35s on a Tundra
Discussion in 'Wheels & Tires' started by Rebelyell89, Oct 25, 2020.
  1. Oct 25, 2020 at 6:14 PM
    Rebelyell89
    Rebelyell89 [OP] New Member
    2019 Tundra
    Im getting ready to put some bigger tires on my SR5. Is anybody having trouble fitting 35s on a Tundra with a level kit? I plan on putting Bielstien 5100s all around and level out the front, and wondered if I would have any rubbing issues with 35s.
  2. Oct 25, 2020 at 6:17 PM
    You will probably have some rubbing on some of the plastics.
  3. Oct 25, 2020 at 7:10 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    What wheels? I have +25 offset wheels and I had no rubbing whatsoever when I had the factory bumper. If you have a good alignment, you will not rub at all with the correct offset.
    https://www.youtube.com/watch?v=fK2y9NcqpYg
    drew.c.114, Bob_Wiley and Elduder like this.
  4. Oct 25, 2020 at 7:15 PM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Ditto this.
    Remove the front plastic and mudflaps.
    My 35x12.5/18's on +25 offset fit with no rubbing whatsoever on 3" lift.
    Gee Dub likes this.
  5. Oct 25, 2020 at 7:48 PM
    dMO
    dMO New Member
    David
    2010 Black Tundra
    Toytec 3/1 leveling kit 18x9 VE37 35x12.50 Toyo RT
    All depends on your wheel offset. Mine are 0 offset and it rubbed on the body mount.
  6. Oct 28, 2020 at 6:26 AM
    Tundraman479
    Tundraman479 New Member
    Barry
    2024 Tundra Crewmax TRD Sport Lunar Rock
    I just put 5100's up front at the highest setting and am running a 295/70/18 on factory offroad wheels. No rubbing but I had already removed the mud flaps. The tire is just a hair smaller then a 35x12.5 but it fills the wheel well and looks good on the Tundras.
  7. Oct 28, 2020 at 7:54 AM
    LA184
    LA184 Living the Dream
    2014 4x4, 4.6L Radiant Red Tundra
    4 in lift, 35s, Black Rhino Armory Wheels, Custom Rock Sliders, SDHQ ABS Guards, Warn Winch Bumper, Warn Evo VR 12-S Winch, 4.88 Re-Gear, Rear E-Locker.
    I had plenty of rubbing, unfortunately, with 35s and a 4in lift. I would recommend removing the plastic in the fender and consider the option of a BMC. Others have different results...
  8. Oct 28, 2020 at 8:30 AM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Its all about wheel offset.
    Berdine and LA184[QUOTED] like this.
  9. Nov 6, 2020 at 2:17 PM
    Rebelyell89
    2019 Tundra
    Im looking at the 5100s also. Thanks for the input
  10. Nov 6, 2020 at 2:26 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    It is all about offset, i have a 6" lift with 35s on 20s with -24 offset and rub on full turns
  11. Nov 6, 2020 at 2:31 PM
    BlackSheep
    BlackSheep caffeinated member
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    held together by duct tape and baling wire
    wheel offset is the key. i had 35s on my stock RW wheels which are +50mm and didn't rub anything. Stock height, no other mods.
  12. Nov 6, 2020 at 2:50 PM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    18x9, +25 offset.
    35x12.5 Nitto Terra Grapplers
    No plastic.
    No rubbing.
    J&ATundra likes this.
  13. Nov 6, 2020 at 3:04 PM
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    3/1 Lift (Level) with 35x12.50x20 tires had to have a CMC to fit. No Plastic rubbing
  14. Nov 6, 2020 at 4:21 PM
    Blueknights75
    Ron
    Clayton, NC
    5100s on all four corners with front at top setting. Running 295/70/18 on PRO wheels. I could imagine going any larger without rubbing issues as well as the close proximity to the UCA..
  15. Nov 8, 2020 at 12:10 PM
    JoshR324
    JoshR324 New Member
    North TX
    What do y’all think about 18x9 with a +18 offset? That’s what I’m planning on running with 35x12.5 and would like to avoid the BMC if possible.
  16. Nov 8, 2020 at 12:25 PM
    TheBeast The Beach
    thats what I have and did the bmc to clear the bigger tires.
  17. Nov 8, 2020 at 12:55 PM
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    YEP! NO PROBLEM W/ MY SET UP. (see in signature) TOOK OFF THE FRONT REAR MUD FLAP ONLY & PUSHED THE INNER LINER IN A BIT.
    :oldglory:
    O.S.T.
  18. Nov 8, 2020 at 12:56 PM
    JoshR324
    JoshR324 New Member
    North TX
    dang I was hoping it wouldn’t be necessary. Guess that .27” makes a big difference. (That’s what she said)
    GODZILLA likes this.
  19. Nov 8, 2020 at 1:33 PM
    hhenry_
    hhenry_ New Member
    Bay Area Ca
    08 tundra crewmax
    I have 18x9 +20 offset but I don’t rub I took off my mud flaps.
    JoshR324[QUOTED] likes this.
  20. Nov 8, 2020 at 1:42 PM
    TheBeast The Beach
    depends how you will use the truck, if going off road, tight turns, big droops then you gotta have to do the bmc but if just driving on roads you might be fine without.
  21. Nov 8, 2020 at 11:54 PM
    JoshR324
    JoshR324 New Member
    North TX
    cool thanks guys
  22. Nov 9, 2020 at 7:30 AM
    ejl04
    ejl04 New Member
    Could you show is a side show down the side of your truck to see how far they stick out past the fender?
  23. Nov 23, 2020 at 1:13 PM
    Rebelyell89
    2019 Tundra
    Man that is the look Im going for. Any rubbing issues on tight turns?
  24. Nov 23, 2020 at 2:27 PM
    Blueknights75
    Ron
    Clayton, NC
    No rubbing whatsoever...after trimming the skid plate and removing the front mud flaps.
