285/70r18 Anyone running?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by TunofLunaRock, Aug 10, 2021.
  1. Aug 10, 2021 at 5:07 AM
    TunofLunaRock
    TunofLunaRock [OP] New Member
    Serg
    Tundra
    Seeing a lot of guys running 295’s on stock TRD PRO(2” TRD/Fox suspension lift), I’m also reading that there’s slight rubbing or close to. Has anyone ran 285’s/70r18? Does the size fit the truck? Also, I imagine there’s no rubbing on that size tire. Might just look a little too small?? I don’t know. What are y’all’s thoughts?
    jewsNbrews likes this.
  2. Aug 10, 2021 at 5:15 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I’m running 285/75s on the stock Pro suspension. Added CB+2 for less squat which a load. Click the link below in my signature for pics.
    Also, you could search the TRD Pro forum for 285/70 like this:
  3. Aug 10, 2021 at 5:30 AM
    The 285 and 295 are within 3/8 inch of each other. They are very close. The 295 is 10 lbs per tire heavier though.
  4. Aug 10, 2021 at 7:14 AM
    TunofLunaRock
    Serg
    Tundra
    Thanks, I’ll have to search that way.
    Terndrerrr[QUOTED] likes this.
  5. Aug 10, 2021 at 8:03 AM
    U-moto
    U-moto New Member
  6. Aug 10, 2021 at 9:59 AM
    duerrs
    duerrs Semper Fi!
    2008 Tundra TRD Off Road & 2020 Tundra TRD Pro
    Same as above w/1.25" Bora Spacers...IMG_1788.jpg
    bulldog93, daveS67, a_double and 3 others like this.
  7. Aug 10, 2021 at 10:37 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    @Marty McFly has that size I believe.
    I am planning on this size as well when the stock Michelins wear out. Planning on going either bfg km3 or nitto ridge grapplers.
    Marty McFly likes this.
  8. Aug 10, 2021 at 12:10 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Im running the 285/70/18.
  9. Aug 10, 2021 at 2:14 PM
    MICKs18yota
    MICKs18yota New Member
    Ohio
    2018 Tundra SR
    285/70/18s here alsoD60AAE27-E8F8-46A3-A020-4113EB284C63.jpg
  10. Aug 13, 2021 at 8:04 AM
    snappy924
    snappy924 New Member
    Garrett
    Pasadena, California
    2017 Tundra Crewmax 4x2
    Bilstein shocks, Tembren bump stops,
    I’m running 285x65x18 on stock wheels with truck leveled with Bilsteins. Added bumper shims to avoid rubbing. So far so good.
  11. Aug 13, 2021 at 9:16 PM
    Bigbird57
    Bigbird57 New Member
    I am running the 295-70-18 Ridge Grapplers on TRD Pro wheels. I had to trim 1" off the sides of the skid plate. I run a Body Armor winch bumper with Bilstein 6112's at 1.9". There is a CB 1/2" shim on the driver's side.
    I'm using factory UCA's.
    Turning right no rubs, good clearance on sway bar. Turning hard left the tire barely touches the sway bar.
    Hope this helps. Some just remove the swaybar, but with minor touching I'm keeping mine.
    Update: Ordered a set of BORA 1.25" spacers
    Upon members advice. I was able to move swaybar. No rubs!
  12. Aug 14, 2021 at 5:52 PM
    daveS67
    daveS67 New Member
    285/65 R18 BF Goodrich K02s just installed yesterday
    Hbjeff, Tundra@21, EN2TUNDRA and 4 others like this.
  13. Aug 14, 2021 at 7:08 PM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    Aren’t they also around 10lbs heavier per tire?
    I run 285/70/18 Nitto Exo Grapplers with no issues. I did install Coachbuilder Bumper shim because if I backed out of my driveway on full lock they’d just rub.
    D4x4TRD, EN2TUNDRA and jewsNbrews like this.
  14. Aug 14, 2021 at 7:11 PM
    Yes they are....I'll add that. :thumbsup:
    JeffMac[QUOTED] likes this.
  15. Aug 14, 2021 at 7:12 PM
    JeffMac
    Jeff
    South Florida
    Yea definitely not worth it imho.
  16. Aug 14, 2021 at 7:49 PM
    BlueCollar89
    BlueCollar89 New Member
    Wes
    New Mexico
    2021 Army Green Limited TRD Off-road Crewmax
    Tint, rear Firestone airbags, 285/70r18 Nitto Ridge Grapplers
    285/70r18 Ridge Grapplers on stock TRD Off-Road. Like mentioned earlier, size is close to the 295’s yet they are 10lbs heavier per tire so that made my decision. And no rubbing at all.
  17. Aug 14, 2021 at 8:27 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    I’d love to see more pictures if you have them. That first picture is very high quality!
    BlueCollar89[QUOTED] likes this.
  18. Aug 16, 2021 at 9:32 AM
    EN2TUNDRA
    EN2TUNDRA NOT SO New Member!
    North TX
    2021 Tundra TRD PRO Lunar Rock
    285/70/18 Nitto Ridge Grapplers
    All stock suspension
    No mudgards removed
    No spacers added
  19. Aug 16, 2021 at 5:12 PM
    BlueCollar89
    Wes
    New Mexico
    I appreciate that! Unfortunately I don’t have any others that turned out that good lol. This was just with an iPhone 11 Pro Max so I’m surprised it looks that nice
    CCLJ03[QUOTED] and jewsNbrews like this.
  20. Aug 16, 2021 at 9:03 PM
    Markful
    Markful New Member
    Mark
    Puyallup, WA
    '21 DBL CAB PRO LR, '08 dbl cab (gone)
    Glad to see this. I want this size in these tires. How do you like the ride? Any noticeable noise increase? How's the throttle response?
  21. Aug 17, 2021 at 2:31 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    29721D2F-3875-4D20-8C0C-5E7AB946619C.jpg All stock. 285/70/18
    AggiePhil, CCLJ03, WawaLunar and 4 others like this.
  22. Aug 17, 2021 at 2:32 AM
    RusPro21
    Don
    Pa.
  23. Aug 21, 2021 at 5:57 PM
    Marty McFly
    Morty McBoonJug
    :wave:
    I’m super late to the party lol I ran 285s for a long time and loved them. I did recently bump it up to 35s though. For what its worth, I am feeling the difference in mpg from 285s to 35s :annoyed:
  24. Aug 22, 2021 at 3:05 AM
    RusPro21
    Don
    Pa.
    Just curious what kind of gas mileage you getting with the 35’s. Yeah the only thing I’m planning on doing to get that wider stance is changing my wheels down the road with a different offset and still keep 285’s.
  25. Sep 2, 2021 at 5:08 PM
    wdw67
    wdw67 New Member
    2021 trd pro
  26. Sep 10, 2021 at 5:08 AM
    RusPro21
    Don
    Pa.
    Hey Steve, Can you answer this since you are running spacers. I’m looking at keeping my 285’s on with aftermarket wheels with 18 off set which pushes the wheels out which puts the tire about a inch past the fender do you think the tires will rub? Are your tires rubbing anywhere? Thanks.
  27. Sep 10, 2021 at 9:07 AM
    duerrs
    duerrs Semper Fi!
    I can't say for certain as I really don't know what my offset is running the stock wheels with the 1.25" spacers.
    With that said, when I first installed the new tires with the spacers, I had a slight rub on back fender skirt when turned left to full lock on the drivers front only. No rub at all on passenger side when locked in either direction. This remained for about 10,000 - 15,000 miles until tires wore some. I now have 44,000 miles on these tires with about 50% tread remaining.
    It was a really slightly rub. No wear/damage to fender skirt or tire. I knew it would it go away as tires wore down which it did.
    Hope this helps...good luck!
  28. Sep 10, 2021 at 9:33 AM
    RusPro21
    Don
    Pa.
    Thank you. With your spacers your tires are out about a inch correct? I have a 21 Pro with same wheels so I may keep the stock wheels and add spidertrax 1.25 that’s if your tires are sitting about a inch out. I don’t want them out to far but I think the truck looks better with tire out just a little for that wider stance. Also you are running the same in the front and back 1.25 so your tires are the same distance sticking out? I also have 285’s.
  29. Sep 10, 2021 at 10:02 AM
    duerrs
    duerrs Semper Fi!
    Yes, running spacers front and rear. Tires poke about 1" as you mentioned. When I was younger, I preferred more poke (offset), however, as I've gotten older, I don't care for that look anymore. This gives it just enough to look a bit more "tough" or "rugged" versus stock.
    RusPro21[QUOTED] likes this.
  30. Sep 10, 2021 at 10:09 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    I'm those295 guys on Visions18x9...Falkens Wildpeaks at3...Solid wheels and tires.. Of course a wee10lbs heavier..IMG_20210306_093030.jpg
