2021 Uneven rear ride height issue
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by ltsheets, Oct 7, 2021.
  1. Oct 7, 2021 at 10:03 AM
    ltsheets
    ltsheets [OP] New Member
    Logan
    2021 Tundra TRD PRO Lunar Rock
    So I just noticed today after unhooking a light camper, that the back of my truck is not level. The right side is sitting lower than the left. When I measured, the clearance from top of tire to top of wheel well was obviously different. Thoughts??
  2. Oct 7, 2021 at 10:11 AM
    dzznts
    dzznts New Member
    Tennessee
    2021 Lunar Rock Tundra TRD PRO
    Wow that’s like 2 inches “That’s what she said”
  3. Oct 7, 2021 at 4:59 PM
    ltsheets
    Logan
    Lol yeah.
  4. Oct 21, 2021 at 3:12 PM
    ltsheets
    Logan
    Anyone else?
  5. Oct 21, 2021 at 3:15 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Are your shackles binding on the low side or anything? Look under the truck and see if they’re about the same angle. That’s a big difference. I think my truck differs about a half inch.
    Hightide likes this.
  6. Oct 21, 2021 at 3:25 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I was surprised to see how much rear lean I had in my driveway. When I took it to completely level ground, sides were the same. Your front can affect your back as well, depending on suspension and the ground in the front.
    Ginsterkev likes this.
  7. Oct 21, 2021 at 3:27 PM
    ltsheets
    Logan
    Haven’t checked. Honesty not sure what I would be looking for regarding the shackles.
  8. Oct 21, 2021 at 3:28 PM
    ltsheets
    Logan
    Yeah less than an inch wouldn’t bother me much but this I can see with my eye is way off.
  9. Oct 21, 2021 at 3:30 PM
    alb1k
    Left Coast
    It's good
    2 is a lot. I had 1.5 from uneven ground. have you moved the truck and measured in diff locations?
  10. Oct 21, 2021 at 3:45 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Make sure you are actually on level ground. If still way off (inch or more) then have the dealer check it, if something is amiss they will fix your 21 under warranty.
  11. Oct 21, 2021 at 3:52 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Take a look under the truck and make sure your shackles are more vertical than horizontal. If the rear leaf eye is contacting the frame, something is not right.
    bulldog93, Hightide and ltsheets[OP] like this.
  12. Oct 21, 2021 at 8:05 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Also, never measure from the tire itself, measure from the hub.
  13. Sep 2, 2022 at 5:19 PM
    RickW
    RickW New Member
    Rick
    2018 Tundra SR5 Plus CrewMax
    Did you ever figure out if/what the problem was? I just realized the same thing on my 2018.
  14. Sep 3, 2022 at 10:22 AM
    Ginsterkev
    Ginsterkev Lessons not learned in blood are soon forgotten
    Kevin
    Pennsylvania
    2019 tundra Trd pro supercharged
    Tvs1900 magnuson blower Team rxp catch can Wescott designs collar lift on fox factory suspension Front and rear TRD sway bars
    Could not agree more with that statement sometimes you don't realize how uneven things are and that can effect the height
    Drastically I have a lowered car and lifted truck and my driveway shows on both those vehicals the side to side difference
    alb1k[QUOTED] likes this.
  15. Sep 3, 2022 at 10:31 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Check see if ur shock is leaking
