33x12.5x18 on TRD Pro
Discussion in 'Wheels & Tires' started by nolaTRDpro, Jul 28, 2016.
  1. Jul 28, 2016 at 11:39 AM
    nolaTRDpro
    nolaTRDpro [OP] New Member
    2015 White TRD Pro
    Can I fit 33x12.5x18 tires on my stock TRD Pro without any issues? Looking to change the rims too. Looking at the Fuel Vector.
  2. Jul 28, 2016 at 1:15 PM
    Law323
    Law323 Shhhhh....Boardude is really Batman.....
    Law
    Tennessee
    2012 4.6 L MGM DC
    Toytec BOSS suspension lift @ 3" (front) Toytec BOSS remote resi's (back) 1" Toytec block (rear) 275/70r18 Toyo AT2 Info system mod 3D MAXpider Kagu floor mats LED interior lights 50% ceramic tint front windows 35% ceramic tint windshield brow Bed mounted YETI bottle opener Paracord wrapped oh Sh!t bars 3" stubby antennae Upcoming: LED backup lights/cargo lights OEM Backup camera Method Standard 18x9 wheels Iron Cross Patriot step bars TRD sway bar Trifold or roll up tonneau cover
    On TRD pro wheels, you'd need a 1.25" spacer
    Depends on what offset the vectors are
  3. Jul 28, 2016 at 1:27 PM
    nolaTRDpro
    2015 White TRD Pro
    Alright, I don't know the offset of the vectors. I'm not on the up and up about offsets.
  4. Jul 28, 2016 at 2:07 PM
    Law323
    Law
    Tennessee
    2012 4.6 L MGM DC
    Looks like vectors are 1 offset. That means they're 1mm near dead center. Looking at your rims (assuming they're +60 offset) which is the standard for stock tundras, but not sure about TRD pro. Let's say +50 to be safe. The vectors would be sticking out 2 more inches (converting offset mm to inches. 50-1=49. 49 mm = 1.9 inches) at that offset, you'd most likely have to do a CMC (cab mount chop).
    Then again, I'm not an expert, I'm sure someone will chime in that's more knowledgeable than I am.
  5. Jul 28, 2016 at 4:32 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    You will be fine with 33's on the pro without any modifications. It's basically a 2" lift. I'm only at 2.5" of lift have +20 offset wheels and run 35's. I did have to do the cmc but you will be fine with 33's.
  6. Jul 28, 2016 at 4:46 PM
    Law323
    Law
    Tennessee
    2012 4.6 L MGM DC
    On 12.5 of width on 1 offset even with 33's? Not sure about that. Could be wrong though.
    20-35 offset is the sweet spot for tundras that much I do know.
  7. Jul 28, 2016 at 4:54 PM
    chphilo
    chphilo Tundra addict
    Western PA
    It seems that Vector also comes in 20 mm offset as well. I would definitely opt for 20 mm.
  8. Jul 28, 2016 at 4:57 PM
    TheBeast El CreepO
    I run 33 x12.5x 18 with leveling kit in front and stock TRD suspension but I have aftermarket wheels with +18. No rubbing issues.
    Virgils12 likes this.
  9. Jul 28, 2016 at 5:02 PM
    Virgils12
    With either one of those offsets he will be fine with 33's. I just looked and my offset is +12 offset I believe and it's to much. Stay in the +18 ta +35 range. I could have went with a 34" tire with my wheels and not had to do the cmc. He will be good...
  10. Jul 28, 2016 at 5:16 PM
    nolaTRDpro
    2015 White TRD Pro
    So 33x12.5x18 with a 20mm offset is what I'm looking for? And if I want to slap 35's on there I would have to put a leveling kit? I just read about offsets so I kind of get it now.
  11. Jul 28, 2016 at 5:19 PM
    Virgils12
    If you want to go 35's you could probably do 1 or 2 coachbuilder shims per side and the cmc and be good.
  12. Jul 28, 2016 at 5:29 PM
    chphilo
    Western PA
    I think Law is right. I have 3.5 inch lift with 34.5 inch tire. My tires are more than 1/2 inches narrower than the tires you are trying to install. My tires at full lock is only a few mm away from the body mount, so my guess is that he will have to cut the body mount even if opts for 20 mm offset. Some people don't mind, but I personally do not want to chop the body mount.
  13. Jul 28, 2016 at 5:36 PM
    nolaTRDpro
    2015 White TRD Pro
    Yeah definitely don't want to cut anything.
  14. Jul 28, 2016 at 5:39 PM
    Law323
    Law
    Tennessee
    2012 4.6 L MGM DC
    If do some more research before making the final decision then. Or at the very least get a different offset or opt for narrower tires.
  15. Jul 28, 2016 at 5:41 PM
    nolaTRDpro
    2015 White TRD Pro
    Yeah for sure, sounds like a plan. Thanks bro.
    Law323 likes this.
  16. Jul 28, 2016 at 5:41 PM
    Law323
    Law
    Tennessee
    2012 4.6 L MGM DC
    This is true but I do remember reading somewhere that the wheel well on the 3rd gen is about an inch smaller than the 2nd gens. Or is it just my imagination?
  17. Jul 28, 2016 at 5:45 PM
    Law323
    Law
    Tennessee
    2012 4.6 L MGM DC
    Had to do the same when I got my tires. Wanted 295/70r18 but couldn't swing the wheels just yet. So opted for a 275/70 on stockies until I could get the wheels I wanted, to avoid UCA rub. Some guys said it was fine, but i wanted to be safer than sorry.
    Hey, another thing you could try if you're not ordering tires online is some shops will do a test fit for you if you buy your tires from them. May be an option
  18. Jul 31, 2016 at 9:18 PM
    nolaTRDpro
    2015 White TRD Pro
    So you think I wouldn't have to do any modifications if I just go with the 295/70/18 with those vector wheels?
  19. Aug 1, 2016 at 6:14 AM
    Law323
    Law
    Tennessee
    2012 4.6 L MGM DC
    If it were me, I would get the wheels you like, then go to a local tire shop you trust, ask for a test fit and go from there.
  20. Aug 1, 2016 at 12:49 PM
    nolaTRDpro
    2015 White TRD Pro
    Sounds like a damn good plan to me
    Law323 likes this.
  21. Aug 1, 2016 at 1:14 PM
    Law323
    Law
    Tennessee
    2012 4.6 L MGM DC
    Let us know how it goes and the final result brother!!
  22. Aug 1, 2016 at 1:33 PM
    TheBeast El CreepO
