305/65R18 issues with 2019 TRD Pro suspension?
Discussion in 'Wheels & Tires' started by Frestyl06, Apr 30, 2019.
  1. Apr 30, 2019 at 9:19 PM
    Frestyl06
    Frestyl06 [OP] New Member
    2019 trd pro
    Hey friends. Just sold my 2012 Toyota Tundra rock warrior on Saturday. And picked myself up a 2019 tundra trd pro. Does anyone know if the 305/65r18 in either Nitto Ridge Grappler or BFg ko2s have any rubbing or fitment issues. Can’t really find info for the new pro suspension. Thanks in advance
  2. Apr 30, 2019 at 9:25 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    WELCOME!
  3. Apr 30, 2019 at 9:28 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Welcome from San Diego. As far as I know, the new Fox set-up is basically the same as the Bilstein set-up as far as clearance goes. Maybe look for info on that set-up with the prior Pros?
    15whtrd likes this.
  4. Apr 30, 2019 at 10:09 PM
    proROB
    proROB New Member
    Robert
    Temecula, Ca.
    2017 Tundra TRD PRO
    305/65 needs at least an 8.5” rim, the stock rim is 18x8, so that won’t work
  5. May 1, 2019 at 12:31 PM
    Frestyl06
    2019 trd pro
    Would you say you need the shackles in the back to make those tires work?
  6. May 1, 2019 at 12:33 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
  7. May 1, 2019 at 12:36 PM
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I run these on 18x9 methods w a +25 offset and needed to trim a little in the wells both in front and behind the tires.
    Not sure what wheels you are planning to use but I linked a vid of a guy clearing the stock uca with stock rims
  8. May 18, 2019 at 7:03 PM
    jagged155
    jagged155 New Member
    2018 Platinum Pro
    Considering this setup. Does it ride better with the shackles or do you just like the extra rake?
  9. May 19, 2019 at 6:15 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Yes it rides better with shackles and forward rake keeps it from bulldogging when you put something in the bed. in addition helps traction control according to Dave
    Watt maker likes this.
  10. Jun 4, 2019 at 5:18 AM
    Belated welcome from NY.
  11. Jun 11, 2019 at 10:31 AM
    BDavis3
    BDavis3 New Member
    2019 Tundra TRD Pro
    None
    Frestl06 what did you decide? I have the same question. 2019 TRD PRO with no mods and don’t want any for now except bigger tires, looking at the BFG KOs also in 305 65 18. I’ve read where they do not rub on the 2017s but can’t find anything on a 2019 .
  12. Jun 16, 2019 at 5:20 PM
    TRDPROSean
    TRDPROSean New Member
    Hattiesburg, MS
    2017 CM TRD PRO
    275/70r18 Nitto Ridge Grapplers, TRD rear bar and intake, Coachbuilder +2 shackles, Corsa 14916 exhaust, UWS lo pro toolbox, Craven Speed stubby, tint
    They are the same truck. The Fox branded shocks will not cause clearance issues.
  13. Jun 16, 2019 at 5:43 PM
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    295/70r18 is the biggest you can fit without rubbing. You will have to remove the front mud flaps.
    TRDPROSean likes this.
  14. Oct 25, 2019 at 12:13 PM
    Spakylpm
    Spakylpm New Member
    2020 Tundra
    305/65r18 is the tire ran on my Pro no rubbing at all. It was a good fit for the truck!
    xuy likes this.
  15. Oct 25, 2019 at 1:37 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    305/65 is quite a bit shorter despite being 10mm wider
  16. Dec 19, 2021 at 7:33 AM
    xuy
    xuy New Member
    2021 TRD PRO Super White
    That's what I have also. But clearance between the rubber and UCA is definitely less than 1 inch. I could barely stick my hands in between. But this is perfect for me. I never worry about it. And I'm keeping everything stock for now.
