37s 17s 22 Tundra leveled confirmed
Discussion in '3rd Gen Tundras (2022+)' started by NueveTundra, Dec 23, 2021.
  1. Dec 23, 2021 at 9:22 PM
    NueveTundra
    NueveTundra [OP] Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
  2. Dec 23, 2021 at 10:38 PM
    mass-hole
    mass-hole New Member
    The wheel wells looked huge so I believe it.
    now the problem is trying to run 37’s with 3.31 gears. Its too bad they don’t have optional 3.73’s or 3.90’s.
    TK1979 and frichco228 like this.
  3. Dec 23, 2021 at 11:40 PM
    1stGenTundraVamp
    1stGenTundraVamp New Member
    D
    1st Gen TRD Tundra 4x4
  4. Dec 24, 2021 at 2:41 AM
    racer01
    racer01 New Member
    Geoff
    Aiken South Carolina
    23' TRD Pro
    295/70-18 Nitto Recon Grappler, RB 20 running boards
    It is a Westcott Design preload collar lift. It's not on their page products page yet but they have talked about it a little on social media. As you can tell the preload collars they make all look about the same and are a good way to get some lift without geometry issues of a big spacer on top. I'd imagine it is very similar in style to the last one on the page (Land Cruiser 200). Their lifts are very popular with the current gen TRD Pro's as they allow you to keep the Fox shocks and keep the geometry in the proper ranges.
    https://westcottdesigns.net/store/suspension/
    TK1979 and ryanwgregg like this.
  5. Dec 24, 2021 at 5:10 AM
    nuclear
    nuclear New Member
    Didn't watch video, but what about the spare?
    TK1979 and RavingOx like this.
  6. Dec 24, 2021 at 5:57 AM
    RavingOx
    RavingOx Member
    WNC
    2022 Tundra Platinum in Black
    It wasn’t mentioned. But good point.
    TK1979 likes this.
  7. Dec 24, 2021 at 7:43 AM
    Keeferton
    Keeferton New Member
    Keith
    Bend, OR
    22 Tundra TRD Off-road DC
    I know they say it doesn't limit travel but doesn't this basically use the vehicles down travel to lift it? So basically after you did this you would have very little to no down travel? It does look badass though.
    PeakIT and TK1979 like this.
  8. Dec 24, 2021 at 7:50 AM
    randomquickness
    randomquickness New Member
    Very glad to see 17’s worked. That opens up more tire options that aren’t load range E
  9. Dec 24, 2021 at 1:16 PM
    NueveTundra
    Planet Earth
    Me personally if I got a 2022 early (looks to be probably mid year if I can) would just purchase one of the early easy lift ways (like Rough Country spacer kit for $180) to get stanced right. Then when the aftermarket market catches up with full lifts, buy one and install it.
    In doing so it would also allow the split cost of buy wheels and tires then a real lift later. ;)
