295/70/17 on Stock Suspension??
Discussion in 'Wheels & Tires' started by nyhc121, Oct 26, 2022.
  1. Oct 26, 2022 at 10:20 AM
    nyhc121
    nyhc121 [OP] New Member
    2017 Limited TRD Off Road
    I’m looking to get some 17x8 Method 316s, +25 offset with 295/70/17s on stock suspension. Anyone know if this will work? Tiresize website shows the height the same as 275/70/18 which I know work on stock suspension, but tires are about an inch wider. Thanks
  2. Oct 26, 2022 at 10:57 AM
    PermaFrostTRD
    Northern NY
    Cab/body mount chop and bumper shims plus a heat gun on the fender liners in the wheel well is likely necessary with that offset and tire width. Possible skid plate trimming as well.
  3. Oct 26, 2022 at 11:12 AM
    nyhc121
    For a 33” tire?? I was under the impression body mount chop was only necessary when you went 35 and above
  4. Oct 26, 2022 at 11:14 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Why do you ask for help and then argue w/the response :notsure:
    Cpl_Punishment likes this.
  5. Oct 26, 2022 at 11:19 AM
    nyhc121
    I’m trying to clarify the answer considering a 33” tire is a common upgrade for people running 18” wheels with no other modifications. I don’t mind removing the mud-flaps and fender liner but I’m not interested in a body mount chop. Has anyone had personal experience running a 17” 295/70/17
  6. Oct 26, 2022 at 11:47 AM
    PermaFrostTRD
    Northern NY
    I've highlighted the important part. "33's on 18's" are typically guys putting 275/70r18 LT size on their OEM wheels that have a a +60mm offset, which is different from the +25 wheel you're asking about. Then add another inch (width) of tire (295 vs 275).
    Do what you want. You may be fine, you may need to get your knuckles dirty.
  7. Oct 26, 2022 at 11:50 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
  8. Oct 26, 2022 at 1:03 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Yes it works. I did it with no lift but did lose mud flaps and pushed the liner forward a wee bit. Same size and offset.
    nyhc121[OP] likes this.
  9. Oct 26, 2022 at 2:07 PM
    nyhc121
    Thank you! Any pics from that setup?
  10. Oct 26, 2022 at 2:09 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    I agree with @dpast88. I leveled mine, added a bumper shim and still had to lose the little flap in the front
  11. Oct 26, 2022 at 2:13 PM
    nyhc121
    There’s also the Method 703 I was looking at with +35 offset. Not sure if that’s a better option but that wheel is a half inch wider and a few lbs heavier I was trying to keep the setup light as possible since I’m going to an E rated tire.
  12. Oct 26, 2022 at 4:22 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Sure.
