2022 Transmission Cooler?
Discussion in '3rd Gen Tundras (2022+)' started by Genuine Cooling Systems, Dec 6, 2021.
  1. Dec 6, 2021 at 1:17 PM
    Genuine Cooling Systems [OP] New Member Vendor
    I haven’t had the chance to get my hands on a 2022 just yet to confirm. Does the 2022 Tundra come with a dedicated transmission cooler? Has anyone monitored their transmission temperatures while towing, off-roading, etc.
    If the need for a transmission cooler is there, I’ll be happy to design a transmission cooler kit for the 3rd generation.
  2. Dec 6, 2021 at 1:27 PM
    Kung
    KG, VA
    ...and here I was all ready to say "Lord not another transmission cooling system thread...." but you addressed the problem AND are presenting a solution.
    Hats off to you, good sir.
  3. Dec 6, 2021 at 1:36 PM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    Yes it has a dedicated transmission cooler.
  4. Dec 6, 2021 at 2:26 PM
    Good to know! Thank you.
    ryanwgregg likes this.
  5. Dec 6, 2021 at 2:31 PM
    Last of the V8
    Last of the V8 New Member
    21 limited Trd calvary Blue
    Rsi smartcap, predator steps, roadmaster suspension, nicks tyranny cooler. Rago dash mount plate. Console safe.
    Thanks Nick. I love the kit on my 21. Hopefully the new one doesn't just have a puck.
  6. Dec 6, 2021 at 2:36 PM
    racer01
    racer01 New Member
    Geoff
    Aiken South Carolina
    23' TRD Pro
    295/70-18 Nitto Recon Grappler, RB 20 running boards
    Anyone happen to have a pic or parts diagram? Been poking through pics and such now that I have ordered a 2022 and can't seem to find a picture of the cooler anywhere. Just curious as to size, if it is air to oil, where it is located, etc.
  7. Dec 6, 2021 at 3:15 PM
    stevj
    stevj New Member
    On a clear day, I can see Seattle from my house.
    Current RAM 1500 owner waiting for the new Tundra "hybrid."
    OEM location is typically within the radiator.
    That would make it a liquid-to-liquid exchanger.
  8. Dec 6, 2021 at 10:35 PM
    SLVR6
    SLVR6 New Member
    One integrated in the lower part of the radiator and one “puck”.
    I assume you work for a dealer to get those pictures?
  9. Dec 7, 2021 at 2:36 AM
    racer01
    racer01 New Member
    Geoff
    23' TRD Pro
    Awesome. Thanks for sharing. Very different than my 2008 Tundra (air to liquid in front of radiator), 2015 Tundra (air to liquid above of ac condensor) and 21' Land Cruiser (air to liquid similar to 2008 tundra). Good info!
  10. Dec 7, 2021 at 2:58 AM
    Mattedfred
    Mattedfred Toyota Fan Boy Since ‘04
    Ted
    Cambridge, Ontario Canada
    2023 SR5 TRD Sport DC 4X4 in MGM
    TRD Skid Plate/Running Boards, Bison Soft Rollup Tonneau, Thule Canoe Rack, Bedmat, Tailgate Black Insert Badge, Northwest Seat Covers Neoprene Custom Fit Front Row Seat Covers. Tailgate Mat
    Thanks Ryan! Sorry to have to ask it here but maybe you could help me find the answer. Do you know if the rea overhang is the same on every version of the 3rd gen Tundra or is their one configuration that has the least amount of rear overhang (distance from the back of the rear tire to the back of the rear bumper). Thanks!
  11. Dec 7, 2021 at 4:17 AM
    SLVR6
    SLVR6 New Member
    If you check the difference of the overall length and wheelbase on toyota.com for both wheelbases you get the same value. Knowing the front doesn't change you can safely assume the rear wheel to end of bed is identical on all variants.
    Mattedfred[QUOTED] likes this.
  12. Dec 7, 2021 at 4:35 AM
    Mattedfred
    Ted
    Thank you. I had observed what appeared to be some inconsistencies on the US and Canadian sites so I wasn't trusting their dimensions. I either misread them or they've been updated.
  13. Dec 7, 2021 at 5:47 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Good info here, looks like its not a stand alone cooler like we were told it was or many said it was going to be. Wonder what the temps are gonna be, hopefully tfl offers insight when they test there's.
  14. Dec 7, 2021 at 7:00 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I don't consider that a stand alone cooler, it's running next to the engine coolant passages within the radiator. The early gen 2 tundras had an actual stand alone cooler, my 2012 Tacoma has a stand alone cooler. 17 tundra has the integrated cooler and she runs hot when pulling, this will probably be the same.
    Trust86 and ryanwgregg like this.
  15. Dec 16, 2021 at 7:11 AM
    68rs75z28
    68rs75z28 New Member
    2020 tundra sr5 dc
    Most other manufactures use an in the radiator cooler. For a stock vehicle that is more than adequate due to the amount of surface area it has.... however... when you started adding high stall converters and making more power you need the capacity of a dedicated cooler in front of the radiator.
    Doxiedad likes this.
  16. Dec 16, 2021 at 9:09 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I agree with you other manufacturers do not that doesn't make it right. TFL I think had the f250 and Silverado with these similar trans cooler designs overheat on them. Temps run higher in systems designed like this just a fact. It is probably done for cost savings more then anything. My tundra had the combined setup and that thing ran hot pulling a trailer, I suspect this one will as well.
  17. Dec 16, 2021 at 10:19 AM
    68rs75z28
    2020 tundra sr5 dc
    Your tundra has a combined system like this? FIt wasn't in the radiator on the 2nd gens(14-18)
    I do agree with you an independent cooler is always going to be better, but the system where it runs to the radiator is much better than the crappy system on the 19-21.
  18. Dec 16, 2021 at 10:47 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Yeah mine isn't a stand alone either, 19-21 got rid of it altogether and have nothing at all. I think it was pre 2014 that had the actual stand alone trans cooler.
  19. Dec 24, 2021 at 5:27 AM
    racer01
    racer01 New Member
    Geoff
    23' TRD Pro
    Well apparently the integrated liquid-to-liquid cooler works better than no cooler on the 2.5's. TFL did a re-do of the Ike Gauntlet run with the 2022 in tow + mode now and tracked trans temps with a scangauge. The 2022 3rd gen showed 231 F peak temp at the top of the Ike pulling a little over 8k lbs vs 246 F on the gen 2.5 without a cooler. Video link timestamped to the trans temp discussion.
    https://youtu.be/I4g4t94wgvM?t=1423
    Of course this is a whole new transmission and cooler setup so I make no inferences as to if the cooling is "sufficient" and since I don't tow up the Ike I have no idea what temps that means I would see towing a race car on an open trailer (5k lbs) on the barely hilly (but hot and humid!) terrain of the south east but since it is at least some information and a reasonable comparison point to other TFL tests I thought I'd share. I also have a 2021 TRD Pro with no cooler and have a deposit and deal worked to trade it on a 2022 supposedly coming in mid Jan so I am mildly interested in the trans temp "issue" but really like seeing improvements in overall towing performance. That new engine sure looks like it is loafing along and is torquey and quiet!
  20. Dec 24, 2021 at 12:16 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    You have to also compare the outside ambient temps for the two as well. The 3rd gen they were pulling when snow was on the ground so I would expect that temp to be higher in the warmer months. I can't remember what the outside temp was like for the 2nd gen pull. Great that tfl is going to start tracking temps for us now, they should also include the outside temp as well for comparisons.
  21. Dec 24, 2021 at 12:27 PM
    racer01
    racer01 New Member
    Geoff
    23' TRD Pro
    It was low 50's at the top for the 2nd gen pull. Timestamp video shows outside temp in dash. Not perfect comparison, but better than apples to oranges that often comes up on the internets...
    https://youtu.be/I8upLk9jlcQ?t=428
  22. Dec 24, 2021 at 12:57 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    So for gen 3, toyota boxed the rear frame and re installed a trans cooler.
    Never ever fall for the “trust the engineers” BS again
    Alex38 likes this.
  23. Dec 24, 2021 at 2:28 PM
    ColoradoCub
    ColoradoCub New Member
    Keep in mind most of the 10 spd transmissions in the competitions trucks use a full synthetic ATF, I wonder if Toyota stuck with the old WS ATF for this 10 spd too, I’m guessing not.
  24. Dec 26, 2021 at 7:53 AM
    Toyota1234
    Jack
    Of course they could have down shifted and kept there trans temp down even lower. All these tests are in D.
  25. Dec 26, 2021 at 8:13 AM
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    Right... because a completely new design is what should be compared to an outgoing dated design. By that logic they never should have had a V8 either because they got rid of it in the new design. You should only "trust the engineers" if you are using the truck as they designated in the first place. Read the manual on the 2019-'21 (and probably the '22) and you'll see that they say it's primarily a passenger vehicle with some towing capability. The engineers built it to that spec. and the payload ratings show it. Then the marketing monkeys do what they do best and lie as legally as possible to advertise it in ways that it wasn't strictly designed for.
    The point is, the late model Tundras were never designed to be a towing monster/work truck every day of the week. That market segment is owned by the big 3 and Toyota isn't gunning to unseat them because they aren't going to play to the "I want it all" crowd. The Tundra is for people who OCCASIONALLY need a bust ass tow rig or to move something a bit heavier than a midsize can handle, but not every day. The fact that they aren't designed for that and still have stellar reliability after people go off thinking like cavemen "Truck has bed. Bed mean tow. Tow mean haul 50 foot trailer to compensate for tiny dick." and run the trucks harder than intended is a testament to the designs.
    Yes, we all miss the coolers. Yes, we all wish they hadn't removed them. Yes, we all think that having the cooler would have been better for the trucks long term. And, Yes, this is a dead issue that people still insist on whining about and it's getting old. It's been resolved. Add a cooler, or don't, but FFS quit bitching.
    RavingOx, OppoMojo and ColoradoTJ like this.
  26. Dec 26, 2021 at 8:18 AM
    LML 3500HD
    FIFY
    The Engineers didn't want to remove the external trans cooler. They also got ignored.
  27. Dec 27, 2021 at 10:26 AM
    mass-hole
    mass-hole New Member
    I really don't think its a big deal with these modern transmissions. The Ford 10 speeds get that hot too, even in the Superduty. I wanna say the F250 with the 7.3L Godzilla might have gotten up to 240F when it did the Ike so they clearly don't care if they are letting the Superduty do it.
    And I think a lot of it has to do with how they tune the torque converter. All the Toyota's I have ever driven were super liberal about unlocking the TC which is how you generate a tremendous amount of heat.
    The F150's, at least my 2014, almost never unlocks the TC in T/H mode.
