295/70 18 on 18x9 +25 offset with 2” front lift
Discussion in 'Wheels & Tires' started by bmcdds, Nov 9, 2018.
  1. Nov 9, 2018 at 9:32 PM
    bmcdds
    bmcdds [OP] New Member
    CA
    2019 Barcelona Platinum
    Hey everyone,
    Sorry for another “will these fit” thread. I’ve been reading a lot of threads and I’m trying decide if I should change the size of my tires that I’ve ordered, but not been installed yet.
    Installing 5100’s on middle setting, 2 driver and 1 passenger side shims with Method Double Standard 18x9 +25 rims. Ordered 285/70 18 Nitto RGs at $312 and 60 lbs/tire Going with +2 CB shackles in the rear.
    However, I’m waffling and thinking of ordering 295/70 18 Cooper Discoverer ST Maxx at around $240 and 67 lbs/tire.
    I’m not really interested in CMC, but willing to remove front mud flaps, do some massaging, and pull the front plastic forward.
    Will the 295s be a good fit?
    Thank you!
  2. Nov 10, 2018 at 4:17 AM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    bmcdds[OP] likes this.
  3. Nov 10, 2018 at 4:58 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    I'm running the 295 Maxxs right now with +14 offset and no CMC required. Front fender liners were moved forward. By way those Maxxs are a great value. Can't vouch for +25 offset.
    zcarpenter92 and bmcdds[OP] like this.
  4. Nov 10, 2018 at 8:15 AM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    I’m running a very similar set up 295/70/18 on 18x9 +25 with a 3inch lift. You’ll need to do some trimming to the front fender liner.
    Black Wolf and bmcdds[OP] like this.
  5. Nov 10, 2018 at 9:53 AM
    bmcdds
    CA
  6. Nov 10, 2018 at 9:57 AM
    bmcdds
    CA
    Thank you for the feedback on the Maxxs. Any experience with STT Pros? They are only $3 more than the Maxxs with a deeper tread. But lower speed rating (not a big deal to me).
  7. Nov 10, 2018 at 11:05 AM
    Aurora CO
    I have a set of STT Pro M/Ts too. Great M/T off road tire. Good in most conditions except ice and super packed snow. Off road snow......great. Maxx's are better for daily driver if most of your time is on the highway all the time with long commutes otherwise either tire is good.
    bmcdds[QUOTED][OP] likes this.
  8. Nov 10, 2018 at 12:57 PM
    bmcdds
    CA
    Perfect!
  9. Nov 19, 2018 at 6:57 PM
    Hams
    Hams New Member
    Joel
    Fort Myers, FL
    16- Pro
    Camburg uniball UCA, Cooper AT3 XLT 295, Coachbuilder shims, shackles, and steering kit, SCS Ray 10, Undercover Flex Cover Ultra, GTR Lighting LED headlight and fog.
    After studying 34” tire specs and wanting the lightest tire to balance performance and ruggedness I opted for Cooper AT3 XLT. 60 lbs. Fairly new tire and should compete well against RG. Haven’t mounted them yet so can’t give you real world. Just providing another option.
  10. Nov 20, 2018 at 8:14 AM
    619tundra16
    619tundra16 New Member
    What tire did you end up with?
  11. Nov 20, 2018 at 10:26 AM
    bmcdds
    CA
    Thanks! I'll check them out, too.
  12. Nov 20, 2018 at 10:31 AM
    bmcdds
    CA
    My appointment is Friday at 10am. They have the RG in 285/70/18 and STT Maxx in 295/70/18 for me. Going to take a look at @Hams recommendation and check out the Cooper AT3 XLT too.
    I did the front lift yesterday, so now the truck sits level. I'll tackle the shackles another time, since I just needed to get the front done to get the wheels and tires installed.
  13. Nov 21, 2018 at 11:13 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Very interested in seeing your pics when installed!
  14. Nov 21, 2018 at 11:28 AM
    bmcdds
    CA
    Driver side
    Passenger side
    Sitting at Big Brand Tire in Lompoc waiting on the alignment. Moved up my appointment for wheel and tire install to today at 4:30.
    Voyagermike likes this.
  15. Nov 21, 2018 at 12:16 PM
    bmcdds
    CA
    Numbers almost all within what coachbuilder recommended. The left toe is 0.05 instead of 0.07-0.12.
    Voyagermike and parker44 like this.
  16. Nov 23, 2018 at 9:41 PM
    bmcdds
    CA
    1B3F10E7-4391-42F1-8A3C-A31CD843C7DA.jpg 2BD865BD-5776-4393-9142-1B7C863609DE.jpg 7CD95F7E-75CF-450A-BD93-40B5EF35328D.jpg E2D760F9-B657-4BCE-AA71-3DA7FADF010B.jpg
    Went with the 295/70 18 Cooper ST Maxx tires.
  17. Nov 25, 2018 at 11:26 AM
    TheBeast The Beach
    looks great !
  18. Nov 25, 2018 at 11:41 AM
    bmcdds
    CA
    Bilstein 5100s with middle setting, 2 coachbuilder shims on driver and 1 shim on passenger side. Going to install coachbuilder +2 shackles another weekend.
    Pigglet222 and Voyagermike like this.
  19. Nov 25, 2018 at 12:06 PM
    Voyagermike
    Voyagermike New Member
    California
    Truck looks awesome man! Running the same size tire on my truck as well. If I see you around town I'll make sure to wave.
    :burnrubber:
  20. Nov 26, 2018 at 7:24 PM
    bmcdds
    CA
    I could probably guess where you live. I’ll do the same if I see you.
    Voyagermike[QUOTED] likes this.
  21. Nov 26, 2018 at 7:25 PM
    bmcdds
    CA
    I’ll add the shackles to maintain some rake to keep the TSS sensor happy and prevent the bro lean when I have a load in the back or towing.
  22. Nov 26, 2018 at 7:27 PM
    bmcdds
    CA
  23. Nov 27, 2018 at 5:58 PM
    bthompson12
    bthompson12 New Member
    Bruce
    GA
    22’ Blueprint SR5 4x4
    I have factory 2018 TRD wheels 18 inch with 295/70/18’s and no spacers were needed. I only have 5100’s at top setting and no rubbing at all or any cutting/modifications. Not sure why people add additional stuff up front with the 5100’s
    Pigglet222 likes this.
  24. Nov 27, 2018 at 6:31 PM
    bmcdds
    CA
    I felt that I would be doing less preloading on the 5100s by going with the middle setting. Adding an extra shim on the driver side gets rid of the lean on that side.
  25. Nov 27, 2018 at 6:37 PM
    bthompson12
    Bruce
    GA
    Oh okay. I must have got lucky because mine doesn’t lean at all
