2023 tundra TRd pro Gas mileage
Discussion in '3rd Gen Tundras (2022+)' started by Mountainlord, Jul 19, 2023.
  1. Jul 19, 2023 at 8:40 PM
    Mountainlord
    Mountainlord [OP] New Member
    I have the wescott 3/1 lift and 35s and my mpgs is pretty bad, getting 11-12 on average. Am I the only one ?
  2. Jul 19, 2023 at 8:45 PM
    violetkibbles22
    violetkibbles22 New Member
    2022 tundra
    It’s a giant brick rolling down the road with heavy tires. Im getting 16 with 34s and level in the front and 1 in the back
    ryanwgregg and Mountainlord[OP] like this.
  3. Jul 19, 2023 at 8:46 PM
    Mountainlord
    yeah I expected it to be bad but not this bad. I’ve heard some getting 14-15 running on 37s…
  4. Jul 19, 2023 at 8:55 PM
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    I’m on metric 35s but I kept the weight low on each tire rim combo . I only went up like seven pounds each wheel . Averaging 16.7 across 7 tanks now . What tire did you go with ? Did you adjust for the bigger tire size for mpg calculations?
    Mountainlord[OP] likes this.
  5. Jul 19, 2023 at 8:59 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    I’m getting the very same mileage on Fuel Blitz which I think weight around 32 lbs and 295/70 r18 Falkens….
  6. Jul 19, 2023 at 9:01 PM
    Mountainlord
    I’m on STT Pros 305s and wheels are stealth custom series F5s … haven’t adjusted for the bigger tire. Got anymore info on that on how to do that ?
    I’m at 5k miles… I’m gonna try and increase my tire pressure for daily driving too see if it helps
  7. Jul 19, 2023 at 9:03 PM
    Mountainlord
    PBNB and 22whatwedo like this.
  8. Jul 19, 2023 at 10:11 PM
    Durtywrench
    Lou
    23 Tundra platinum
    None
    Go to this site . Tiresize.com Input your original tire size and your new size . Find out what percentage difference it is . Write that down .
    Now even you go through a tank and you divide your mileage against how many gallons filled up.. multiply that number by whatever percentage you got . In my case
    340 miles divided by 21.1 gallons = 16.113 multiply that by 7% ( my difference ) =1.12 . I add that 1.12 on 16.11 so my mpg is 17.23 . That was my higher tank in my average .
    I’m not a genius so if someone finds something wrong in my math I promise to end my life promptly
  9. Jul 20, 2023 at 6:18 AM
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2023 TRD PRO, 2024 Limited TRD OR, 2026 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    Did you buy it for the gas mileage?
    Mattedfred and Mountainlord[OP] like this.
  10. Jul 20, 2023 at 6:26 AM
    Dan_Gleesac14
    Dan_Gleesac14 New Member
    2023 Tundra SR5;2018 Tundra Platinum (SOLD)
    I have the same setup on my SR5 and my mpg went from high 19s down to 15s with easy driving. On average though, I am in the 11-13 mpg range I've noticed lately
  11. Jul 20, 2023 at 7:28 AM
    Mountainlord
    Thanks man I’ll check it out
    Durtywrench[QUOTED] likes this.
  12. Jul 20, 2023 at 7:32 AM
    Mountainlord
    no sir… but as I mentioned, I’ve heard from others running heavier and bigger tires and getting better mpg so was just curious what people were getting
  13. Jul 20, 2023 at 7:33 AM
    Mountainlord
    right on man
  14. Jul 20, 2023 at 8:20 AM
    Newm
    Newm New Member
    KC
    There are two things you never trust a mans word on...and the fuel mileage of his truck is one. :D
    Truck looks BA though!
  15. Jul 20, 2023 at 8:38 AM
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    When I had OEM Wildpeaks I was getting 22mpg on highway when under 70mph, sometimes even 23+ mpg. Not everyone will get that, sometimes its how you drive and sometimes its the vehicle. With 35s I am getting about 4mpg less according to the truck display, I saw as high as 19.5-7mpg on a 90 mile highway drive, but its averaging around 18. Calculate the extra size into your results to be more accurate, and remember you more than likely doubled the weight of the tires which greatly effects mileage.
  16. Jul 20, 2023 at 12:10 PM
    Mountainlord
    thanks man ! Yeah gonna try some of these. Going higher on tire PSI for daily driving and better gas
  17. Jul 20, 2023 at 12:12 PM
    Mountainlord
    oh wow yeah that’d be nice … gonna try some different things see if it helps mpg
  18. Jul 20, 2023 at 12:16 PM
    Tundrafarm
    Tundrafarm New Member
    22 hybrid limited 4x4
    I average 14mpg on 33’s Toyo oc from 16mpg on stock tires on my limited.
  19. Jul 20, 2023 at 12:33 PM
    king.cong.1119
    king.cong.1119 New Member
    13-13.9mpg highway calculated.
    10-11mpg city.
    stock gearing, 37s tires, metal bumper, tire carrier, bed rack, fully skidded.
    Y0TA PR0 and Mountainlord[OP] like this.
  20. Jul 20, 2023 at 1:00 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    also varies on where you live. Say I live somewhere where the speed limit if 65 and relatively flat vs where I live pretty much everything is uphill in any direction, windy as hell, and the highway is 80mph- I’m going to get worse mpg
  21. Jul 20, 2023 at 4:01 PM
    Mountainlord
    yeah true, I’m in Texas, pretty flat, sometimes it gets windy but we do have 85mph speed limits on some tolls
  22. Jul 20, 2023 at 5:18 PM
    Spoony1
    Spoony1 New Member
    2016 tundra platinum crewmax
    Trd pro grill color match door handles and mirror. 4 1/2 bds lift
    I have just over 5000 miles on my pro have nito ridge grapplers on it and am getting just over 16mpg. Dosent matter if I have it eco mode or sport seems to make no difference.
  23. Jul 20, 2023 at 7:02 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    I love these threads that throw out all these specs but ultimately ignore the biggest factor. Yourself. Your driving habits.
    Do you cruise to red lights on the chance that you will get the green to gradually build up speed again? Stop and go traffic? Do you take off easy from lights letting the hybrid work its voodoo? Or do you like to smash on hoes and rep the Turd Pro?
  24. Jul 20, 2023 at 7:20 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Your Yota makes those other two look bad!
    Yota! :muscleflexing:
  25. Jul 20, 2023 at 7:22 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    On 34s :D
  26. Jul 21, 2023 at 8:46 AM
    Mountainlord
    yeah you’re right man, after reading some of the replies I’ve been encouraged and have been more lighter on the pedal and seeing improvements
    Sixty9Four20[QUOTED] likes this.
  27. Jul 21, 2023 at 8:46 AM
    Mountainlord
    nice !
    Y0TA PR0[QUOTED] likes this.
  28. Jul 22, 2023 at 7:43 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Has anyone looked at the Toyota app under "Driving Pulse & Tips". It can show how much lead you have in your foot! If you are driving Miss Daisy or practicing for the F1 qualifier :)
    My perspective on MPG is a bit different since I use my truck for towing and recreation and always use ~93 octane fuel. My main work vehicle is an electric BMW which costs me $1 per day.
    I have Toyo AT3 O/C tires but found super light rims so I didn't gain too much weight on the corners. Heavy treaded tires will not equal good fuel economy. That is the last thing you should do it are looking for good mileage.
    If you are adding a new set wheels and tires for off-roading. Then keep the OE ones and use them during the highway driving and to/from work. Then swap out to the off-road tires for those fun weekends :)
  29. Jul 22, 2023 at 8:15 AM
    Blue Thunder
    Washington
    What other's claim to get for MPGs, in stock form or any set of mods is completely irrelevant. Even the exact same truck. You have no idea if they're lying, or their dash picture of a great MPG is after a 10 mile down-hill journey with a tail wind, what terrain they drive in or if they have the same driving styles. Gas only has so much energy, so you increase mass then you're going to burn more gas. Don't forget the EPA test mandates don't include 85mph speed runs...so nothing about those numbers on the window sticker has anything to do with your real world use. If you do absolutely nothing new to your truck and the mileage drops, then maybe you have a problem. Otherwise you're just seeing cause-and-effect...
    The only way to do a real side-by-side comparison is to have a bunch of guys fill up at the same gas station, do a nice long highway run together and then fill up again and compare notes. That's as close as you'll get to eliminating all other factors.
    Speed is my biggest factor. On my 16 mile commute to work, I get 14.x mpg in the winter in any conditions. During the summer, it's 15.5mpg at 70, 16 mpg at 65, 16.5 at 60 and I can get 17.x mpg if I have the HVAC off and hypermile. That trip is 80% highway and stop/go thru 5 stop lights. All those numbers are averaged from 5+ runs; not a dufus single 10-mile dash shot.
    IMO, the biggest changes you can make are in your driving style. As for the truck, you can just keep things optimized. Remove unnecessary weight. I only run top tier fuel to keep the system clean, which is going to be more important with your motor. I'd also only run premium fuel since you've got boost. You might see a small increase in MPGs from premium fuel, but never enough to justify the cost. I ran it in my Ecoboost and didn't see a MPG improvement but it felt more responsive.
    Good luck!
  30. Jul 22, 2023 at 2:17 PM
    Mountainlord
    didn’t know about this. Thanks man !
