285/65/R18 ??
Discussion in 'Wheels & Tires' started by Rngr188, Mar 18, 2018.
  1. Mar 18, 2018 at 6:11 PM
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I have done some searching but haven't come up with much. I think I've decided (after much research) on 285/65/R18 in the Toyo AT2 Extreme. I'm in a 17 TRD OR on factory whees and suspension. How much trimming if any will I need to prevent rubbing in this size? I read the sticky and it says some trimming might be necessary, for those running this size on factory wheels what did you experience? Thanks.
    LawJ likes this.
  2. Mar 18, 2018 at 6:19 PM
    15whtrd
    15whtrd Mr. Blonde
    I don’t have them personally but I know you will need zero trimming. There are quite a few threads already about what size tires will fit. You can fit a much larger tire with zero to minimal trimming. Check out tire calculator. They are only a half inch wider and a half inch taller than stock.
  3. Mar 18, 2018 at 6:21 PM
    15whtrd
    15whtrd Mr. Blonde
    My truck is stock and I know I can fit a much larger tire but I like to keep my gas mileage and sportiness of the truck. 285 is what I was going to do except for the fact that they are much more expensive, as they are an oddball/uncommon size.
    BTBAKER likes this.
  4. Mar 18, 2018 at 6:24 PM
    Rngr188
    Chad
    Harrison AR
    I was wanting 275/70 in a Ridge Grappler but think I'd be better off with the Toyo at2 and the 285/65 Is offered in the Extreme version 275/70 Is not.
    15whtrd[QUOTED] likes this.
  5. Mar 18, 2018 at 6:26 PM
    15whtrd
    15whtrd Mr. Blonde
    Without doing a search, what is the extreme version?
  6. Mar 18, 2018 at 6:27 PM
    Rngr188
    Chad
    Harrison AR
    Larger sidewall and deeper tread from my understanding. Only offered in certain sizes.
  7. Mar 19, 2018 at 5:34 PM
    Rngr188
    Chad
    Harrison AR
    What size and tire are you running? Also when you say bigger what do you think would be max? I know the sticky says 285/65/r18. I'm not set on the AT2 or anything for that matter as I've considered RT, Ridge Grap, Trail Grap, etc. If I go AT2 I want the Extreme version which in there limited offerings of it would have to be 285/65. I really want 6112 at 1.9 setting but that might be a while and I'll definitely need to replace my stock tires before shocks can fit into my budget. With that said I'll need tires that will look good size wise when I am able to pull the trigger on shocks but still work on factory suspension.
  8. Mar 19, 2018 at 5:39 PM
    christopher43mx
    christopher43mx New Member
    I'm running 275/60/20 which is 33s,they r 1/2 " taller and 1/2" narrower . I have 0 rubbing issues. I think you should be fine
  9. Mar 19, 2018 at 5:39 PM
    15whtrd
    15whtrd Mr. Blonde
  10. Mar 19, 2018 at 6:16 PM
    Rngr188
    Chad
    Harrison AR
    That's about equal to 285/65/r18 vs the stock 275/65/r18
  11. Mar 19, 2018 at 7:02 PM
    Rngr188
    Chad
    Harrison AR
    I' assuming a 33x12.50r18 isn' going to work on factory OR wheels and suspension correct?
  12. Mar 24, 2018 at 9:42 AM
    LawJ
    LawJ New Member
    Law
    2014 Black Crew Max 5.7
    2.5 leveling kit, 285/65/18 on factory rims
    Any pics of 285/65 18 on stock wheels.... that’s exactly what I’m putting on Tuesday
    BravoDeltaRomeo and heytat like this.
  13. Mar 25, 2018 at 7:56 PM
    Cisko213
    Cisko213 New Member
    So Cal
    2016 Tundra TRD Pro
    Retrofit Headlights, Baja Design Fogs
    Make sure you post pics!! Im looking into this set up but i'm still between AT2 Xtreme or KO2
    heytat and 15whtrd like this.
  14. Mar 25, 2018 at 8:12 PM
    Rica25
    Ricardo
    Tulare
    I just mounted 275/65 18 on mine about 2 weeks ago but when making sharp turns about 40 mph my traction control is kicking on so the tire shop I purchased them at told me if it didn't go away they would swap my tires for new ones to see if they might be defective but if I do swap them I am ordering 275/70 18 if they are available.....i will be doing this tomorrow the traction kicking on the highway exit is been happening every day for the last 2 weeks....so it's time to try another set and test
    LawJ likes this.
  15. Mar 25, 2018 at 8:19 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    285/65r18 KO2's on stock wheels
    DGempis11, TundraT, LawJ and 2 others like this.
  16. Mar 25, 2018 at 8:21 PM
    Cisko213
    Cisko213 New Member
    So Cal
    2016 Tundra TRD Pro
    What tire Brand and model specifically
  17. Mar 25, 2018 at 8:23 PM
    Cisko213
    Cisko213 New Member
    So Cal
    2016 Tundra TRD Pro
    This KO2 setup might be the way I go. BFG's are owned by Michelin and are easier to buy and replace if needed than Toyo or Nitto!
  18. Mar 25, 2018 at 8:32 PM
    Rica25
    Ricardo
    Tulare
    Installed the Toyo AT2 275/65 R18
  19. Mar 25, 2018 at 8:35 PM
    Cisko213
    Cisko213 New Member
    So Cal
    2016 Tundra TRD Pro
    Yeah thats a bummer, I hope they find something wrong. How can you not exit off a freeway at 40mph. Thats not acceptable.
  20. Mar 25, 2018 at 8:37 PM
    Rica25
    Ricardo
    Tulare
    It's a loop turn........but my previous tires were identical in size and have not modified anything since previous tires were Cooper at3
  21. Mar 25, 2018 at 8:38 PM
    Rica25
    Ricardo
    Tulare
    equin likes this.
  22. Mar 25, 2018 at 8:39 PM
    TheBeast The Beach
    I would get the 295/70/10 AT2 xtreme :).. @BlueBottle has them :spy:
    Black Wolf likes this.
  23. Mar 25, 2018 at 8:41 PM
    Rica25
    Ricardo
    Tulare
    They look bad ass but don't want to waste so much fuel or really have to modify much......also this truck is paid for so I'm thinking about getting next gen truck or maybe 2017 next year
  24. Mar 25, 2018 at 8:44 PM
    Rica25
    Ricardo
    Tulare
    I've had this truck since new and has been great not much replaced in parts as of yet.....but I really like the body of 3rd gen but for me I didn't really want to throw money away when there is no difference as far is tranny or engine ...... besides cosmetics
  25. Mar 25, 2018 at 9:16 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    You have them too :spy::spy:
    Did they do the zero point calibration? If they didn’t that can be why your tc is going off. My tc doesn’t go off on offramps and I drive aggressively.
    I would wait for the next gen. Should be out in the next few years.
    TheBeast[QUOTED] likes this.
  26. Mar 25, 2018 at 9:19 PM
    Rica25
    Ricardo
    Tulare
    What do you mean point zero calibration?
  27. Mar 26, 2018 at 10:11 AM
    Rngr188
    Chad
    Harrison AR
    Any lift?
  28. Mar 26, 2018 at 10:25 AM
    Backslider
    Tooele, UT
    At that time it was just a 2" level kit.
  29. Mar 26, 2018 at 10:36 AM
    Rngr188
    Chad
    Harrison AR
    I have stock TRD OR suspension and wheels and was wanting to go this size in a Toyo AT2 as that comes in the Extreme model, just worrying about rubbing issues. I know it's only 1/2" taller and 1/2" wider but still don't wont to have rubbing. Looks like my 6112 or 5100 lift shock budget is going to have to wait a bit but I'll be needing tires in roughly 10k miles as my factory Michelins are getting pretty worn.
  30. Mar 26, 2018 at 10:45 AM
    10 is a pretty small rim.... :bananadance:
    JRPro and TheBeast[QUOTED] like this.
