285/75/r18 on 17 Stock TRD PRO
Discussion in 'Wheels & Tires' started by YotaBro, Feb 23, 2021.
  1. Feb 23, 2021 at 2:47 PM
    YotaBro
    YotaBro [OP] This forum will make me broke
    Calvin
    FL
    Lots of shenanigans.
    Just ordered these and wanted to verify if anyone runs these on a stock TRD PRO before I throw them on. I am already aware that I will need to remove the mud flaps. I know a lot of people run 295/70/r18 and 285/70/r18 but not many with 285/75/r18.
    Nativeimages and ackthresher like this.
  2. Feb 23, 2021 at 4:29 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
  3. Feb 23, 2021 at 4:34 PM
    YotaBro
    Calvin
    FL
    Nativeimages likes this.
  4. Feb 23, 2021 at 5:18 PM
    biebs96
    PA
    I did it. I am leveled to the same height as the pro in the front and trimmed my skid plate to match the width of the TRD Pro skid. Removal of the little front flaps was all that was needed and I have zero issues rubbing lock to lock.
    285/75/18 on stock rims (same as pro) No wheel spacers.
    to me this photo just shows how much bigger the truck looks with a simple tire upgrade.
    Hope this information helps.
  5. Feb 23, 2021 at 5:27 PM
    YotaBro
    Calvin
    FL
    Thank you, kind sir! This for sure helps! Gives me reassurance for my decision. Just didn't wanna throw these bad boys on just to find out that it won't work
    Nativeimages and biebs96[QUOTED] like this.
  6. Feb 23, 2021 at 6:11 PM
    biebs96
    PA
    No problem. I felt the same way and after much research on here I decided to pull the trigger... and I am very glad I did.
  7. Feb 23, 2021 at 6:12 PM
    YotaBro
    Calvin
    FL
    Yeah, this is the closest to having 35's so im super siked!
  8. Feb 23, 2021 at 6:14 PM
    biebs96
    PA
    Also when you complete this... please for the love of everything... do not start a “my mpg’s are worse after my 35s” thread :rofl:
  9. Feb 23, 2021 at 6:15 PM
    YotaBro
    Calvin
    FL
    Hahaha, well i didnt buy a yota for the MPG so I cant complain too much :rofl:
    biebs96[QUOTED] likes this.
  10. Feb 23, 2021 at 6:17 PM
    biebs96
    PA
    my Yokohama’s are embossed on the sidewall with a height of 35”
    Couldn’t resist.
    YotaBro[QUOTED][OP] likes this.
  11. Feb 23, 2021 at 6:59 PM
    Fish2eat88
    Fish2eat88 New Member
    Jay
    2018 silver sky double cab
    295/75 3/2 lift
    This tire is perfext. Wheel spacers would make it beefier but here in 808 sometimes you will get bothered if your tires stick out so I just avoid all that non sense
  12. Feb 23, 2021 at 7:00 PM
    YotaBro
    Calvin
    FL
    You didnt do anything to your suspension?
  13. Feb 23, 2021 at 7:12 PM
    Fish2eat88
    Jay
    295/75 3/2 lift
    Sorry 3/2
  14. Feb 25, 2021 at 4:35 PM
    YotaBro
    Calvin
    FL
    She fits! Thanks for all of the help guys!
  15. Feb 26, 2021 at 2:16 PM
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    No rubbing the UCA, or anywhere at full lock? Looks like you removed the front mud flap?
  16. Feb 26, 2021 at 4:16 PM
    YotaBro
    Calvin
    FL
    No rubbing lock to lock and yeah that sucker had to go
    itsmerh85[QUOTED] likes this.
  17. Mar 12, 2021 at 4:18 PM
    drhntr
    drhntr New Member
    Derrick
    New Hampshire
    2017 Cement Pro DC
    GoRhino 2.0 MX4 295/70/18 TOYO AT3 TRD CAI Window Tint
    Thinking about going with the 285/75 on my pro as well these look great
    Congrats
    ackthresher and biebs96[QUOTED] like this.
  18. Mar 18, 2021 at 7:04 PM
    Tdog408
    Tdog408 New Member
    T
    2020 Cement Tundra Limited TRD Off Road/ 2017 BMW M4
    I’m running 285/75/18. Love it. Just got these the other day. Mud flaps removed and wheel well modification with a heat gun. No rub.
  19. Mar 26, 2021 at 7:37 AM
    nomad_dave
    nomad_dave New Member
    David
    Colorado Springs, CO
    2021 Tundra Ltd double cab
    OME BP-51,SPC UCAs
    I keep reading about the heat gun mod, could you show a picture of it now?
  20. Mar 26, 2021 at 6:14 PM
    Tdog408
    Tdog408 New Member
    T
    not the greatest job but it works.
  21. Mar 27, 2021 at 1:04 PM
    nomad_dave
    David
    OME BP-51,SPC UCAs
    It looks like you got a good bit of clearance from that.
    Tdog408[QUOTED] likes this.
  22. Apr 7, 2021 at 5:47 PM
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    Truck looks great! I was waiting for someone to put Falken Wildpeaks on. I am thinking I will try the same size as you, 285/75r18. Still no rubbing or anything?
  23. Apr 7, 2021 at 6:00 PM
    YotaBro
    Calvin
    FL
    With the added weight (I got an aftermarket bumper with a winch and lights) it dropped it so it started rubbing the rear mud flap so I just took it off. If you aren’t running 300+ lbs you should be fine.
  24. Apr 7, 2021 at 6:07 PM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    With stock offset you’ll probably rub the front sway bar lightly as well. Nothing of concern but you’ll lose some of the paint off it.
    2.25” lift front and rear (listed height not measured) new springs were so firm I opted to remove the sway anyway. My Falken say 35” but barely measure 34 x
    The Dude likes this.
  25. Apr 7, 2021 at 6:30 PM
    Lemoyne40
    Lemoyne40 New Member
    Central PA
    that's a great looking ride my man!
  26. Apr 9, 2021 at 5:02 PM
    Sitting Sideways
    Beaverton, Oregon
    Ordered the same 285/75r18 Falken Wildpeak AT3W’s. Found them on Amazon for 278 and Discount Tire price matched it. What tire pressure are you running? Thanks for the info
    Skey44 likes this.
  27. Apr 10, 2021 at 7:01 AM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    40 psi in same tires (size and brand) here. A little lover if you want a smoother ride. A bit more for loads. I did the chalk test and think 38 is where they were “ideal” but I just run 40.
    Sitting Sideways and biebs96 like this.
  28. Apr 17, 2021 at 10:16 AM
    Sitting Sideways
    Beaverton, Oregon
    That’s 38 psi cold right?
    Skey44[QUOTED] likes this.
  29. Apr 17, 2021 at 10:22 AM
    Sitting Sideways
    Beaverton, Oregon
    3EFFB729-6059-43A9-9EEB-A38DC99B5330.jpg Got my 285/75r18 Falken Wildpeaks today! Removed the front flaps but still have a little bit of rubbing in the front. I believe it’s due to that I am running the maximum caster and have Icon UCAs so all that pushes the wheel much farther forward in the wheel-well. I am going to use a heat gun and mold the plastic forward a bit. Looks like I only need to do so about 1/8” maybe. Thanks for all the info guys!
    Skey44 likes this.
  30. Apr 17, 2021 at 10:38 AM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Looks awesome!
