285/75R18 wheels and tires fit without cmc
Discussion in 'Wheels & Tires' started by Blueribbon15, Mar 28, 2018.
  1. Mar 28, 2018 at 9:21 PM
    Blueribbon15
    Blueribbon15 [OP] New Member
    2015 blue ribbon Tundra
    2015 tundras SR5 TSS package. 3/1 leveling kit 285/75R18 Nitto Ridge Grapplers
    Hello all. I’m new here. I’ve been trying to find threads about fittment issues with 285/75R18 tires. I just wanted to start a thread about these tires. I have a 2015 Tundra with a 3/1 leveling kit. I have 18” wheels with a 25mm offset. I’m running Nitto Ridge Grapplers size 285/65R18. I wanted to let people know that this setup works well. I didn’t have to do a cmc. I just removed the front two flaps and had to do some minor trimming on the bumper plastic. The set up is sweet. I hope this helps anyone looking at this set up. I don’t know if it will work for any other generations, but in the 3rd gen tundras, it works awesome.
  2. Mar 28, 2018 at 11:55 PM
    Gtfour43
    Gtfour43 New Member
    Oahu
    So are those 285/65 or 285/75?
    Nice truck btw
    Blueribbon15 [OP] and monaco730 like this.
  3. Mar 29, 2018 at 3:13 AM
    Casper3
    Casper3 Slow down, let the MGM's catch up.
    Jay
    CT
    2017 Super White 5.7 SR5 TRD off road
    Welcome from Ohio, looks good :thumbsup:
    Blueribbon15 [OP] likes this.
  4. Mar 29, 2018 at 4:24 AM
    parker44
    parker44 New Member
    Keith
    Columbia, South Carolina
    2008 Tundra - Desert Sand Mica
    I like those wheels. I was actually between those you got and the Vision Warriors I got. Only reason I went with the warriors is because I wasn't sold on those MB wheels photoshopped on my truck, and thought mine would look a little better with more chrome. Sweet setup!
  5. Mar 29, 2018 at 5:18 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Tundra TRD nonPRO
    Methods, Toyos, Kings, TCs
    I have Method Standards 18x9 +20 and Toyo 285/75/18, didn't have to do the CMC (BMC). I did cut the skidplate ears off, but I did that before I even owned the new tires so can't verify if it was necessary or not. No mud flaps of course, but they could potentially fit with some modification.
  6. Mar 29, 2018 at 11:19 AM
    Blueribbon15
    They’re 285/75’s. I forgot I had to bend my skid plate. But I also did that before I got my new tires.
    Boudin likes this.
  7. Apr 1, 2018 at 2:45 PM
    Thesquatchy1
    Thesquatchy1 New Member
    Georgetown, KY
    2018 cement SR5 4x4 5.7
    Those look good!
  8. Apr 1, 2018 at 4:46 PM
    Blueribbon15
  9. Apr 1, 2018 at 4:57 PM
    Thesquatchy1
    Georgetown, KY
    Which leveling kit did you use?
  10. Apr 1, 2018 at 5:01 PM
    2ndgenny
    2ndgenny Support oil pipelines...we drive Tundras.
    Oh8 Limited DC
    Arb bumper/2” rigid led fogs. Pocket fender flares. Debadged. Smoked tailights/3rdbrake. Magnaflow catback.
    Looks deadly. Which rim is that?
  11. Apr 1, 2018 at 5:02 PM
    Blueribbon15
    I used the fat bob 3/1 leveling kit. It’s exactly the same as the rough country. I did this one to get tires for now, but I’m planning on doing the Bilstein coilovers
  12. Apr 1, 2018 at 5:10 PM
    Blueribbon15
    The rims are MB’s. I like them a lot. They have a bigger load rating than the fuels I was looking at. Plus way cheaper
    2ndgenny likes this.
  13. Apr 7, 2018 at 7:11 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    TRD Rear Anti-sway bar, TRD Pro skid plate, Bedrug bed mat, Icon Rebounds 285/75/17 Cooper Discoverer XLTs, Bilstein 6112s/5160s, Diamondback SE
    Thought those looked familiar. Same as the ones I have. They look much better on yours with the lift and bigger tires!
  14. Apr 26, 2018 at 7:43 AM
    1794TUNUNDRUM
    1794TUNUNDRUM New Member
    Jay
    2016 Toyota Tundra 1794 Edition
    2.4" Leveling Kit
    Thanks Blueribbon15 and Tundradrenalin, those are both great looking trucks! Appreciate the detailed lift and tire&wheel info. I got way too much negative space around these stock 275/55R20's and "need" to upgrade for summer.
  15. Apr 26, 2018 at 10:17 AM
    mds808
    mds808 New Member
    2017 Platinum Tundra - Metalic Black
    Any front pics? Thx
  16. May 8, 2018 at 8:41 AM
    1794TUNUNDRUM
    Jay
    2.4" Leveling Kit
    Thanks for the inspiration Blueribbon15, I pulled the trigger this past weekend! I went with the 285/75R18 Nitto Ridge Grapplers on 18X9 Fuel Cleaver D574 wheels with 20mm offset/5.75" backspacing. I only had to trim inner front bumper plastic, the tires rub the cab mount a little bit at full turn, as expected, since I only have a 2.4" spacer up front and not the full 3/1 lift. Not sure if I'm going to do the CMC or the 3/1 lift, but either way it would definitely clear the cab mount then. Also, you guys were right, I have almost 2" of clearance at full turn for the factory skid plate, so no trimming required there with this setup!
    Stock 2.jpg Cleaver Wheel.jpg Nitto RG Tread.jpg BOOM 1794 2.jpg D1.jpg P1.jpg
  17. May 8, 2018 at 8:54 AM
    parker44
    parker44 New Member
    Keith
    Those look sweet!!! I love the ridge grapplers on mine.
    1794TUNUNDRUM likes this.
  18. May 20, 2018 at 5:03 PM
    Papa roach
    Papa roach New Member
    Dustin
    2014 silver metallic TRD crewmax
    Soon to be 3 in 1 leveling kit
    The pics look great. I also just purchased the 285/75/18 ridge grapplers and the 3 in 1 leveling kit from supreme suspensions. I have a 2014 tundra TRD and planning to keep my 18” TRD wheels. I think they have a 55 offset. I’m wondering if this setup will work? I’d prefer not to use wheel spacers. Thanks in advance.
  19. May 20, 2018 at 5:46 PM
    zcarpenter92
    zcarpenter92 Yotas, Coronas and 'Merica
    Zach
    Eastern Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I believe those wheels are +60 offset, and I believe you’ll need em. I do seem to remember a guy or two that’ve run stock wheels on 295/70’s and didn’t need em though, but I could be wrong.
  20. May 24, 2018 at 1:09 PM
    RangerBP
    RangerBP SC Expat
    Cañon City, CO
    2017 4x4 SR5 TRD Double Cab SSM
    I just put 285/75/18 duratrac on 2017 stock trd wheels. 2.5”/1” lift, no spacers, no CMC, a wee bit of frame rub at full lock. Stock skid plate had to go due to its width.
    equin likes this.
  21. May 26, 2018 at 6:58 AM
    aztundraguy
    aztundraguy New Member
    2017 Tundra CM TRD Offroad
    6112/5160,Icon Billet UAC,Diff Drop,Billet .250 shim Lean Correction, CB Bump Stop Extensions, 275/70r18 w/ 18x9 +12 offset
    You have any pictures
  22. May 26, 2018 at 10:10 AM
    RangerBP
    RangerBP SC Expat
    Cañon City, CO
    aztundraguy likes this.
