295/70/18's on 3-1 level. will they fit without trimming and/or spacers?
Discussion in 'Wheels & Tires' started by clp311, Feb 28, 2019.
  1. Feb 28, 2019 at 7:04 AM
    clp311
    clp311 [OP] New Member
    2007 crew cab tundra SR5 4x4
    3-2 level kit is all that I have done on it so far.
    Hey guys,
    New to my Tundra and putting some new wheels and tires on. I have a 3-1 level on it and I am looking to get a set of 295/70/18's in the near future. I just wanted ask what all I will need to trim and if I will need spacers to pull it off.
    Thank you!
  2. Feb 28, 2019 at 7:08 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
  3. Feb 28, 2019 at 7:10 AM
    clp311
    Thanks,, I'll check it out.
  4. Feb 28, 2019 at 7:20 AM
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    3/1 "level" with 295/70r18. Wheel offset is +25 versus the stock ~60. Or roughly the equivalent of stock + 1.25" spacers.
    Removed front mudflap. I had to trim the skid plate and tuck some plastic, but that might be partially related to camburg ucas. All minor stuff though. You can easily go 35s.
    clp311[OP] and Black Wolf like this.
  5. Feb 28, 2019 at 8:09 AM
    You’ll probably def need to trim skid plate and maybe remove front mud flaps. All depends on your offset too
  6. Feb 28, 2019 at 9:07 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I'd think that size on stock wheels would have ya rubbing the UCA, but if you get aftermarket wheels with less offset, the trimming will likely be minimal. Probably just a lil off the front bumper and take off the mudflaps.
    clp311[OP] likes this.
  7. Feb 28, 2019 at 4:38 PM
    clp311
    Thanks guys, I am getting wheels at the same time and leaning towards vision rockers for the wheels and cooper discoverer stt pro's for the tires. I figured I would have to remove the front flaps and cut some but that's not a huge deal either. Thanks for the pics. This forum is really helpful.
    zcarpenter92 likes this.
  8. Feb 28, 2019 at 4:51 PM
    jessenavarro
    jessenavarro New Member
    Jesse
    Oak Glen, CA
    2018 White Tundra TRD Off-Road 4x4
    Front Fox 2.5 Coil-over shock with adjustable reservoir -- DSC Rear Fox 2.5 shock with adjustable reservoir -- DSC Total Chaos Fabrication UCA -- tubular Method Race Wheels MR701 18x9 + 25mm -- Matte Black BFG KO2s - 35x12.5x18 Demello Sliders RetraxPro XR bed cover Yakima Roof Rack setup Baja Designs S8 40" light bars x2 (amber and white LED) Baja Designs Squadron Pro ditch lights Baja Designs Squadron Sport fog lights Switch Pros SP-9100 Midland MXT400 GMRS radio
    I had to trim skid plate only
  9. Feb 28, 2019 at 4:52 PM
    jaredmillerdvm
    jaredmillerdvm Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    I have the same as what you are planning. You will have to trim a little off the skid and heat up the plastic in front of your tires and remold to prevent rubbing. I do not have spacers and I have a 3/1 leveling kit. I had already removed the mud flaps so unsure if you HAVE to removed them but I would assume.....
  10. Mar 14, 2019 at 2:23 PM
    clp311
    Ok, guys I got the wheel and tire setup mentioned above and I removed the both front mud flaps on both front tires. On turns I am still rubbing where the back flap was that I already took off. It's not as bad as when the flaps were on but still very noticeable. The wheels are 18x9 Vision Rockers. The tires are cooper STT pro's 295/70/18/
    Spacers needed?
  11. Mar 14, 2019 at 3:15 PM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    I also have 295/70R18 offset +25 and running stt Pro. I’m currently rubbing my body mount just a hair when I’m on full lock reverse.
  12. Mar 14, 2019 at 3:32 PM
    clp311
    is is not rubbing going forward on hard turn?
  13. Mar 14, 2019 at 3:35 PM
    TheBeast The Beach
    just do a CMC and pinch welds for peace of mind.
  14. Mar 14, 2019 at 4:32 PM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    No rubbing going forward or full turn
    clp311[OP] and Rica25 like this.
