295/70 R18 Trail Grapplers hitting UCA
Discussion in 'Wheels & Tires' started by Dbello70, Jun 1, 2018.
  1. Jun 1, 2018 at 3:44 PM
    Dbello70
    Dbello70 [OP] New Member
    David
    2015 Tundra TED 2WD
    Readylift 3/1
    Hello everyone. I am new to this forum so please go easy on me. I have a 2015 Tundra TRD 2WD. I recently installed a Readylift 3/1. I wanted to keep the stock 18 inch rims but put new 295/70r18 Nitto Trail Grapplers on. All the research I did on this site and other forums stated I would not have a problem installing 295/70/18 tires on stock 18 inch rims with a 3/1 lift level, but when I went to install the 295/70 r18 Trail Grapplers on the front, the wheels would not fit because the tire was hitting the Upper Control Arm. Again, all my research led me to believe a could put a 295/70 r18 on with no modification so i was shocked to find the UCA was preventing the wheel from being put on.
    So, here I am. Did I possibly do something wrong in during the 3 inch spacer install? The truck was running great with the Readylift install and wheel alignment.
    What are my options now? Do I need spacers on? If yes, how big? Were all the posts stating 295/70 R18s Trail Grapplers on stock 18 inch rims with a 3inch lift would fit with no modifications? I do not want to buy new rims at this time
  2. Jun 1, 2018 at 4:56 PM
    Watt maker
    Watt maker Keepin' the lights on!
    Ronald
    NM
    2017 TRD Pro Tundra DC Cement
    1 of 255
    You have a few options. The side lugs on the Trail Grapplers are big which makes the tire actually wider than other tires in the same size, which makes them more likely to rub on suspension components. You could choose a different tire, run spacers, or different wheels.
    FWIW, I’m running 295/70/18 Ridge Grapplers on stock wheels, no spacers. I have about 3/8”-1/2” clearance from the UCA.
    zcarpenter92 and 831Tun like this.
  3. Jun 1, 2018 at 5:06 PM
    Dbello70
    David
    2015 Tundra TED 2WD
    Readylift 3/1
    No spacers? Is your truck lifted? I'm thinking my 3 inch lift dropped the UCA too much. Looms like spacers for me. Thank you.
  4. Jun 1, 2018 at 5:47 PM
    Watt maker
    Ronald
    NM
    1 of 255
    Factory TRD Pro suspension, so roughly 2” lift.
    Stroke250, Dbello70 [OP] and equin like this.
  5. Jun 1, 2018 at 8:22 PM
    040Tundra
    040Tundra El Chapo
    Aaron
    Las Vegas, NV
    Super white '16 CM LTD 4x4
    I have 295/70/18's trail Grapplers on a 3.5" leveling kit but I have 1.25" SpiderTrax spacers cause I like the look of the stance. Sounds like wheel spacers would be your cheapest fix. Sorry I'm not more help.
  6. Jun 1, 2018 at 8:26 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    How high was your truck on the jack? Possibility the suspension was drooped too much?
  7. Jun 1, 2018 at 8:41 PM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    TC LT w/ king 2.5 C/O and bypass, ADS bypass rear, Toytech shackles, TRD dual exhaust dumped, KM3 37s on Method standard +18. N_Fab front bumper, Westin rear w/ hitch relocate, RCI skids, Desert Eagle tranny skid, All Pro sliders, ARB dual compressor, 5.29 gears and ARB rear locker
    If you choose spacer, I ran 'em for more than year, DON'T cheap out. Bora or Spiertrax are the only ones I'd run.
    Grey Wolf and Watt maker like this.
  8. Jun 1, 2018 at 8:44 PM
    040Tundra
    040Tundra El Chapo
    Aaron
    Las Vegas, NV
    I can vouch for SpiderTrax. I've had mine on for over a year through street and 4x4'n without any problems.
    831Tun likes this.
  9. Jun 1, 2018 at 8:47 PM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    They're great 'cause they're hub and wheel centric....... I ran Spiders too....
    040Tundra likes this.
  10. Jun 1, 2018 at 8:59 PM
    040Tundra
    040Tundra El Chapo
    Aaron
    Las Vegas, NV
    Why'd you take them off?
    831Tun likes this.
  11. Jun 1, 2018 at 9:01 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2016 SR5 TRD Offroad CM
    I've run Bora on the Tundra and Spidertrax on the 4runner. No problems with either. Use red loctite and torque to spec - If you do check torque set your wrench a couple ft lbs short of torque spec, that way you don't risk breaking the loctite.
    831Tun likes this.
  12. Jun 1, 2018 at 9:07 PM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I was having trouble deciding what to do about spares and tires for the trailer. Then Discount tires direct had Methods for $160 ea. and I was finally able to decide
    Watt maker and Backslider like this.
  13. Jun 1, 2018 at 9:15 PM
    040Tundra
    040Tundra El Chapo
    Aaron
    Las Vegas, NV
    $160? What a steal! Good for you...
    831Tun likes this.
  14. Jun 1, 2018 at 9:16 PM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    But they only let me buy 4 at that price:(
  15. Jun 1, 2018 at 9:18 PM
    040Tundra
    040Tundra El Chapo
    Aaron
    Las Vegas, NV
    What did you do for the spare?
  16. Jun 1, 2018 at 9:46 PM
    TheBeast The Beach
    that was shortly after @831Tun joined tundras.com and :spending::spending:
    831Tun likes this.
  17. Jun 1, 2018 at 9:51 PM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    :rofl::rofl: Not true, the addiction took a little while to kick in to overdrive.... Pun intended.
    040Tundra and TheBeast like this.
  18. Jun 2, 2018 at 4:55 AM
    Dbello70
    David
    2015 Tundra TED 2WD
    Readylift 3/1
    I have a standard 4 ton jack. I was able to get the sway bar, struct and other bolts back in just fine.
  19. Jun 2, 2018 at 4:57 AM
    Dbello70
    David
    2015 Tundra TED 2WD
    Readylift 3/1
    Thanks everyone. I'm going with Spidertrax Spacers. I'm picking them up this morning. Not sure what to go with, the 1.25 or 1.5. Probably buy them both to see what looks better.
  20. Jun 2, 2018 at 5:21 AM
    PermaFrostTRD
    PermaFrostTRD New Member
    Northern NY
    2014 TRD Off-road DC
    Just for more info: here are some pics. Stock trd off road 2014 (suspension and wheels). 275/70 r18 BFG KO2’s. This is the clearance I have with my UCA. 1.25-1.5”
    93A69557-C4D3-479E-9441-5D78DAB4EBA4.jpg 430AADC6-DCED-44FD-9FFA-B78EF745A212.jpg 37622F33-529A-4473-8746-962A8B30D2CE.jpg
    A ½” more (from the 295) shouldn’t give much issue.
    Also, road salt is a bastard.
  21. Jun 2, 2018 at 6:40 AM
    Dbello70
    David
    2015 Tundra TED 2WD
    Readylift 3/1
    I can't figure out what's wrong. I have about the same clearance right now with 275/65 r18. Your UCA looks a like more angled up than mine. I thinking more and more something went wrong with my Readylift 3/1 installation.
  22. Jun 2, 2018 at 10:05 AM
    PermaFrostTRD
    Northern NY
    I don’t know enough about suspension / suspension geometry to tell you if that’s what is happening in your case.
    Sorry man. Maybe some other folks can chime in that know more about that sort of thing
  23. Jun 4, 2018 at 1:05 PM
    parker44
    parker44 New Member
    Keith
    Columbia, South Carolina
    2008 Tundra - Desert Sand Mica
    Even though people have fit the 295's on stock wheels, they are still close. I know my 275/70/18 were close and while the 295's should fit, every truck is slightly different. I don't think anything is wrong with your lift install, I think the main issue is the trail grapplers run a little bigger than advertised. If you were to test fit a terra grappler or something that doesn't have those big lugs on the side, you would probably fit.
    Either way, I'd pick up a set of those spacers and call it a day.
  24. Jun 6, 2018 at 6:14 PM
    Rngr188
    Rngr188 New Member
    Chad
    Harrison AR
    17 Silver Sky Limited CM 4x4 TRD
    So I've always heard bad things about wheel spacers except that Spidertrax and Bora are the best. How good are they? I don't do any heavy off reading but I want confidence because I plan on using my factory TRD OR wheels and because of that I'm limited on tire size plus this is my only vehicle. Let's say I wanted to do 295/70/18 with 6112 at 1.9 or OME 612 is that doable? Can I trust the spacers with my life so to speak?
    JoeM777 and 831Tun like this.
  25. Jun 6, 2018 at 6:28 PM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I ran Spidertrax off road and on for roughly 15k w/o any issues.
  26. Jun 7, 2018 at 5:34 AM
    Watt maker
    Ronald
    NM
    1 of 255
    I wouldn't worry about the spacers offroad, I'd worry about them on the freeway doing 80 going around the curves, especially when towing.
  27. Jun 7, 2018 at 6:20 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, 3/1 fuel wheels, nitto RGs, K&N intake
    I have a 3/1 level and 295/70/18 ridge grapplers and no issues. I do have new wheels which have a +20 offset so i think that helps with clearance.
    Watt maker likes this.
  28. Jun 7, 2018 at 7:35 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    whats your alignment look like? Camber adjustment may also help you
