305 Gallon Fuel Tank Mod
Discussion in 'General Tundra Discussion' started by Professional Hand Model, Jan 17, 2019.
  1. Jan 17, 2019 at 1:59 PM
    Professional Hand Model [OP] A.K.A ‘Golden Hands’
    Hand Protectors
    Hey guys. Thinking about doing this mod as it will save room under the chasis. Should I install a transfer relay? Will it work? Thoughts...
  2. Jan 17, 2019 at 2:07 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
  3. Jan 17, 2019 at 2:13 PM
    15whtrd
    15whtrd Mr. Blonde
    Shouldn’t be a problem.
  4. Jan 17, 2019 at 2:17 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Where do you park? :spy:
    Y0TA PR0, kgb4187, MS22 and 11 others like this.
  5. Jan 17, 2019 at 2:24 PM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    Are you planning on doing in flight highway fuel transfers? You will have the market cornered. LOL
  6. Jan 17, 2019 at 3:46 PM
    Hand Protectors
    I saw one of these little gas cap locker thingys that would prevent theft like this. Not sure if it will fit though. Maybe need a capless lock?
  7. Jan 17, 2019 at 3:48 PM
    Hand Protectors
    How much payload will I lose and do I need bed stiffeners?
    TRDFerguson, TheBeast and OBXTundra like this.
  8. Jan 17, 2019 at 3:57 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    You will exceed your payload rating (check payload on B pillar). Gasoline weighs about 6.3 lbs per gallon = 1922 lbs. A load like this will also negatively affect the handling; higher center of gravity. Having said all that, have you considered any DOT regulations? That much flammable liquid on board is crazy dangerous IMO. Just upgrade to a genuine Toyota 38 gallon tank and be safe.
  9. Jan 17, 2019 at 4:22 PM
    Hand Protectors
    I’d only fill it to 250 gallons to be safe.
    Haven’t check DOT, but plan on putting in a ‘breather mod’ for gas vapor build up.
  10. Jan 17, 2019 at 4:29 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Keeping it half full is way super smart. that way you can save on all the MPGs. Plus at red lights you could alternate hitting the gas and brake to get a wave going back there, and then time the take off right so it will launch you forward on green!
    :burnrubber:
    TundraLuv, Tundyfundy, JH5370 and 4 others like this.
  11. Jan 17, 2019 at 4:31 PM
    TheBeast The Beach
    but wait..can you still fit 35's ?
  12. Jan 17, 2019 at 4:33 PM
    Hand Protectors
    I like your thinking. Maybe once I save up I’ll do the ‘baffle mod’. Breaks the tank wave backlash further helping mpg.
  13. Jan 17, 2019 at 4:34 PM
    Hand Protectors
    Yep.
  14. Jan 17, 2019 at 4:34 PM
    2manytoys
    2manytoys New Member
    Lupe
    Carlsbad, New Mexico
    2017 black tundra crewmax
    Fab fours premium bumpers frt & rr, retracing bed cover, 5% window tint cept frt which is 60%, has lift from dealer maybe 3 inch
    And your mpg will drop drastically.
  15. Jan 17, 2019 at 4:35 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Totally. Plus that will make it that much safer!
    Should be tons of insurance discounts once you do that.
    Just don't tell your agent you ash your cigs out the back window. ;)
    15whtrd likes this.
  16. Jan 17, 2019 at 4:36 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I've got a 425 and a 275 at my house. Mine gets filled with maple sap though.
    tinman10101 and 15whtrd like this.
  17. Jan 17, 2019 at 4:36 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Now that's a Tundra mod worth doing!
    #SapTapMod
    15whtrd and Pudge[QUOTED] like this.
  18. Jan 17, 2019 at 4:38 PM
    Pudge
    CT
    Tank is huge. Dwarfs our old Sappin wagon 1500 W/T even with an 8 foot bed.
  19. Jan 17, 2019 at 4:39 PM
    Hand Protectors
    What leaf packs are you running? Syrup seems heavier that gas. You running heater packs to help with those large pancake pours?
    Squatting Pigeon likes this.
  20. Jan 17, 2019 at 4:45 PM
    Pudge
    CT
    Nope just the stock lead pack. Ran that 425 for one season and have since swapped the truck tank to the 250 and we use the 425 at the sugar shack for storage. Sap weight just slightly more than water. About 8.2 lbs/gallon so its still quite a load for the Chevy but it does ok. Some day I may upgrade or add some super bumps
  21. Jan 17, 2019 at 5:18 PM
    MGM
    MGM New Member
    Do it for the culture.
  22. Dec 9, 2019 at 5:27 AM
    TacomaLC
    TacomaLC New Member
    Chip
    T-town
    2020 Tundra Voodoo 2000 Tundra LTD Red (rest in pieces)
    Just put fertilizer stickers on it.....or better yet hazardous medical waste collection stickers
  23. Dec 9, 2019 at 6:05 AM
    TacomaTundra
    TacomaTundra New Member
    Don
    Charlotte, NC
    2014 Black Toyota Tundra Limited Crewmax
    This is not a good idea.
  24. Dec 9, 2019 at 6:13 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    He's actually been running it most of the year with pretty good results. His MPG actually went up to a shocking 25.379. And he had enough room under the truck to carry an additional 35" tire. He's been pulled over a few times but each time he's managed to beat the charges in court. He represented himself too.
    Pudge, GODZILLA and triharder like this.
  25. Dec 9, 2019 at 9:38 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    You get into a wreck and we will be able to see the fireball from any one of our Google Earth satellites.
    Just sayin...
    TacomaTundra and Trooper2 like this.
  26. Dec 9, 2019 at 9:47 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I gotta hand it to PHM, he’s a pretty handy guy. I think he’s got a handle on this one.
    Fireballs? Bad idea? Get a grip.
    :D
    GODZILLA, Baja Mike and Wrongside like this.
  27. Dec 9, 2019 at 8:26 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I think you need this. Juice caboose if you will...
    GODZILLA and TXMiamiFan like this.
  28. Dec 9, 2019 at 8:31 PM
    Aerindel
    Aerindel New Member
    Montana
    I've thought of this myself a lot in preparation for the boogaloo but I'm modifying old hot water heaters, which you can get for free and are pretty tough metal compared to 55 gallon drums or plastic tanks.
    I do like those tanks though, I have a 550 gallon one under my kitchen for backup water supply. Brought it home in the back of my 93 toyota, empty of course but I bet made my truck look amazing to the people who thought it was full.
    kenomouth64 likes this.
  29. Dec 9, 2019 at 8:36 PM
    Blueknights75
    Ron
    Clayton, NC
    What happens when you can only pump 295 gallons and your full? Does the extra 10 gallons still get utilized to cool the fuel pump?
    :anonymous:
  30. Dec 9, 2019 at 10:05 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    At 0.73mpg this mod should boost your tundras range to around 237.5 miles. Less for the 5.7. Lol
    GODZILLA and Trooper2 like this.
