37s with zero off set is it possible
Discussion in 'Wheels & Tires' started by Trdwillie14, Nov 23, 2020.
  1. Nov 23, 2020 at 8:53 PM
    Trdwillie14
    Trdwillie14 [OP] New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Just wondering if anyone has it. Zero offset method mid travel with 37s. Thanks for the help
    SC_TRD likes this.
  2. Nov 23, 2020 at 9:04 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    If it doesn’t work you haven’t done enough cutting
  3. Nov 23, 2020 at 9:16 PM
    Ryuu
    Ryuu New Member
    Oscar
    SouthEast, TX
    17 TRD PRO Barcelona Red
    just threw stuff at it
    I had asked @blackoutt about this quite sometime back since he did it.
    Here's a screenshot of his reply.
    SC_TRD and Trdwillie14[OP] like this.
  4. Nov 24, 2020 at 1:41 AM
    TXTundra2722
    2015 Black Tundra
    Yes it is possible, I'm running this setup up..... as there are several as well on here that are. Now you didn't specify anything else, so are you trying to run this stock or what size lift?
  5. Nov 24, 2020 at 5:14 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Message from Trdwillie14 "I have the same rims zero off set and have a huge deal on 37s. Some say u can some say u can’t. I’m running fox 2.5 with total chaos uppers"
    Are they 12.5 wide 37s? post pictures of your lower control arm cam tab adjusters, body mount chop, pinch weld area, and I'm not familiar with these upper control arms, are they the heimed adjustable ones? Also any pictures of any areas of rub that you're concerned about. We can make this work!
  6. Nov 24, 2020 at 5:40 AM
    Trdwillie14
    Billy
    2014 trd off road
    Sorry I have fox 2.5 with total chaos upper control arms
  7. Nov 24, 2020 at 5:44 AM
    Trdwillie14
    Billy
    2014 trd off road
    Hey they are 37s 12.5 on 17s it’s a deal I was offered but didn’t know if I’m going down a rabbit hole. I posted a pic of my upper arms. I have a bmc it will need more and have to do a pinch. But I think a member @joonbug did this and still couldn’t fit a 37
  8. Nov 24, 2020 at 5:47 AM
    BlackSheep
    BlackSheep caffeinated member
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    held together by duct tape and baling wire
    lol you are persistent
    Trdwillie14[OP] likes this.
  9. Nov 24, 2020 at 5:48 AM
    Trdwillie14
    Billy
    2014 trd off road
    More like a screaming deal so I wanna make sure lol
  10. Nov 24, 2020 at 5:52 AM
    BlackSheep
    Scott
    Kansas City, MO
    Just buy them and figure it out, dude! Every truck is different, and what one person says "fits" may not match another person's definition. If they're as good a deal as you're saying, you're probably not going to lose money if you have to turn around and sell them.
    snivilous and Elduder like this.
  11. Nov 24, 2020 at 5:53 AM
    Trdwillie14
    Billy
    2014 trd off road
    That’s very true
  12. Nov 24, 2020 at 5:56 AM
    blackoutt
    Indy
    OEM+
    I really like those wheels! but I'm biased.
    Ah okay, so your uppers aren't adjustable. You're kind of stuck with cutting more to make them fit then since your only alignment adjustment is on the lowers. Definitely going to need to work on the pinch weld area and lose some of the liner over it, mines cut at an angle from the lowest outside corner up towards the first inner plastic liner clip. I still rub in certain situations btw, it's a way of life. Just buy them and figure it out later.
    Trdwillie14[OP] and BlackSheep like this.
  13. Nov 24, 2020 at 10:17 AM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    Just saying.. easy way to make them work
    :anonymous:
    GodlessPro likes this.
  14. Nov 24, 2020 at 10:27 AM
    Trdwillie14
    Billy
    2014 trd off road
    Hahhaha naw I would stay 35s if that was the case
  15. Nov 24, 2020 at 11:16 AM
    TXTundra2722
    2015 Black Tundra
    Joonbug wheels his truck pretty hard....and without him putting in his two cents, I'd day what he meant was that it didn't work for him at "Full stuff" of the wheel. If you don't go 80-100mph in the desert and just lightly wheel offroad at the most then you'd probably be OK. With that said, someone on here said it correctly when they mentioned that what works for one truck, won't work for the next.... which is very strange but true with our trucks. If I remember correctly, the TCA uppers.... if that's what you have, already have alot of castor built in.... even though they aren't adjustable. When you get it aligned, you want 4-5+ on castor.... which is what pushes the wheel forward. Are you running a stock front bumper? Because this is the other issue, if so then your just pushing the tire into your bumper/flaps now.... if your handy with a side grinder and while you're at completing your BMC (which is super easy to do) then just trim away from the front. I'm in agreement with everyone else... if you have an awesome deal then go for it! @KevinK is one of the few on here that was on 37s with minimal lift... maybe he'll pipe in. Keep us in the loop on which route you go!
    Trdwillie14[OP] and chugs like this.
  16. Nov 24, 2020 at 11:27 AM
    Trdwillie14
    Billy
    2014 trd off road
    So this is the best they said they could do with the caster. And no I have an nfab front bumper I have a ton of room up front. I have someone to do a better chop and pinch. I hope they fit but I also wouldn’t want to replace my rims and upper arms just for wheel size. Yah I’ve texted joon for sure lol. And I’m sure he goes way harder then I ever will lol
  17. Nov 24, 2020 at 12:19 PM
    blackoutt
    Indy
    OEM+
    so that may be the best they could do on caster while keeping camber in spec, still seems low for TC upper arms that have caster built in though. With adjustable upper arms, you can max the lowers out for the most caster, then dial the camber back into spec with the uppers. I like the driving feel of 4-5 degrees caster.
  18. Nov 24, 2020 at 12:30 PM
    SC_TRD
    Colin
    Round Rock, Tx
    My caster is 3.8 and 4.3... we literally have the same front end components... you can get more if you make some small sacrifices
  19. Nov 24, 2020 at 12:32 PM
    Trdwillie14
    Billy
    2014 trd off road
    That being said I didn’t say they were good at their jobs lol I’m sure u can get more out of them I just can’t find a shop to do it
  20. Nov 24, 2020 at 1:14 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    The caster is the least of your worries. You can always chop more and more until they fit or get new Heimed uppers. What you can’t get around is hitting the wheel arch with the top of your tires. Here’s a pic of my old truck at medium stuff. This is only with a 34.5” tire and +25 offset. Imagine a tire that will be over 1” closer to the fender and about 1.5” further out. One big hit and you’re either trashing your fenders or your tires.
    Picture this honker on a stock fender
    It can probably be done somehow. I just don’t think it’s going to be worth the trouble. If the wheels and tires are that good a deal, I would grab them, buy new wheels and put the tires on the new wheels.
    GodlessPro, chugs, SC_TRD and 2 others like this.
  21. Nov 24, 2020 at 1:16 PM
    Trdwillie14
    Billy
    2014 trd off road
    Great point thanks dude and thanks for the pics it seems like the 35s are just more capable for me
    joonbug[QUOTED] likes this.
  22. Nov 24, 2020 at 1:23 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    NOOO!!!! That was not the moral of the story!!! It was to get the 37's, just not with a 0 offset!!! :rofl:
  23. Nov 24, 2020 at 1:53 PM
    SC_TRD
    Colin
    Round Rock, Tx
    I am trying to sell him on new wheels too! Sling the 701s and the 35s and get brand new wheels with the 37s.. probably won’t even lose much on the deal
  24. Nov 24, 2020 at 1:56 PM
    Trdwillie14
    Billy
    2014 trd off road
    Cant I don’t like icon nothing looks good to me i need till warren sells his new wheels lol
    joonbug likes this.
  25. Nov 24, 2020 at 1:57 PM
    Trdwillie14
    Billy
    2014 trd off road
    Hahahhaa nooooooooooooooo:rofl::rofl::rofl::rofl:
    Saltyhero13 and joonbug[QUOTED] like this.
  26. Nov 24, 2020 at 2:02 PM
    SC_TRD
    Colin
    Round Rock, Tx
    problem solved, just get it in black to match your heart :boink:
    chugs likes this.
  27. Nov 24, 2020 at 2:06 PM
    Elduder
    Elduder New Member
    Or 313s, theyre +25.
    SC_TRD[QUOTED] likes this.
  28. Nov 24, 2020 at 2:09 PM
    Trdwillie14
    Billy
    2014 trd off road
    They also have to be cold blooded
  29. Nov 24, 2020 at 2:26 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Is it out already?
    313s don't have bead grip though.
  30. Nov 24, 2020 at 2:36 PM
    Elduder
    Elduder New Member
    Honest question here, so with 37s do you need to air down as low?
    The sidewall height would be taller, of course :tinfoilhat:, but would a taller sidewall allow for more deformation and contact even at higher pressures?
    Also, considering cavity size, 15 psi (arbitrary #) in a 35 vs 15 psi in a 37 would result in more gas being present in the 37 despite the same pressure. Would this allow you to theoretically run a lower PSI while still maintaining comparable deformation to a 35, at a higher PSI in the 37?
