2024 Tundra Non-JBL - How many channels?
Discussion in 'Audio & Video' started by FerrisWheel, May 15, 2025.
  1. May 15, 2025 at 6:14 PM
    FerrisWheel
    FerrisWheel [OP] New Member
    Bob
    2024 Tundra SR5
    How many channels are you guys setting up in your builds and how are you arranging them?
    3 (front, rear, sub)?
    5 (FR, FL, RR, RL, sub)?
    I would assume 5 would produce better sound but also come at a higher price tag. I'm laying out how I want to upgrade my son's non-JBL 9 speaker system. Any recs/tips appreciated.
    Thanks!
  2. May 15, 2025 at 6:48 PM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    I recently completed an install in my 22. I have the non-jbl 9 speaker system with 14 inch screen on a sr5.
    I set up 5 Chanel’s fr, fl, rr, rl and sub. I used the Jl stealth box as the sub, and JL c3-650’s front and rear. I set them up as components and running them passive. These speakers can also be set up as coaxial speakers. This is powered by an Audiocontrol d5-1300 amp. Although the amp has DSP built in, I didn’t see the need for more wiring and extra amps/channels running it active. I also deleted the front center speaker.
    Nice and loud. Great bass and super clean sound. Everyone that has heard it has complimented the sound quality.
  3. May 15, 2025 at 7:01 PM
    FerrisWheel
    Bob
    2024 Tundra SR5
    Thanks for the rundown! I’ve been looking at a 3 channel setup due to simple wiring with harnesses from TT/others but also researching the 5 channel. Thanks again
  4. May 16, 2025 at 3:47 AM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    You can use this harness from Amazon or crutchfield. It works for two or four Channels.
    PAC LPHTY02 LocPro Advanced T-Harness for Select Non-Amplified Toyota 2018-Up https://www.amazon.com/dp/B0BYPMKR4T
    if you are adding an amp the also have a wiring extension kit.
    PAC LPHEXT17 LPH LocPRO 17... https://www.amazon.com/dp/B0CL9V56TL?ref=ppx_pop_mob_ap_share
  5. May 16, 2025 at 7:15 AM
    FerrisWheel
    Bob
    2024 Tundra SR5
    Thanks again Soflo!
    Soflo likes this.
  6. May 17, 2025 at 7:33 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    8 channel vxi800 (3 ways up front and rear 6.5 coax on their own dedicated channels) mono RD1000.1 for the two subs
