285/70r18 Nitto Ridge Grappler
Discussion in 'Wheels & Tires' started by nvrgvup444, May 27, 2019.
  1. May 27, 2019 at 7:58 PM
    nvrgvup444
    nvrgvup444 [OP] New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    Have the original Michelin 275/65r18
    Put on 5100's all around
    front = Top setting
    back = 5100 with Toytec shackle set at 1.5"
    I'm hoping for a match on Falken 275/70r18 from a national chain (~$175)
    Just wondering if I should go up to 75's or keep the gas mileage good and stay with 70's
    I have a lot of space to fill in my wheel wells but I like the look of the TRD rim so I'm keeping them.
    Black Wolf likes this.
  2. May 27, 2019 at 8:00 PM
    Needs larger tires
  3. May 27, 2019 at 8:08 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    285/75
    drobb and nvrgvup444[OP] like this.
  4. May 27, 2019 at 8:10 PM
    nvrgvup444
    KCMO
    That's what I was afraid of.
  5. May 27, 2019 at 8:12 PM
    Aurora CO
    285/75 will fit quite nicely with those TRD rims
  6. May 27, 2019 at 8:14 PM
    nvrgvup444
    KCMO
    thanks - I'm actually looking forward to dropping the cash on new tires. Should help me do what I do and look good doing it.
  7. May 27, 2019 at 8:16 PM
    Aurora CO
    You'll like the Falkens. Quite popular here with decent reviews (Wild Peaks)
  8. May 27, 2019 at 8:45 PM
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
    I'm in the same situation, factory 275/65-18's are almost done and truck sits at 2.5"/1.5". I am considering 285/65-18 Dick Cepek as they spec at 33" tall as opposed to most others that spec. 32.6".
    Saw this truck when I was at a local dealership. looked like a 2" spacer lift maybe a little more. 285/65-18 tires.
    I'd go bigger just don't want to deal with some of the issues.
    nvrgvup444[OP] likes this.
  9. May 27, 2019 at 9:21 PM
    nvrgvup444
    KCMO
    I think/hope the 285/75r18 will clear my stock UCA, but I bet I will have to trim my skid plate and possibly the front splash guards.
    My paint is so soft I don't want a lot of the tire sticking out...:crazy:
  10. May 27, 2019 at 9:54 PM
    TrooperDC4x4
    Nor Cal
    285/75 will definitely look good. Just use them as an excuse to get one of these, or RCI Skid, then you don't have to trim:
  11. May 28, 2019 at 9:02 AM
    nvrgvup444
    KCMO
    Here is a better pic with the stock Michelin's
  12. May 28, 2019 at 10:11 AM
    TrooperDC4x4
    Nor Cal
    Nice truck.
    You gonna do wheel spacers?
    I also like the TRD alloys. I go back and forth on possibly running spacers for a little wider stance.
  13. May 28, 2019 at 12:10 PM
    nvrgvup444
    KCMO
    I was hopeful that I wouldn't have to. I don't know if running 285/75 if I will need to.... Anyone?
  14. May 28, 2019 at 5:56 PM
    nvrgvup444
    KCMO
    Well.... I bought the Nitto Trail Grapplers 285/75r18. They had 200 miles on them and someone brought them back to Discount Tire and ordered bigger tires.
    Sold them to me for $200 each with add-on's for lifetime balanced and rotation and replacement ($50/tire)+ tax + install = $1100
    Total cost per tire = ~ $280 per tire
    Get them put on tomorrow. The Nitto's get good reviews so I am hoping for the best. Please no rub a dub rub...
    Send pics tomorrow night.
  15. May 29, 2019 at 4:28 PM
    nvrgvup444
    KCMO
    Went a little safer route with the 285/70r18 instead of 75. I have a little rubbing on the skid at full turn = easy fix.
  16. May 29, 2019 at 4:38 PM
    Aurora CO
    NICE!
  17. May 29, 2019 at 6:52 PM
    TrooperDC4x4
    Nor Cal
    Looks good.
    Let's see some shots from from/back to see how they fit within the wheel wells.
  18. May 29, 2019 at 10:53 PM
    nvrgvup444
    KCMO
  19. Jul 19, 2019 at 5:01 PM
    ncomeau35
    ncomeau35 New Member
    North of Boston
    2019 White Toyota Tundra TRD PRO
    Nitro Ridge Grappler 285/75/18
    2nd this!!! Just installed a set of Nitto Ridge Grappler 285/75/18, really filled out the wheel well nicely
  20. Jul 23, 2019 at 9:05 PM
    MICKs18yota
    MICKs18yota New Member
    Ohio
    2018 Tundra SR
    DD455A68-46B2-422C-95F3-E0776197E9CE.jpg Just went with 285/70/18 Yokohama Geolander MT and I really like them, filled wheel wells in good. Don’t think they look small.
  21. Jul 23, 2019 at 9:15 PM
    Fish2eat88
    Fish2eat88 New Member
    Jay
    2018 silver sky double cab
    295/75 3/2 lift
    Have you measured your rear? Looks way more then 1.5. I got 285/75r18 on stock rims with only the skid plate rub on full crank. Im 3/2 and your rear looks way higher
  22. Jul 24, 2019 at 6:09 AM
    Lobodog1
    Lobodog1 New Member
    I have been considering those Yoko's in that size. Any chance you can post a few more full size pics of your truck and what your suspension set up is? Thanks in advance!
    tonynw318 likes this.
  23. Jul 24, 2019 at 9:41 AM
    MICKs18yota
    Ohio
    2018 Tundra SR
    It has 6112’s set at 1.9 on front.
    Rear is not lifted but added 5100’s.
    Wheels are Method NV +25 offset.
    I will tell you it drives and handles better than the stock suspension.
    I did have to trim front mud flaps take off splash flaps on the front and I do have slight rub on drivers side front liner I’m not sure if I’m going to push liner forward, add the CB bumper shims, or just try heat gun. Hopefully I can get to it soon. The truck sets about 1/4 high in the rear was going to recheck numbers after I get some more miles on it.
    Only have a few pictures.
    Here’s a couple of pictures if you need more let me know. Hope this helps.42B8D2A1-5042-488A-8DBE-2E200F794236.jpg 08385267-CDBD-4AEF-8548-7C72AFAF08B8.jpgmE6E3A371-65BF-432B-9310-D445AC6CDA2C.jpg
  24. Jul 24, 2019 at 9:53 AM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    I saw you put the 5100's on the top setting. How's the ride compared to stock TRD with the new tires?
  25. Jul 24, 2019 at 3:43 PM
    ncomeau35
    North of Boston
    Just put on Nitto Ridge Grappler 285/75/18 slight rub on the front mud flap so i removed it. Now at full lock there's just enough clearance, no rubbing
  26. Jul 24, 2019 at 5:40 PM
    nvrgvup444
    KCMO
    I had Toytec shackles installed on top setting because I wanted some rake. My bed is usually full of tools or I am towing and thus weighted down.
    Fish2eat88[QUOTED] likes this.
  27. Jul 24, 2019 at 5:49 PM
    nvrgvup444
    KCMO
    The ride with the 5100's on top setting with the stock light truck tires was smooth as butter. It just looked a little funny with the small tires.
    The ride with the 5100's with the new tires is definitely stiffer. Not bad. But it went from what my wife said as "rides like a car" to "rides a little rougher" - I had to play with the tire pressure to find the sweet spot.
    I know almost everyone goes with middle setting plus shims. I do go off-road a lot. However, I take it slow and easy because I'm usually in places where I'm not on trails. Just fields and forest and some Kansas canyons.
    Fish2eat88 likes this.
  28. Jul 24, 2019 at 6:40 PM
    You need wheel spacers in a bad way......your wheels are tucked in. Spacers would make your stance look alot better. I run a +1 offset and have Bushwackers.
  29. Jul 24, 2019 at 9:09 PM
    ncomeau35
    North of Boston
  30. Jul 25, 2019 at 7:05 AM
    I don't use spacers any more because I went with the +1 offset. They are Spidertrax and were only used for about a month. Now they have been sitting in their boxes in the garage.
