2021 Tundra Tail Light question
Discussion in 'Lighting' started by pjazz123, Nov 26, 2020.
  1. Nov 26, 2020 at 9:20 AM
    pjazz123
    pjazz123 [OP] New Member
    Hello all -
    I'm new to the Tundra world. I recently purchased a new 2021 Lunar Rock Tundra TRD Pro and have a question about the tail lights. I bought some aftermarket (smoked out) OEM tail lights that specifically said on the website that it fits 2014-2021 tundra's. I went to put them on my truck yesterday and found out that they don't fit. The aftermarket tail lights have two male push knobs on one side (that essentially lock in the lights in place), and on the other side, it's the standard screw mounts.
    It appears that the 2021 Tundra changed the stock tail light mounts that now requires the light to have two "female" push knobs (instead of male).
    Can anyone else confirm this on their 2021 Tundra??
    Thanks
  2. Nov 26, 2020 at 9:30 AM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    When the stock lights were removed did the pins detach from the taillight and remain in the body of the truck? A pic would be worth a thousand words.
    KingsAustin and GODZILLA like this.
  3. Nov 26, 2020 at 9:45 AM
    pjazz123
    I will take a picture later this afternoon. but to answer your question, yes everything detached as it normally should but as mentioned, the are two female ends instead of male ends. The standard pin's that we are used to seeing aren't present at all (even on the back end of the light). I did try to remove the plactic male housing to see if i could just jimmy-rig it but the fit was still off by about half an inch.
  4. Nov 26, 2020 at 11:16 AM
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
  5. Jan 7, 2021 at 3:57 PM
    rbrently
    rbrently New Member
    Hello PJazz123. Would you want to sell your factory driver side tail light since you bought new? I am needing one for my 2021 lunar rock.
