing.
    Sunnier likes this.
  8. Dec 13, 2017 at 11:40 AM
    NHPig
    New Hampshire
    What do the Demello's look like underneath? Do they wrap under frame?
  9. Dec 13, 2017 at 11:46 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    Yes, it's an L bracket. There are 4 of them. The outside of the L lines up with existing holes in the frame. The most rearward L, has holes that line up in both the side and bottom of the frame. If you just want them as steps, you only need to bolt the outside of each L as well as the bottom on the last one by the rear tire. If you want them weight bearing as sliders, you will need to drill holes in the bottom of the frame, 3 on each side, 1/2" bit.
    They are mountable as a one man job but you'll have to get creative with a floor jack.
    dcsleeper408 likes this.
  10. Dec 13, 2017 at 12:37 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I have the exact same ones, installed about 8 months ago. Love ‘em. They fit perfectly on my 16 crew max w/ a 38 gallon tank.
    Eclipsed & Floating and Sunnier like this.
  11. Dec 13, 2017 at 1:03 PM
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    I went with the same Demello Rock Crusher sliders. In order for this to be used as a true slider some drilling is required. I believe it’s 4 holes into the frame.
  12. Dec 13, 2017 at 1:17 PM
    BigTimber
    BigTimber New Member
    Ben
    Casper, WY
    2016 TRD Pro
    White Knuckles on my 2016. Had to drill some holes for the underside of the brackets. I especially like the extra little lip at the front and behind the slider.
  13. Dec 13, 2017 at 2:03 PM
    Unlimited
    Unlimited New Member
    2017 Tundra Crewmax Limited TRD Offroad
    TRD dual Exhaust, TRD Pro Skid Plate, TRD CAI, Demello Hybrid Sliders, Bilstein 6112/5160, Total Chaos UCA, Toytec rear Shackle lift @ 1.5", SCS Ray10 18" with spare, Cooper STT Pro 295/70r18 with spare, Extang Solid Fold 2.0 Tonneau, KB Voodoo Hi Rise Crossbars Oh Sh!t handle add
    +1 for Demellos. Got them ridiculously fast too. Not sure if that is normal but they make some nice stuff.
    smslavin and dcsleeper408 like this.
  14. Dec 13, 2017 at 2:50 PM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
  15. Dec 13, 2017 at 2:51 PM
    SuperSilverTundra
    Nick
  16. Dec 13, 2017 at 5:13 PM
    Gbatchelder
    Greg
    ‘16 Tundra SR5
    With the Demello’s it’s 4 holes in the frame per side if you want them as true Sliders or to jack up the truck with them. I’m just using them as running boards and are solid with the frame hole bolts. They are heavy duty - 76 pounds each I believe - quite the install with two floor jacks. I’ll post some more pics of the bottom when I can get some in the light.
  17. Dec 13, 2017 at 5:34 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    @sdhq_offroad
    Complete bolt on... no drilling
    Mounts wrap around the frame
    Mounts to cab mount in very front of sliders
    4130 chromoly tubing
    Erichudgins, Wrongside, CJ21 and 3 others like this.
  18. Dec 13, 2017 at 6:03 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    All Pro on a '16 CM with 38 gal. tank. You do have to drill some holes in the bottom of the frame. I like the way are canted up slightly so they don't make the truck look lower. I landed the truck on 'em last weekend w/o issue. This was the gentle "truck is taking a brake". But it made it the 1st time and came down hard on the sliders, so hard that I got out to take a look to what I'd done,,,,, nothing.
    CJ21, NHPig[OP], dcsleeper408 and 2 others like this.
  19. Dec 14, 2017 at 9:23 AM
    Sunnier
    Sunny
    San Diego, CA
    Newm, NHPig[OP] and dcsleeper408 like this.
  20. Dec 16, 2017 at 8:17 AM
    NHPig
    New Hampshire
    Looking at P & P, but don't see these listed (with a kickout). What type do they consider that one?
  21. Dec 16, 2017 at 8:22 AM
    NHPig
    New Hampshire
    I've started to pay attention to that thread, and tempted to get on the 20 pre-order, but hard to tell if that is the right route. I like that the lower half of the L-bracket runs almost the entire length of the bottom of the frame.
    Sunnier[QUOTED] likes this.
  22. Dec 16, 2017 at 8:22 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    They stopped making that one.
  23. Dec 16, 2017 at 8:23 AM
    NHPig
    New Hampshire
    Ah, thanks. I like the kick-out.
  24. Dec 16, 2017 at 8:26 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    When I replace mine in the spring this is what I’ll have
  25. Dec 16, 2017 at 8:28 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Why you replacing yours? It’s going to turn into a collectors item. :laugh:
  26. Dec 16, 2017 at 8:33 AM
    Eclipsed & Floating
    Voluptuous Whitey
    More than half of my backing plates were too big so I had to compromise strength for a snug fit. Ifiever have to jack up in certain spots it’ll be onlybolts that is supporting the truck
    Ok know why they’re discontinued
  27. Dec 16, 2017 at 8:41 AM
    SoCalDave
    SoCalDave New Member
    Dave
    2016 DC 4x4
    WKOR fits the 38 gal. Have to drill out holes at the bottom though.
  28. Dec 16, 2017 at 9:31 AM
    Sunnier
    Sunny
    San Diego, CA
    Everything I read about BAMF is that their products are top-notch. But after scouring this forum, I decided I'll go SDHQ because they also have an excellent reputation, their sliders offer coverage over the greatest length, and (probably most important to me, so I don't have to decide whether I'm putting holes in at just the right places), I don't have to drill holes in my truck to install. I'm not a fan of kick-outs, so not having any or much would please me best.
    Now, back to BAMF, if you read through all of that other feeler thread, there's some theorizing that you could pay a bit extra for a kick-out. Who knows, maybe they'll build them to extend the full length and locate holes to mount into those already in your truck. If so, those on that feeler list will be a lucky crowd. You could be their hero if you sign up, because they need a few more to commit, like, right now. And it might be a unique opportunity to get best or tied-for-best sliders at a lower price than they'll ever be going forward....
    If those get built, and have the quality and customized fit for the Tundra that the SDHQ have, thousands more will jump to buy; and may or may not get that chance, depending on whether BAMF can put them out at a price point that makes sense for them and purchasers.
    I bet there's a couple thousand of us still watching that thread. But, because it's a 1st production kinda thing, BAMF hasn't put out details about the things that are priorities to me.
  29. Dec 17, 2017 at 2:49 PM
    rodm1
    rodm1 New Member
    I'm going to tag along on this thread. very good information.
    Sunnier likes this.
  30. Dec 17, 2017 at 4:02 PM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    x2
