275/55R20 Wrangler Duratrac Pressures
Discussion in 'Wheels & Tires' started by DigbyPotter, Aug 23, 2019.
  1. Aug 23, 2019 at 9:22 AM
    DigbyPotter
    DigbyPotter [OP] New Member
    Denham Springs, LA
    MGM 2019 SR5 CM TSS Black 4.6L 4x2
    I'm running the factory Duratracs and the door sticker says 30 psi front/33 psi rear.
    At those pressures they just look low to me. Am I crazy?
  2. Aug 23, 2019 at 8:13 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    No. You're not crazy.
    That tire at those pressures will support max GVWR.
    Do they "look" low like there is too much sidewall bulge on the bottom? If so bump them up a few. Maybe 36. Too much higher than that you'll affect ride quality.
    DigbyPotter[OP] likes this.
  3. Aug 23, 2019 at 9:36 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My wife’s car says 35psi. I run them 45 front 38 rear.
    An old school alignment guy I go to told me that the manufacturers recommend too low of a rating for plush ride and better braking. Not sure if the braking part is true but tire wear has improved dramatically by adding more pressure to her fronts. 35 was burning the tires out.
    Pump your tires up to 45 and do a chalk test. I run E rated at 55 front and they are good.
  4. Aug 24, 2019 at 4:26 AM
    DigbyPotter
    Denham Springs, LA
  5. Aug 24, 2019 at 4:53 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Discount Tire said to run 42 in Duratracs on my Tacoma. Door sticker for my BFGs says 46 but I run 50. I would try 46. At the normal door sticker PSIs you are going to wear the outer edges and get worse MPGs.
  6. Aug 24, 2019 at 6:21 AM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Had the same question myself this week. I’ve got these on my 2019. Had 285/55/20 KO2s on my 2016. Got 2-3 miles better on my 2016. Went to discount tire and they recommended 38.
  7. Aug 24, 2019 at 7:06 AM
    DigbyPotter
    Denham Springs, LA
    Are y’all running the same pressure in all four or staggered lower in the fronts? What are the pros/cons of either way?
  8. Aug 24, 2019 at 9:04 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I run 55 front and 40 unloaded rear. Feels good.
    You need the tire to have proper contact of the road with the whole tread. Too high and youre just riding the center, too low and it’s just riding the edges, sapping your mileage. If it is too high you will be breaking the tires loose constantly, and i will be bucking like a horse
  9. Aug 24, 2019 at 9:48 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    LOL y'all talking all these crazy air pressures you run with E rated tires.
    I don't see where he asked y'all what you run in your tires.
    The 275 Duratracs max out at 51 and will hold max weight at 36psi.
  10. Aug 24, 2019 at 9:56 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I’m giving an example that the door pressure doesn’t always match what you need. Not did i tell him to run 55. I suggested doing 45 and testing it because i was very aware that his load rating wouldnt be that much higher than that.
    Toyota’s door recommendation is hogwash. Just is
