30K Miles
Discussion in '2.5 Gen Tundras (2014-2021)' started by ealxele, Oct 15, 2021.
  1. Oct 15, 2021 at 6:34 AM
    ealxele
    ealxele [OP] New Member
    Hi All,
    Just getting the 30K mile service at the dealership and was wondering if it is recommended to swap out the:
    1. Fuel induction service
    2. TB service - injector
    3. Brake fluid service
    Much appreciated!
  2. Oct 15, 2021 at 6:39 AM
    Taco-Spike
    Two Trucks
    The MAFS and Throttle body could probably DIY with $20 worth of cleaner and about 20 minutes of your time. injector cleaner, I just drop in a bottle in an empty tank and fill in 10-15 gallons and drive to empty then fill full - I do about 40k +/-
    Edit for the MAFS and TB - I can get a few cleanings done out of the bottles
    Brake fluid seems a little soon but could probably let them do it if you don't want to mess with a full fluid flush ~ if that's what they're doing
  3. Oct 15, 2021 at 6:47 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    Classic dealership scam. They'll probably charge you $100 for the first 2 items, each! Brake fluid is important though, and I'd clarify if they're flushing or bleeding. To me, a flush means all fresh fluid throughout the system, vs a bleed which is removing any air (if found) from the lines.
    So in the bleed scenario, are they just cracking the bleeder and checking for air for 2 seconds before closing the valve again? That's not worth the $150 or whatever they'll charge.
  4. Oct 15, 2021 at 6:58 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    no on all of that. Oil change, fluid changes for diffs, xfer case, trans- all drain and fill no flush. Then the usual checks for anything that needs attention and roll on!
    batman900 and ealxele[OP] like this.
  5. Oct 15, 2021 at 8:39 PM
    ealxele
    Gotcha thank you so much for the info!
    Taco-Spike[QUOTED] likes this.
  6. Oct 15, 2021 at 8:39 PM
    ealxele
    Glad I asked lol, it was like $145 for each!
  7. Oct 15, 2021 at 8:40 PM
    ealxele
    Thanks!
