2nd Gen to 3rd Gen Conversion
Discussion in 'General Tundra Discussion' started by martinjrherrera, Apr 4, 2019.
  1. Apr 4, 2019 at 7:12 PM
    martinjrherrera
    martinjrherrera [OP] New Member
    martin
    2008 Toyota Tundra SR5
    Hey Guys,
    So I decided to keep my tundra after the insurance deemed it a total loss.It is a SR5 2008 with 120,000 miles on. I'm going to be rebuilding the front end and posting pictures from tear down to rebuild. I have read a few forums but I have not seen a step by step and part by part list required to do so. A few have shown part numbers or YouTube videos. I will be using my GoPro to film the transformation. I'll keep you guys posted. Any recommendations from someone who has gone through this process??
    Filthyphil, Berdine, Trooper2 and 4 others like this.
  2. Apr 4, 2019 at 7:17 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    @Roman can probably help with the parts list.
  3. Apr 4, 2019 at 7:19 PM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
  4. Apr 4, 2019 at 8:45 PM
    08crewmax
    08crewmax New Member
    CA
    ‘08 Pyrite Mica Crewmax Limited
    I’d subscribe to that build
  5. Apr 12, 2019 at 7:28 PM
    martinjrherrera
    martin
    parts have came in for 3rd gen upgrade I am working on body work and some mechanical repairs like replacing water pump and a/c liquid line that got busted...removed front assembly and need to put new one on then mounting new radiator and condenser lots of work to come but I'm excited
    Filthyphil, Rica25, Ostrich and 3 others like this.
  6. Apr 13, 2019 at 11:14 AM
    martinjrherrera
    martin
    I'm about ready to put this back on. Just need to put on the cab mount
  7. Apr 13, 2019 at 12:00 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    :popcorn:Nice work.
    CaptSpaulding likes this.
  8. Apr 13, 2019 at 12:03 PM
    timsp8
    NY
  9. Apr 13, 2019 at 12:22 PM
    martinjrherrera
    martin
    Got the cab mount welded on!
  10. Apr 13, 2019 at 12:28 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
  11. Apr 13, 2019 at 12:29 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I know you said you got parts already but...
  12. Apr 13, 2019 at 1:34 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Nice build. I’ll be watching. Where you located?
    Mountun Goat likes this.
  13. Apr 13, 2019 at 6:00 PM
    martinjrherrera
    martin
    Houston, Tx
    Jrharvey02 likes this.
  14. Apr 13, 2019 at 6:16 PM
    martinjrherrera
    martin
    it's coming along, there are some slight modifications for fenders I need to do and the hood latch is different from gen 2 models
  15. Apr 13, 2019 at 6:21 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Good job
  16. Apr 16, 2019 at 5:37 PM
    martinjrherrera
    martin
    Ran a new liquid A/C line due to collision busting my old one and waiting on new lock for hood since 2nd gen is different and one bracket for the support I ordered. Overall it's coming along good just making adjustments. Trd pro headlights dont hook up to 2nd gen I'm going to need a harness.
  17. Apr 16, 2019 at 6:35 PM
    martinjrherrera
    martin
    Do I still need the transmission cooler? The new a/c condenser looks different and as if the trans lines can hook direct to condenser??
  18. Apr 17, 2019 at 1:02 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
  19. Apr 17, 2019 at 1:03 AM
    Berdine
    Binghamton, NY
    Great job soo far. I was planning this for the wife's sequoia this summer
  20. Apr 17, 2019 at 2:42 AM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Nice job. Are you planning on doing the bed side skins as well?
  21. Apr 17, 2019 at 3:26 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
  22. Apr 17, 2019 at 6:48 AM
    martinjrherrera
    martin
    not sure yet about doing the bed skin and tailgate possibly, does anyone know the answer to the transmission cooler? seems like the a/c condenser has direct hook ups for trans lines. can I remove the old transmission cooler and hook lines direct to condenser?!?
  23. Apr 17, 2019 at 8:21 AM
    Jrharvey02
    I think you’re not getting any answers because nobody has any experience with this...kinda expected when you’re doing something only a handful of people have ever done...good luck, I’d try calling the manufacturer...
  24. Apr 17, 2019 at 10:03 AM
    timsp8
    NY
    The trans cooler style changed mid 10. You can run both in parallel or take yours out and use just the one in the ac condenser. I’d try to run both for extra cooling. Can buy trans lines at an auto store to run both.
  25. Apr 17, 2019 at 1:52 PM
    martinjrherrera
    martin
    thanks man I end up doing direct since the 4th gen TRD PRO Grill only fits with the trans cooler removed
  26. Apr 17, 2019 at 6:26 PM
    martinjrherrera
    martin
    Almost there put in new radiator,a/c condenser/a/c line, water pump, and belt ran for 1hr and drove like new no leaks. Just need this damn wire harness and wiring figured out for new 2018 TRD PRO Headlights
  27. Apr 17, 2019 at 6:31 PM
    TheBeast The Beach
    nice ! couple guys done it here. hopefully they chime in. @xrunnerdude67 makes a harness for gen 2 to fit 2018-19 sequoias LEDs, maybe he will know more as far as harness.
  28. Apr 17, 2019 at 9:01 PM
    G10dra
    G10dra Not a New Member
  29. May 8, 2019 at 5:48 AM
    martinjrherrera
    martin
    Finally got everything painted and bolted on. I really like the way it came out. Paint was done In garage took alot of work two days. Now i just have to wait on DMV to send me back rebuilt salvage title and take for inspection.
  30. Dec 4, 2019 at 12:46 PM
    minter66
    minter66 2007 TSS CrewMax
    Wow that's looking good. That first photo hits hard home as my truck looks almost identical. Same front grills inserts and same color. Glad you brought it back my man.
