34/35’s on trd offroad rims pics please
Discussion in '3rd Gen Tundras (2014+)' started by Fish2eat88, Nov 1, 2018.
  1. Nov 1, 2018 at 1:44 AM
    Fish2eat88
    Fish2eat88 [OP] New Member
    Jay
    2018 silver sky TrD offroad double cab
    Wondering if anyone has out 34’s or 35’s on the offroad rim? Most likely gonna do a 3” front 2” back to get some rake. I really like the stock look so I really wanna keep the stock rims. Any1 has run bigger tires with them? Thanks in advance.
    Sunnier likes this.
  2. Nov 1, 2018 at 5:29 AM
    15whtrd
    15whtrd I tried being reasonable, but I didn't like it.
    White 2015 Tundra DC SR5 TRD 4x4 5.7L
    TRD Pro suspension, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate.
  3. Nov 1, 2018 at 6:02 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Auburn Pro LSD, Sprint booster, ICM step rails, CB TRD PRO kit, 285/70/18 Nitto Ridge Grapplers, K&N Air charger CAI, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    TRD PRO wheel with 285/70/18 which is 34”/11.5”
  4. Nov 1, 2018 at 7:41 AM
    shockinyall
    shockinyall Hillbilly
    West Virginia
    2017 TRDOR CM
    In Queue...
    285/75R18 which comes out to a 34.8" x 11.2" thereabouts.
    Sunnier, My14Tundrs, 15whtrd and 2 others like this.
  5. Nov 1, 2018 at 8:34 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    Looks great, what lift and any wheel spacers?
    jewsNbrews likes this.
  6. Nov 1, 2018 at 9:54 AM
    shockinyall
    West Virginia
    2017 TRDOR CM
    In Queue...
    Thanks. Its the 3/1 Toytec-Eibach Pro Truck with stock wheels and no spacers. I removed front mud flaps to clear, but it rubs on the front plastic when in reverse/full lock just a little bit, not enough to bother me. No issues with cab mount. I don't do heavy offroad, just old logging roads getting to cabins, but if you really flexed you would be rubbing somewhere. About a 1/4 clearance on stock UCA's.
  7. Nov 1, 2018 at 9:54 AM
    Watt maker
    Watt maker Keepin' the lights on!
    Ronald
    2017 TRD Pro Tundra DC Cement
    1 of 255
    Stock TRD Pro with +2 CB rear shackles, no wheel spacers, 295/70/18 Ridge Grapplers
  8. Nov 1, 2018 at 9:59 AM
    Squig
    Squig New Member
    South-Western ON, Canada
    2018 Black Tundra SR5
    Looks amazing
    Watt maker likes this.
  9. Nov 1, 2018 at 9:59 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    Sweet truck, what mods did you do to stop rubbing in the front. I also have the CB+2 shackles. I also have the 1” shim up front. I run the spridertrax 1.25” spacers.
  10. Nov 1, 2018 at 9:59 AM
    Watt maker
    Ronald
    1 of 255
    Thanks!
  11. Nov 1, 2018 at 10:01 AM
    Watt maker
    Ronald
    1 of 255
    No rubbing anywhere but I took the small flap in front of the tires off as a precaution.
  12. Nov 1, 2018 at 10:05 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    Cool, thanks.
  13. Nov 1, 2018 at 10:06 AM
    15whtrd
    Man, that looks real nice! You got me rethinking the 275 70s I was gonna go for.
  14. Nov 1, 2018 at 10:19 AM
    Watt maker
    Ronald
    1 of 255
    Thanks! If I were to do it over, I'd go with the 285/70/18's as they are 10 lbs lighter per tire but still a load range E tire but these 295's sure look good.
    Muleycrazy13 and 15whtrd like this.
  15. Nov 1, 2018 at 10:32 AM
    15whtrd
    $322 a tire! Holy crap. It looks like Nitto is the only one to make that size?
  16. Nov 1, 2018 at 10:34 AM
    15whtrd
    I guess looking again that is only $11 more per tire compared to the 295s.
    Sunnier likes this.
  17. Nov 1, 2018 at 10:45 AM
    Watt maker
    Ronald
    1 of 255
    Yeah and they're proud of it as well! The Discount Tire I deal with was going to give them to me for the same price as the 295's but they were on back order and didn't know when they would arrive. They had the 295's in stock so I went with those. On the plus side, if I damage a tire, 295's are easier to find.
    Sunnier and 15whtrd like this.
  18. Nov 8, 2018 at 9:06 AM
    Fish2eat88
    Jay
    Looks awesome. So the +2 shackles gave you how much rAke? The pictures makes you look leveled
  19. Nov 8, 2018 at 9:20 AM
    Watt maker
    Ronald
    1 of 255
    It’s about an 1-1.5” taller in the rear depending on fuel level. It looked like it was sagging all the time when it was stock. It levels out nice with a load now.
  20. Nov 8, 2018 at 9:43 AM
    AlexWV
    AlexWV Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    I have 35x12.5s on my TRD offroads. 3/1 lift with wheel spacers.94DABEE1-B86C-4681-B126-210AF041D0BC.jpgIMG_2926.jpg
  21. Nov 8, 2018 at 9:56 AM
    Pit_goral
    Pit_goral New Member
    Piotr
    Chicago & Greeley
    17 Tundra Limited TRD OFF ROAD
  22. Nov 8, 2018 at 11:44 AM
    parker44
    parker44 New Member
    Keith
    Columbia, South Carolina
    2008 Tundra - Desert Sand Mica
    Toyo makes their MT in this size as well, and you need to rob a bank to buy them. I looked at them years ago and they were almost $400 per tire!
    15whtrd likes this.
  23. Nov 8, 2018 at 12:00 PM
    15whtrd
    Fuk that!
  24. Nov 8, 2018 at 5:57 PM
    Watt maker
    Ronald
    1 of 255
    Great choice of tire and size! You’re going to love them! :thumbsup:
    Prostar 190 likes this.
  25. Nov 8, 2018 at 6:12 PM
    Rica25
    Rica25 Got Bam?
    2008 Super White Tundra
  26. Nov 10, 2018 at 9:48 AM
    Dust
    Dust Wow, It's Big!
    Riverton, NJ
    14 Barcelona Red Metalic Limited CrewMax 4x4
    It’s recommended that 35”x 12.5” should be ran on a 9” wide rim at minimum. An 8” wide or less rim will cause the center of the tire to wear faster than the edge due to the rim narrower width causing the center of the tire to ballon in the center. Yes I speak from experience from running 285/70 on my Tacoma with factory TRD Baja rims (16”x 7.5 same deal, rim too narrow). Tires were screwed in a year and a half. Tire shop told me but didn’t listen. Just my .02
    Sunnier and Fish2eat88 [OP] like this.
  27. Nov 10, 2018 at 12:59 PM
    Fish2eat88
    Jay
    Looks like i need to just run the 33’s on the oem and get new rims for 35’s
  28. Nov 10, 2018 at 6:33 PM
    15Yota
    15Yota New Member
    Brandon
    Madison, MS
    2015 Black TRD 4x4
    3” Fatbob Coilovers, Maxtrac shackles, Ranch hands front and rear
    3” front, ~1.5” rear
    SPC UCAs, this tire size will not clear if you have these UCAs.
    285/75/18 (35x11.00)
  29. Nov 10, 2018 at 6:45 PM
    Fish2eat88
    Jay
    BMC?
  30. Nov 10, 2018 at 6:48 PM
    15Yota
    15Yota New Member
    Brandon
    Madison, MS
    2015 Black TRD 4x4
    No chop, it clears lock to lock
