285-75-18 Rubber Options
Discussion in 'Wheels & Tires' started by mr_souc, Mar 8, 2018.
  1. Mar 8, 2018 at 6:48 AM
    mr_souc
    mr_souc [OP] New Member
    Joel
    Maine
    2014 Tundra TRD Off-Road CrewMax
    - 3/2" Leveling/Lift - TRD Dual Exhaust - TRD Pro Grill - 32 Inch Light Bar - N Fab Step Rails - Color Match Bumpers - 285/75-18 Terra Grappler G2s
    Hey gang,
    Looking for a mid-aggressive tread tire for a set of 285-75-18s. I don't need anything too meaty as I do a fair amount of highway driving, yet I'm not looking for rollerblade wheels either...
    The two options that blow my skirt up so far are the Toyo Open Country A/T IIs & the Nitto Terra Grappler G2s, in that order.
    What other decent options come in this size? Coming up from a Tacoma in a 16" rim where I ran 285-75-16, I'm surprised at the limited AT options in a 285-75-18 for the Tundra.
    What do you fellas run? Would I be better off running a 33" or 35"?
    Cheers!
  2. Mar 8, 2018 at 7:05 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    NC
    2017 TRD Pro Tundra Wht
    BFG ko2!!!!
    mr_souc [OP] likes this.
  3. Mar 8, 2018 at 7:08 AM
    mr_souc
    Joel
    Maine
    Yessah, that's all I used to run on the Tacoma, but they don't appear to come in a 285-75-18.
    zcarpenter92 likes this.
  4. Mar 8, 2018 at 7:14 AM
    seniramsu
    Nate
    NC
    Hmmm. That is a shame. I love these tires and like you it is all that I have ran.
  5. Mar 8, 2018 at 7:19 AM
    seniramsu
    Nate
    NC
    Looks like BFG has those in the M/T...
  6. Mar 8, 2018 at 7:39 AM
    mr_souc
    Joel
    Maine
    A little more rubber then what I need. I might have to bump to a 35-12.5-18 to bet a better selection.
  7. Mar 8, 2018 at 9:02 AM
    zcarpenter92
    zcarpenter92 Yotas, Coronas and 'Merica
    Zach
    Eastern Colorado
    2008 Desert Sand 5.7L DC
    In sig
    If I remember correctly, Toyo RT's come in that size. And I just found out there's a 285/75R18 in that size as well. If they were available when I was looking I'd of likely went with those.
  8. Mar 8, 2018 at 9:51 AM
    mr_souc
    Joel
    Maine
    rnssncman likes this.
  9. Mar 8, 2018 at 9:57 AM
    zcarpenter92
    Zach
    Eastern Colorado
    In sig
    Forgot to add this one on my post too @mr_souc
  10. Mar 8, 2018 at 10:25 AM
    parker44
    parker44 New Member
    Keith
    Columbia, South Carolina
    2008 Tundra - Desert Sand Mica
    That size isn't quite as common as the 295/70/18, so not as many choices. I think it's becoming more popular though, but you may check out the 295's.
    What size lift/level are you running or plan on running? If you drop down to a 33, 275/70/18 are widely available in almost every tire, plus much cheaper.
  11. Mar 8, 2018 at 11:00 AM
    mr_souc
    Joel
    Maine
    Running a 3" up front and 2" out back. The truck came with 285/65/18 (~33") Falken Wildpeak A/T 3Ws, which are great tires, they just look way too small to me and don't fill up the wheel well.
  12. Mar 8, 2018 at 11:38 AM
    mr_souc
    Joel
    Maine
    Looks like a 325-65-18 is also a decent option. A lot more options in this size. Only thing is it's looking like the 325-65-18s are ~1.5" wider and on a stock wheel w/ no offset, I imagine there would need to be some trimming due to rubbing...
  13. Mar 8, 2018 at 12:09 PM
    zcarpenter92
    Zach
    Eastern Colorado
    In sig
    I know one guy who’s tried to fit those on a 3/1 and they wound up rubbing the frame pretty seriously, even with aftermarket wheels.
  14. Mar 8, 2018 at 12:18 PM
    mr_souc
    Joel
    Maine
    Pissah...
    Likely lean to the original 285/75/18s or even 295/70/18 in that case then...
  15. Mar 9, 2018 at 7:31 AM
    parker44
    parker44 New Member
    Keith
    Yea I would go with those two sizes you mentioned above. I might lean towards the 295's, those are a little shorter than those 285/75's.
  16. Mar 9, 2018 at 8:02 AM
    mr_souc
    Joel
    Maine
    Fair enough, appreciate the input.
    I think the 295s might be the winner just do to the greater selection in that size.
    Cheers gang!
  17. Mar 9, 2018 at 1:57 PM
    Watt maker
    Watt maker Keepin' the lights on!
    Ronald
    2017 TRD Pro Tundra DC Cement
    1 of 255
    The Nitto Ridge Grappler is offered in a 285/75/18. I run them in the 295/70/18 version and I’m very pleased with them. Smooth, quiet, well balanced on road and they can still hold their own off-road. I’ve also been running them on a 4runner that’s been all over the SW n just about every terrain imaginable and these tires have impressed me.
  18. Jul 3, 2018 at 3:48 AM
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    Cooper AT3's are offered in that size. I have run them on various vehicles and they have been great. I am currently running Ridge Grapplers this is my second set, no complaints however next go around I will probably go back to the Cooper AT3's.
  19. Dec 4, 2018 at 11:01 AM
    mr_souc
    Joel
    Maine
    I ended up rolling with 285/75 R18 Nitto Terra Grappler G2s. I have about 15k miles on them and they seem to be wearing WAY better them any BFG KO2s or General Grabbers I have ever ran on any vehicle before.
    I'm a happy camper.
    equin and Watt maker like this.
  20. Dec 9, 2018 at 12:56 PM
    Mgmtundra
    Mgmtundra New Member
    I’m looking into this tire size as well can you post a few pics of your TGs? The duratrac in that size is pretty interesting as well.
  21. Dec 9, 2018 at 12:59 PM
    RangerBP
    RangerBP SC Expat
    Cañon City, CO
    2017 4x4 SR5 TRD Double Cab SSM
    This is my first winter running the Duratrac in 285/75 and they’ve performed well.
    Edit: I don’t know if winter is an issue for you or not, but they’ve done well as an all-around tire.
  22. Dec 9, 2018 at 1:03 PM
    Mgmtundra
  23. Dec 9, 2018 at 1:04 PM
    Mgmtundra
    What’s the specs on the lift?
  24. Dec 9, 2018 at 1:06 PM
    RangerBP
    RangerBP SC Expat
    Cañon City, CO
    Thanks.
    6112 at 2.5 up front, 5100/toytec shackle at 1” in the back, stock ucas, no bmc.
    equin likes this.
  25. Jan 28, 2019 at 6:28 AM
    Luckydog
    Luckydog New Member
    Dominic
    Currently Ohio.
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    Hey RangerBP- I like the look of those tires. Do you think I could get away with those on 6112's @ 1.9"?
  26. Jan 28, 2019 at 6:36 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    This site has been useful for a number of tire/wheel-related questions. Here's what they have in your size:
    Luckydog likes this.
  27. Jan 28, 2019 at 11:05 AM
    RangerBP
    RangerBP SC Expat
    Cañon City, CO
    I’m no expert, but I think you may be able to fit it, but it’d be really snug if it fits.
    I’ll tell you that they fill up the wheel well at 2.5”. The biggest potential for rub is with a stock front bumper. It looks like you have an aftermarket, so you should clear there. They’re big tires - 35.1” x 11.2”. Especially if you off-road, the extra .6” would give you room for it to articulate a bit more.
    Sorry I’m not helpful in being able to give a definitive answer. There are a handful of active members here running these. It may be worth looking to see what height they’re running.
    Good luck!
  28. Jan 28, 2019 at 11:10 AM
    Luckydog
    Luckydog New Member
    Dominic
    Currently Ohio.
    Thank you for the reply! Definitely going to give it a try when these tires wear out. Should be in the next couple months. Will post with my experience when I do.
    RangerBP likes this.
