285/70/18 Clearance
Discussion in 'Suspension' started by esse_quam_videri, Jun 12, 2019.
  1. Jun 12, 2019 at 5:48 PM
    esse_quam_videri
    esse_quam_videri [OP] New Member
    Ryan
    2019 Super White Tundra
    Hi All - First time posting.
    So, I just got a 2019 TRD OR and added a 2.5/1 leveling kit and replaced the stock tires/rims with 285/70/18's on Fuel Vapors. No issues with rubbing anywhere except on the mud flaps while turning in reverse. Does anyone know if adding a top plate spacer will help? (to bring the front up to 3") And yes...I know I could just remove the mud flaps, but thats no fun, right?
  2. Jun 12, 2019 at 5:55 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hi and welcome from SoCal!!
    esse_quam_videri[OP] likes this.
  3. Jun 12, 2019 at 5:56 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  4. Jun 12, 2019 at 6:01 PM
    SunTundra413
    SunTundra413 New Member
    Ned
    Massachusetts
    2019 Black TRD Sport DC 4X4
    ARE Cap
    Welcome from Massachusetts.
    There are some vendors that sell shim kits to move your front bumper forward about 1/2" which should give you the clearance you need. It has been mentioned in a few threads on this forum. I think Boss 4X4s has one and maybe Coachbuilder too.
  5. Jun 12, 2019 at 6:07 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Generally not a good idea to stack lifts
  6. Jun 12, 2019 at 6:20 PM
    esse_quam_videri
    Ryan
    Thanks for the heads up. So, Toytec makes a 2.5" and a 3" leveling kit. It looks the difference between them is the 3" kit has the additional top plate spacer which brings it up an additional 1/2". Is this considered "stacking" lifts?
  7. Jun 12, 2019 at 6:22 PM
    esse_quam_videri
    Ryan
    The rubbing is coming from the mudflap behind the wheel, not the front...sorry. I removed the small mudflap attached to the bumper. Thanks though!
  8. Jun 12, 2019 at 7:39 PM
    ninjajay
    Spoolston, TX
    @Toytec Lifts can comment on that but it looks like their kit was designed to take the extra shim from the start
  9. Jun 13, 2019 at 7:54 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    The 3'' spacer is simply our 2.5'' internal coil spring spacer and our 1/2'' top mount spacer, we design it that way to insure proper ride quality overall and making sure that the internal coil spring spacer does not compress the spring down to much and causing coil clash.
    @csuviper ran our 3'' spacer kit while we were rebuilding his coilovers and he liked he the ride a lot.
    -David
  10. Jun 13, 2019 at 10:27 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Still running the spacer kit because i am too lazy to get the rebuilt coilovers back on. Hopefully soon i will.
    I have the TRD sport stock shocks with the spacer kit. It really is amazing for the price. Ride is really good.
  11. Jun 14, 2019 at 1:23 PM
    esse_quam_videri
    Ryan
    They did. It only happens on the left side, which leads me to believe my added weight is bringing it down enough to rub. Hopefully the additional lift will help...
  12. Jun 14, 2019 at 1:31 PM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Bam 8 exhaust 285/70 18 ridges 4:88 gears, auburn lsd 6112s SPC UCA
    I’m running the same set up and no rubbing in the rear. Are u running stock UCA?
  13. Jun 15, 2019 at 3:27 AM
    esse_quam_videri
    Ryan
    Yep.
  14. Jun 15, 2019 at 1:02 PM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    I think with with aftermarket UCA like SPC u have more adjust for higher caster and can move the wheel forward more
