2nd Gen headlight adjustment help
Discussion in 'Lighting' started by CM-LENNY, Jul 2, 2017.
  1. Jul 2, 2017 at 8:26 PM
    CM-LENNY
    CM-LENNY [OP] No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    We are going to be installing Bilstein 5100's on my brother in laws 2008 Tundra CM. It does not have the dash control headlight levelers like the newer trucks do. I searched around some and need to know the screw or knob location for the headlight adjustment after lift. Thanks in advance.
    landphil likes this.
  2. Jul 3, 2017 at 8:55 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
  3. Jul 3, 2017 at 9:17 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Here is a picture of the driver side headlight. One inside the red circle is the side-to-side adjuster and one his 'middle' finger is pointing to is the up-and-down adjuster. (If you try to adjust the driver side headlight without first taking the battery out, you may understand what that middle finger may mean, haha)
    TheBeast and Black Wolf like this.
  4. Jul 3, 2017 at 9:34 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Well said^^^^
  5. Jul 3, 2017 at 11:01 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    If you use a long shank Philips #2 screwdriver straight down the groove to the adjuster as it was intended to be used, you won't feel the need to deploy your middle finger(s) at all. As shown in @bobeast 's link.
  6. Jul 3, 2017 at 11:47 AM
    chphilo
    Western PA
    A man with proper tools! :thumbsup: You are correct. I did it with normal screwdriver and I will never attempt this without taking the battery out (or getting the proper tool). :D
  7. Jul 3, 2017 at 3:43 PM
    CM-LENNY
    San Diego, CA
    Wow guys..........Thanks for the replies. That's why this forum is the bomb. Just ask and you get an answer instantly.....:thumbsup:
  8. Jul 3, 2017 at 3:47 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    You'd be one of the few to think of this with installing a lift / leveling kit. And for that, and on behalf of all those that don't get blinded, and don't know they would have been otherwise, I thank you.:thumbsup:
    bobeast and CM-LENNY[QUOTED][OP] like this.
