275/70-18 BFGs or 285/70-18 or Method MR309 Grid with 150.00 spacing?
Discussion in 'Wheels & Tires' started by notatallcool, Oct 15, 2019.
  1. Oct 15, 2019 at 11:29 AM
    notatallcool
    notatallcool [OP] New Member
    2019 Tundra TRD pro double black
    none yet
    I just bought a 2019 Pro and I purchased method grids 18x9 with a 150.00 offset. Discount tire said I should not go bigger than 275/70-18 due to rubbing with these wheels.(Also better availability) Can someone offer advice, I will have these installed tomorrow afternoon?
  2. Oct 15, 2019 at 11:53 AM
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    +0 or +18 offset? I think those are the Method Grid 18" wheel offsets for the Tundra.
    5x150 is the bolt pattern.
    With that said, I run 18" Method NVs with a +25 offset and 275/70/18 tires...I have a 2.2" front lift (much like the Pro's lift). I have NO rubbing with my setup and I have a 33" tire. Granted, my tire is 275mm wide. If you go to a wider tire (285) or taller (34" or higher) then you have to worry about rubbing as offset and lift affect it.
    275/70/18 = 33.2" diameter
    285/70/18 = 33.7" diameter
    Going with a wider tire may LOOK great, but it can cause rubbing issues as well.
    831Tun and notatallcool[OP] like this.
  3. Oct 15, 2019 at 11:55 AM
    notatallcool
    none yet
    my bad 5.75 back space and 18mm offset
  4. Oct 15, 2019 at 12:00 PM
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    Personally, you have A LOT more choices at 275/70/18 and they are cheaper. Here is a side shot with a +25 offset and 275/70/18 tires:
    MDHinSD and redhat like this.
  5. Oct 15, 2019 at 12:04 PM
    notatallcool
    none yet
    Ok great! Thank you, I'm getting out of a 2017 Raptor and these shoes are pizza cutters.
  6. Oct 15, 2019 at 12:06 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I think either size is fine. I just can’t believe you don’t want the bitchen 2019 pro wheels
  7. Oct 15, 2019 at 12:06 PM
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    you have a lot of choices at 295/70/18 as well, but they are 20mm wider and 1" taller than the 275/70/18s...so they WILL rub with a +18 offset. You will have to remove and/or mold plastic to make them fit. Maybe some small cutting.
  8. Oct 15, 2019 at 1:14 PM
    notatallcool
    none yet
    Im not a fan brother.. but they are for sale for $1750. obo
  9. Oct 15, 2019 at 1:14 PM
    notatallcool
    none yet
    these are going on tomorrow
    drobb, tbutler, yoshi82 and 2 others like this.
  10. Oct 15, 2019 at 1:32 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    For Gods sake SHOW US when it’s done.
  11. Oct 16, 2019 at 1:36 PM
    notatallcool
    none yet
  12. Oct 16, 2019 at 1:43 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2024 Tacoma TRD OR
    Looks good, still amazed you went to that from a Raptor tho.......
  13. Oct 16, 2019 at 4:07 PM
    CCLJ03
    Craig
    You pay for a lot of things you never use on a Raptor.
  14. Oct 16, 2019 at 4:09 PM
    CCLJ03
    Craig
    Yeah I’m going to need to see more of this. Looks awesome!!!
  15. Oct 16, 2019 at 4:40 PM
    Tundra blue
    Tundra blue New Member
    2017 sr5
    Level kit different wheels tires
    Hey have2017 tundra sr5 TRD one rims 18 with a3inch leveling kit want to bring rims and tires out to match flairs on truck not sure what sizes and how big tires can go would like 295-70-18 and in put anyone
    notatallcool[OP] likes this.
  16. Oct 16, 2019 at 9:40 PM
    notatallcool
    none yet
    I used the crap outta my Raptor, and did a lot of off roading. Hope to get a gen2 next year.
  17. Oct 17, 2019 at 3:20 PM
    CCLJ03
    Craig
    So tundra for a year then back to raptor?
  18. Oct 17, 2019 at 3:54 PM
    Blueknights75
    Ron
    Clayton, NC
    Where are you located to pick up these wheels?
