2024 5.5 bed bike options
Discussion in '3rd Gen Tundras (2022+)' started by dano9258, Dec 15, 2023.
  1. Dec 15, 2023 at 7:19 AM
    dano9258
    dano9258 [OP] New Member
    2024 Limited 4x4 OR Pkg
    MX4 Cover
    We just bought 3 mountain bikes and we’re trying to figure out how to transport them. We have the Bak MX4 installed so it would have to be some solution with that up against the cab. I’ve thought about getting a bed extender and using the rails on the side somehow? Any idea or photos?
  2. Dec 15, 2023 at 7:21 AM
    dano9258
    MX4 Cover
    I’d rather use the bed somehow. And I don’t want cross bars because then we can’t open the cover.
  3. Dec 15, 2023 at 7:24 AM
    Hella Krusty and Hbjeff like this.
  4. Dec 15, 2023 at 7:44 AM
    Powder Hound
    Powder Hound New Member
    2015 Limited TRD Double Cab
    Have a look at some fork mount rail attachments. Swagman has one, The Claw. You can purchase high end attachments or budget ones, depends on how much you wanna spend. You can easily remove them during the off season. Tailgate pad is super easy.
  5. Dec 15, 2023 at 8:14 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    I've been using an original Bike Tight system for years, but they went out of business long ago. Saris makes the same thing - heavy extruded aluminum boards with t-slots. You can put dropout mounts in them, I like the RockyMounts option. Nothing is hard mounted so easy to pull in and out when you don't need them.
    https://www.amazon.com/gp/product/B000BTA6NG?ie=UTF8&th=1
    https://www.amazon.com/gp/product/B019709MXO?ie=UTF8
    I carried 3 bikes in a 5' bed Tacoma and have carried 6 in my 6.5' Tundra with room for a cooler and gear. The rubber bed mat was mandatory in the composite Tacoma bed to keep it from sliding around. You just have to find a way to manage the front wheel storage.
    Jorts likes this.
  6. Dec 15, 2023 at 8:17 AM
    dano9258
    MX4 Cover
    I've read those can scratch up your paint over time. I'm really looking for something in the bed where the mount attaches to the factory rails and the rear tire can just sit on the tailgate. But I haven't found anything like that yet.
    I don't know if that will work because of the Bakflip MX4 we have installed? The front of the bed is taken up about 8" with the folding cover, so I don't think a bike could reach that front rail?
  7. Dec 15, 2023 at 8:22 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I use three of these when we go on vacation. Remove front wheel on each bike and attach front forks. They're held into the utilitrack with t-nuts. Works great and very secure.
    https://www.amazon.com/MUQZI-Release-Bicycle-Installation-Adapters/dp/B0BY1H2PMS?crid=3HJQF78PCU06G&keywords=fork+mount+bike&qid=1702657233&sprefix=fork+mount+bike+%2Caps%2C184&sr=8-3&th=1
    They can fit sideways in the bed except at the wheel wells. Not sure you can fit three in the bed regardless if you are intent on keeping the cover on. If you want to have the best of both worlds I would suggest the diamondback cover and install the bike mounts on top of the cover. Or get one of the covers that can be folded up against the cab of the truck - I had one and the front rails were accessible that way.
  8. Dec 15, 2023 at 8:30 AM
    dano9258
    MX4 Cover
    You think 3 bikes with the front wheels taken off would fit sideways to attach to the side rails? We don't have the bikes yet, should be arriving next week so I can't verify yet. We just spent $1000 and love the MX4, so getting rid of it is not an option. If they would all fit sideways using the side rails, that would be ideal, just not too confident (2 of the bikes are 24" and 1 is 27.5%).
    I like this idea but is the track just laid on the bed of the truck? Is there nothing securing the bikes in the bed then?
  9. Dec 15, 2023 at 8:31 AM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    I took a 2x8 and attached several of the mounts like the above and mounted them on the board. Remove the front wheels, attach to the mounts and use a couple of ratchet straps across the top to secure the bikes/board to the bed. All told, it was ~$55 for 4 mounts and I think I had the 2x8 laying around. And it's easily removable, since it doesn't attach to the bed.
  10. Dec 15, 2023 at 8:33 AM
    dano9258
    MX4 Cover
    Ooh I like this idea! Does the tailgate close with the cover flipped up or would I need to keep the tailgate down you think?
  11. Dec 15, 2023 at 8:38 AM
    Tbrandt
    Tristan
    Kansas City
    Yes, it's just laying in the bed. It has rubber feet, but can slide around if you're driving on rough roads.
  12. Dec 15, 2023 at 8:39 AM
    shawn474
    MoCo, Maryland
    Not likely to fit three sideways with the wheel wells and the bakflip intrusion. Are you 5.5' or 6.5' bed? But you could try. I would swap sides of the rails - meaning use the driver side of the bed for the first bike, use the passenger side for the second bike and the driver for the third.....that way you can overlap the handlebars and save space. Thats what I do and it works very well.
  13. Dec 15, 2023 at 9:01 AM
    dano9258
    MX4 Cover
    We have a 5.5 bed. So if you have a 6.5 and it's tight with three, we might not be able to do that.
  14. Dec 15, 2023 at 9:15 AM
    jhtram
    jhtram If I'm curt with you it's because time is a factor
    Jay
    Raleigh, NC
    2023 Lunar Rock Tundra Limited TRD
    OEM TRD Lift Maxxis RAZR AT LT285/65R20 tyres Spidertrax 1" Spacers Retrax Pro XR Tonneau Bumpershellz 'stache overlay TRD Pro Fender Flares Yakima Overhaul HD Bed Rack OEM Blackout Overlays aFe Front Tow Hooks Talon's Cat Shield Undercover SwingCase Toolboxes TufSkinz Console Cover (Matte black) ScreenProtech LCD and instrument cluster protectors Tailgate & bumper vinyl inserts (texas decal king)
    Though I know its not what you want, honestly a hitch rack is your best bet. If that is not an option then the tailgate pad is probably next. I got to see one up close recently....
    22whatwedo and Tundrastruck91 like this.
  15. Dec 15, 2023 at 9:43 AM
    jhtram
    Jay
    Raleigh, NC
    1UP with a RakAttach is my go to for bike hauling when I need to access the bed. There are cheaper options but I got rear ended in the wreck above with my 1Up and 4 bikes on the back and the 1up saved my truck. The rack was bent and 3 bikes had cracked frames but the truck only had a small dent in the tailgate from a bike pedal.
    22whatwedo likes this.
  16. Dec 15, 2023 at 9:45 AM
    shawn474
    MoCo, Maryland
    I have a 5.5 foot bed but have full access to the bed when transporting the bikes
  17. Dec 15, 2023 at 10:23 AM
    PKFan
    I have a DC, so a 6.5' bed, but with the front wheels off, I doubt there'd be any issue with being too long to fit in your bed.
    dano9258[QUOTED][OP] likes this.
  18. Dec 15, 2023 at 12:04 PM
    Hella Krusty
    Hella Krusty New Member
    I use a THULE gate matt. I had 3/m put on my tailgate so the cover doesnt touch the physical paint. I have The OEM Toyota tonneau and my XL Rocky Mountain Instinct with 29's fit fine. I have had 5 bikes ( all adults) back there
  19. Dec 15, 2023 at 3:05 PM
    dano9258
    MX4 Cover
    Yea, don't want to do paint protection in order to put a cover on the tailgate. That's why im looking for solutions for them in the bed with the cover up.
    Hella Krusty[QUOTED] likes this.
  20. Dec 15, 2023 at 3:35 PM
    901tundra
    901tundra New Member
    Memphis, TN
    2023 Magnetic Gray Limited TRD Off-road
    - Color-matched grille and rear bumper insets - 1-inch Cornfed front spaces - TRD grille with light bar and amber marker lights - Debadged
    Tundrum74 likes this.
  21. Dec 15, 2023 at 6:21 PM
    dano9258
    MX4 Cover
    Those won’t work with a cover though, right?
  22. Dec 15, 2023 at 8:33 PM
    901tundra
    Memphis, TN
    no, but just wanted to share if others are looking.
  23. Dec 16, 2023 at 8:08 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    We bolted some upright bike carriers to our DB cover on our Ridgeline. Worked great! Our focus was to keep the front wheels on due to the disc brakes. We also wanted some protection from bug splatter. Our bikes are generally pretty expensive so using a hitch mount wasn't ideal to make the bikes the new rear bumper. Also, lots of road muck comes up from the back with our wet weather.
    I am doing the same thing with with the Tundra and want to carry 2 kayaks and 2 bikes on the cover.
  24. Dec 16, 2023 at 2:09 PM
    dano9258
    MX4 Cover
    Pictures?
  25. Dec 16, 2023 at 3:39 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    @dano9258 here are a few shots.
    Just incase you couldn't tell the difference :)
    The Tundra is my current setup and when things slow down, I will get the bike carriers on there as well. The kayaks are 12' long and about 50 lbs each.
    The Ridgeline has a much smaller bed area at 5'. I added aluminum blocks to raise up the standard Thule crossbars and put the upright bike holders on.
    With the Tundra, I intend on carrying the kayaks and bikes at the same time. Just working on what that looks like for space on the cover.IMG_8084.jpg
  26. Dec 16, 2023 at 4:20 PM
    dano9258
    MX4 Cover
    Thanks. On a side note, how do you like the Marin bike?
  27. Dec 16, 2023 at 6:47 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    It’s my wife’s, I built it up from parts and have some nice parts on it now. Sram ASX 1x12 mullet. Roval carbon wheels, enve stuff and red shift. It is a Cortina CX Pro.
    Super light and fast bike.
    My gravel ride is a Scott Addict Gravel 10. It is nice and light as well. With Campy WTO 45 wheels and Kogel parts.
    I won’t even talk about my road bike!
    dano9258[OP] likes this.
