2022 TRD PRO with 35" tires
Discussion in '3rd Gen Tundras (2022+)' started by TundraLifeIsGood, Oct 21, 2022.
  1. Oct 21, 2022 at 10:55 AM
    TundraLifeIsGood
    TundraLifeIsGood [OP] New Member
    I have a 2022 TRD PRO Tundra and I installed the 35" x 12.50" x 18 Toyo Open Country AT3 tires this morning. This was after trying to find information on this thread and on YouTube of someone with a 2022 TRD PRO Tundra that installed a 35" tire without the Westcott Lift or a spacer lift or any kind of suspension modification. I could not find anything. I do not want to modify the TRD PRO suspension as I like the current stance. I did not like the stock tires (Falken Wildpeak 285 65R 18) as they looked small on the truck. I respect others that are fine with this tire. It is a good performing tire. My personal preference is the 35" tire look.
    Absolutely no rubbing anywhere. In fact, the tire techs that installed the tires were surprised at how much room there was still in the wheel wells--as we were all aware of folks pushing back the liner and getting too close to the UCAs and needing to take out that metal part behind the front tires.
    FYI, the TRD PRO does not have this removable metal part and seems to be built a bit differently--almost as if it is understood that many of us would be swapping out to bigger tires. The offset for the BBS forged wheels also makes it possible to run the 35" x 12.50" without coming close to the top of the UCA. I still have about an inch of room up there.
    I'm pleasantly surprised at this and wanted to share this with other 2022 TRD PRO owners that might be debating going this route and worried that it might rub.
    BTW, in case any of you were wondering--the 35" Toyos are made in the USA.
  2. Oct 21, 2022 at 11:03 AM
    Tundra'25
    Tundra'25 Well-Known Member
    Wincent
    Southern California
    That's awesome!! Stuffing tires!
    Pictures, please? :worthless:
    ytank1 likes this.
  3. Oct 21, 2022 at 11:19 AM
    mass-hole
    mass-hole New Member
    Seriously. Pics or it didnt happen :boink:
    ytank1 and zonehenge like this.
  4. Oct 21, 2022 at 2:10 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    yep, 2022s will fit 35s with ease.
    ryanwgregg likes this.
  5. Oct 21, 2022 at 8:44 PM
    bigjuice
    bigjuice Researching and collecting parts…
    WA State
    2022 MGM Crew Max SR5
    So…no little crash bar in the back? What is there then?
    Pics as everyone has requested please.
    ytank1 likes this.
  6. Oct 27, 2022 at 6:19 AM
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    where are these pictures?
  7. Oct 27, 2022 at 7:25 AM
    Adam_1794
    Adam_1794 New Member
    MA
    22 1794 Metallic Black -Tow package/AVS/Air
    MY Toyo AT3s arrive tomorrow! :D Ended up going with 295/70/18s. Gonna run em on Method 705s
    LET'S SEE THE PICS!
    kilocharlie106 likes this.
  8. Oct 27, 2022 at 3:48 PM
    frichco228
  9. Oct 27, 2022 at 5:57 PM
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    Let’s see some pics!
  10. Oct 29, 2022 at 8:16 AM
    Lunagas11
    Lunagas11 New Member
    TX
    22 LunarRock TRD PRO
    TRD running boards TRD tonneau cover 35" BFG AT K/O2
    This is my setup. BFG AT K/O2 35x12.5R18 no lift, no rub, just had to remove the front mud flaps
  11. Oct 29, 2022 at 9:12 AM
    Wild Rose
    Wild Rose New Member
    2022 Toyota Tundra Limited TRD-Offroad 4x4 Supersonic Red
    Is there an option for trd pro's to have black headliners?
  12. Oct 29, 2022 at 4:33 PM
    Jkwolfe09
    Jkwolfe09 New Member
    Jerren
    I’d probably have brought a pro if they were smart enough to use black headliners I absolutely hate the light color
    jachal likes this.
  13. Jan 28, 2023 at 7:33 PM
    markjames07
    markjames07 New Member
    Mark
    2023 tundra trd off road
    295/70r18 with method nv 305 18 offset. No level kit !
    Stock 2023 tundra trd Offroad long bed. 295/70 r 18 with method nv 305 18 offset. No rubbing and pin back front mud flap. Poke is perfect in my opinion
  14. Aug 17, 2023 at 7:42 AM
    Jasontylers
    Jasontylers New Member
    JT
    22 Tundra TRD aka The Wizard
    TRD 3” Lift KMC Wheels Nitto Recon Grappler 35’s TRD side steps
    I have a 2022 TRD OR Limited on TRD 3" lift with 35's and IMO this pic does not look like 35's. Are you sure they're true 35's? BFGs' run smaller.
  15. Aug 18, 2023 at 6:11 AM
    Lunagas11
    TX
    BFG AT K/O235x12.5R18 Is what’s on the sidewall of the tire
  16. Aug 18, 2023 at 6:36 AM
    LR Pro 2022
    LR Pro 2022 New Member
    2022 LR Pro
    very nice
