2022 List of issues
Discussion in '3rd Gen Tundras (2022+)' started by 5thgen, Feb 28, 2022.
  1. Feb 28, 2022 at 11:06 AM
    5thgen
    5thgen [OP] New Member
    Got this from a FB comment of all the current 2022 issues. It's a good reference point and check off list when buying the 2023.
    "Perimeter cameras falling off the mirrors or freezing up when it’s cold
    Trucks stalling and shutting off in the middle of the road
    Trim curling and peeling up off of the doors of top trim levels like Platinums
    Brake sensor failure
    Turbo actuator failures
    Improper window trim leaving a gap causing a nasty wind noise
    Rear bumpers install crooked and off to one side
    Plastic trim around the front door locks hanging lock mechanism
    Steering wheel buttons not functioning for some
    Fuel sending units failing or giving out inaccurate readings"
    Darkness likes this.
  2. Feb 28, 2022 at 11:33 AM
    Woodman427
    Woodman427 New Member
    22 Crewmax Ltd Shorty Mag Grey
    Add in...
    - Hood/tailgate installed off-center
    - Windshield installation issues causing cabin noise / creaks
    - Head unit/ speaker output failure
    - Screen freezing/locking up
    - Bluetooth connectivity issues
    - Composite bed warped at cab side
  3. Feb 28, 2022 at 12:46 PM
    boyders
    boyders New Member
    Looks minor enough, thank you! Can't wait for my Limited OR in May :)
  4. Feb 28, 2022 at 4:12 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    AC doesn't work upon arrival to dealer.
  5. Feb 28, 2022 at 4:39 PM
    Baldwin
    Baldwin New Member
    I must have a lemon because it has none of these issues.
    TMack77, jmay86, TTund16 and 17 others like this.
  6. Feb 28, 2022 at 5:04 PM
    TimboSlice15
    TimboSlice15 Another money pit....
    Timothy
    Holly Springs NC
    2022 Tundra SR 4x4, 2017 BRZ Limited w/ PP
    I have Android Auto issues that are really annoying.
    I have gone into low power mode 3 times, but never had a check engine light.
    Wind noise from drivers door near the mirror.
  7. Feb 28, 2022 at 6:21 PM
    5thgen
    Hard to believe you don't have the window trim gap/issue.
    ryanwgregg likes this.
  8. Feb 28, 2022 at 6:45 PM
    Supertech1
    Supertech1 New Member
    Reading all the negative posts makes me question whether I should back out of my 3/14 build. Then I see a post like this, laugh, and remember how much I enjoyed the test drive.
    Henry1jg, damnfingers and Medic343 like this.
  9. Feb 28, 2022 at 7:27 PM
    boyders
    boyders New Member
    Hey now if you're going to blindly believe social media issue reports you have to believe social media accounts of no issues.
    TMack77 and Henry1jg like this.
  10. Feb 28, 2022 at 7:49 PM
    5thgen
    A picture is worth a 1000 words.
  11. Feb 28, 2022 at 8:02 PM
    21CGtundra
    21CGtundra New Member
    Robbie
    SLC, UT
    2022 Midnight Black Tundra SR5 (Feb 22')
    I picked up mine tonight. It has the obnoxious wind noise also. Not a total bummer but annoying for sure. All seals seem to be installed correctly?
  12. Feb 28, 2022 at 8:08 PM
    Tundra-G
    Tundra-G New Member
    2022 Tundra Ltd 4x4 TRD Off-road
    My car has no issues…
    Actually had a few connectivity issues until I called Toyota and opted out of all data collection and services. It got rid of the profiles menu, and shows this now in the personal information area (see picture below).
    After this, all the connectivity issues disappeared. My iPhone CarPlay now connects seamlessly each and every time wirelessly when I start the car. It seems the issue may be the Toyota phone app and the over the air connectivity services.
    TMack77 and Tundrastruck91 like this.
  13. Feb 28, 2022 at 8:19 PM
    5thgen
    Can you all check to see if you have this issue? It appears Toyota got a ton of seals not cut to spec and decided to install it anyway.
    https://youtu.be/uNIniznaPIE
  14. Mar 1, 2022 at 1:52 AM
    Baldwin
    Baldwin New Member
    You're right about that one. The gap is probably there. I dont think its a defect though since they all seem to have it. My truck is nice and quiet and dry and no seals are popping off. I have no window trim issues as far as I'm concerned.
  15. Mar 1, 2022 at 6:34 AM
    21CGtundra
    Robbie
    SLC, UT
    I remember reading a few people had their speedometer off a few mph's. I can add myself to this list. Mine reads 2-3 mph higher than actual speed (confirmed with multiple apps).
  16. Mar 1, 2022 at 6:38 AM
    Retired...finally
    Maybe that's how the Gen 3 gets better MPG.:rolleyes:
    GODZILLA and 1UP like this.
  17. Mar 1, 2022 at 6:42 AM
    Breathing Borla
    Breathing Borla New Member
    2016 Tundra Platinum 4x4 Crewmax
    does your remote start work with teh app then or is that all gone as well?
  18. Mar 1, 2022 at 7:15 AM
    Tundra-G
    Tundra-G New Member
    Yes, it will not work any more since you will be severing all connections from Toyota to your car. I just did not want them to collect any data or be connected to my car.
    Not sure if some of the trims have remote start with the truck’s remote. That part should not be affected.
  19. Mar 1, 2022 at 7:17 AM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    You have to remember, unhappy people are much more likely to post a review or comment than someone where everything is perfect. I fall into this category as well. There is a good chance I wouldn't have even found this forum if I didn't have an issue with my new truck. I'd love to know the ratio, like 100 happy consumers per complaint or whatever it is.
    louscrw likes this.
  20. Mar 1, 2022 at 7:22 AM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I thought they all had remote start via keyfob? Press lock, lock, and hold lock button.
  21. Mar 1, 2022 at 7:28 AM
    Tundra-G
    Tundra-G New Member
    Have not tried it, lol. Will give it a try
  22. Mar 1, 2022 at 7:40 AM
    Tundra-G
    Tundra-G New Member
    the app data from satellites will be off depending which satellite they use. Your phone connects to one satellite at a time. You need a dedicated unit such as a RaceBox or a good radar detector, which connect to several satellites at once to get accurate data.
    I tried estimating my speed your way by using my phone and various apps after I put bigger tires. I noticed the phone apps can vary 2-5mph from the actual speed depending on where you are.
  23. Mar 1, 2022 at 6:48 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Ok, picked up my Platinum today after it was in the shop almost 5 weeks! During the walk around, I noticed 3-6 bumps on each of the black wheel well trim pieces. They caught the light like door dings but actually protruded outward. Toyota will be replacing all four I'm told. We couldn't determine the cause, possibly from the fasteners.
    My other issue was the infamous window seal problem. The passenger side rear seal sticks out on the end and will not snap into place. The driver's side rear seal has a large gap where the ends meet. They will be replacing these as well. The quality control from Toyota is really lacking on this series.
  24. Mar 6, 2022 at 5:43 AM
    pbmax
    pbmax New Member
    Pete
    I am 3 weeks in, 500miles with my Plat and the my rear window seals are short as others have mentioned. Another issue that just surfaced was my digital fuel gauge showed 1/2 tank Wednesday night and a full tank Thursday morning miraculously. Headed over to the gas station and put 11 gallons in and have driven 60 miles since and still shows full on the fuel. The miles to empty readout when down to 370 and now back up to 405.. I called Toyota to log the issue and my dealer to make them aware. Service advised me to drive it for a week or two to see what happens while they investigate. This is a bit annoying, however I'm confident these issues will be resolved. Overall I love this truck!
  25. Mar 6, 2022 at 7:11 AM
    Maharisc
    Maharisc w/ Maggie Mae
    Karl
    2022 Tundra Limited DC MGM TRD OR
    Build date: 12/11/21
    Troyboy84 likes this.
  26. Mar 6, 2022 at 7:15 AM
    DrZoidberg
    DrZoidberg New Member
    SATX
    Reserved everything
    The problem with the wind noise is I have seen 4 different “reasons.” I’d say 70% of the complaints are the drivers side seal.
    But TRD John is on the rear passenger door, I’ve seen the rear driver door and I’ve seen the drivers side mirror as the issue.
  27. Mar 6, 2022 at 7:18 AM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Is anyone having any leaking from a car wash, etc due to the weather seal issues? Particularly the issues in the front causing wind noise. As stated in my post above, I have the rear window issue, but don't see that causing a leak issue. I wish I could hear the wind noise complaint first hand; I know many people are more particular/sensitive about these things than I am. Seeing how I have the same visible issues as others with the rear window, it makes me wonder, do I have a wind noise issue and don't notice, lol.
  28. Mar 6, 2022 at 7:22 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    *Cringe....So happy I kept my 2018.
    THOR's and MT Madman like this.
  29. Mar 6, 2022 at 7:23 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum/Rock/Warrior Pro CM
    A.R.E. CX HD, Fox TRD Pro's, RW's 285/70/17
    Kind of a pain to have these issues but thank god for the early adopters to work out the small things.
    In the end, honestly, this list doesn't look much different than any of the other threads and problems on the 1,2,2.5 gen boards, except of course the turbo.
    -Tss/Pre-collision alerts
    -BSM sensor issues in cold weather
    -Steering rack recall
    -Airbag recall-
    -CamTower leaks
    -ABS problems
    -Dashboard showing foam, quality control
    -Window actuators
    -Moonroof issues
    -Windshield wind noise, sealant uneven
    -Transmission surging
    -Fuel pump
    -Stock battery early failure
    TMack77 likes this.
  30. Mar 6, 2022 at 7:38 AM
    DrZoidberg
    SATX
    Reserved everything
    I’ve only seen 1 or 2 water leak complaints. Never followed them to see origination or resolution.
