33" tires with a level kit only
Discussion in 'Suspension' started by sboster9, Oct 31, 2020.
  1. Oct 31, 2020 at 10:08 AM
    sboster9
    sboster9 [OP] New Member
    Hello team just wanted to know if anyone has a tundra with 33's and only a level kit? I am trying to stay within budget. Also what mud tire would you recommend that is also good on the highway? Its 2020 Limited
  2. Oct 31, 2020 at 10:10 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    I have this exact set up. 2.5” level via Bilstein 6112s and a couple of shims and running 275/70R18 Falken Wildpeak. I really like it.
    Chucho, Sapper406, Pbed85 and 3 others like this.
  3. Oct 31, 2020 at 10:22 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    There are no mud tires good on the hwy. Some all terrain tires are Good on the hwy. The Cooper XLT Discoverer AT3 XLT are good.
    Many run Toyota, Nitro, or BG Goodrich AT's with good results.
    Txexplorer23 and BravoDeltaRomeo like this.
  4. Oct 31, 2020 at 12:57 PM
    sboster9
    Thank you both very much. I’ll be purchasing on Black Friday and will post some before and afters. Thanks again
  5. Oct 31, 2020 at 1:05 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    They'll fit fine, although you have to trim the skid plate a little. I get rub on mine when turning sharp. I have 275/70R18 Duratracs. A mud terrain that's good on the highway is an oxymoron.
    Txexplorer23 and Chucho like this.
  6. Nov 3, 2020 at 2:54 AM
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    I am running the same, except the 1.9" setting on the 6112s. Same 275/70r18 Falken tires. No clearance issues. Tires are appropriately sized for the lift/level.
  7. Nov 3, 2020 at 6:31 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, 6112/5160, MR 701's, TOYO R/T Trails 285/75/17
    I have the 6112s staggered but its level and running Mickey Thompson ATZ 295/70r17- Looks pretty good- almost as if it should come stock like that.
  8. Nov 3, 2020 at 6:56 AM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    I have 285/70r17 (32.7”) on stock suspension with no issues at all.
  9. Nov 3, 2020 at 7:04 AM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Leveled via Bilstein 5100s. Tires are Falken Wildpeak AT3W size 275/60R20 ( 33x11 ). These are my favorite all around tires and get great reviews from others as well
    Shuffler likes this.
  10. Nov 3, 2020 at 7:49 AM
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I ran 275/70R18 (33.2" nominal) on my 2008 with factory TRD offroad suspension without any lift or level kit. With the Goodyear Wrangler Duratracs, I had to tweak the thin sheetmetal skid plate just a tad because the side lugs on those stick out a bit and would rub at full lock in a right-hand turn, but it wasn't any more than bending about 1/2" on the front edges of the plate.
    That was a LOT of miles and a LOT of sets of tires ago. At around 150k, I finally put a 3/1 level kit on it and then moved up to 305/65R18 (33.6" nominal) but had issues with the ABS system to eventually went back to 275/70R18. The issues were likely caused more by the width of that tire on the stock rims, but I didn't want to spend the $$ on new rims.
  11. Nov 3, 2020 at 8:18 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I'm running 33x12.50x18 on +12 offset, no lift, no rubbing, 202 trd sport
    68 RS/SS likes this.
  12. Nov 3, 2020 at 1:08 PM
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    King's all around, Magnaflow exhaust, 18x9 Method 305 NV, Falken Wildpeak A/T3W 305/65/18 tires, tinted windows (shhhhh)
    I have a set of Bilstein 5100's for the rear that I had on my 2020 Tundra for 1,000 miles I am selling for $100. Any shipping negotiable.
  13. Nov 26, 2020 at 12:03 PM
    TP143
    TP143 New Member
    What setting are your struts set at?
  14. Nov 26, 2020 at 12:14 PM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Middle setting (1.57")
    TP143[QUOTED] likes this.
  15. Nov 29, 2020 at 10:13 PM
    Chucho
    Chucho New Member
    Rob
    Salem, OR
    2017 MGM DC Tundra SR5 TRD 4X4
    Tuff Country 2" Level spacer Kit up front Paired with KYB Mono Max shocks all around. Roadmaster Active Suspension HD kit 1mm gap 275/70R18 Falken Wildpeak A/T3W mounted on some MB352 18X9 + 25 Cobra 19DXIV CB radio.
    Nice looking truck! Did you do anything to the rear suspension?
  16. Nov 30, 2020 at 3:03 AM
    glowblue
    VA
    Thanks! I’m happy with it. I put on Toytec shackles at 1.5” and Bilstein 5100 shocks. The rake is 1” exactly which I like so it doesn’t squat when loaded down. A lot of folks say the Pros squat when loaded in the back or towing.
  17. Nov 30, 2020 at 6:24 AM
    Kanobi13
    Kanobi13 New Member
