2021 tundra leak from bell housing
Discussion in '2.5 Gen Tundras (2014-2021)' started by manuel91744, Oct 21, 2021.
  1. Oct 21, 2021 at 5:35 AM
    manuel91744
    manuel91744 [OP] New Member
    Manuel
    2021 Toyota tundra
    None
    Newt to the forum glad I found it.. got a new tundra has 95 miles when I dropped it at the dealership hope Toyota can give me reassurance it will be taken care of.. any thoughts thank you 2FD46568-6498-4361-BD52-3F2723B00EF1.jpg
  2. Oct 21, 2021 at 6:12 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    I had that also on my 20. In the 14000 miles it has now, I’ve never seen it again.
  3. Oct 21, 2021 at 6:18 AM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    Had the same leak on my 2018, the rear seal holding plate was not sealed correctly, they dropped the trans and re-sealed the plate, leak gone.
  4. Oct 21, 2021 at 6:23 AM
    manuel91744
    Manuel
    2021 Toyota tundra
    None
    I’m glad they fixed it right just was crazy at 95 miles.
  5. Oct 21, 2021 at 8:50 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    Please let us know what the dealer says!
  6. Oct 21, 2021 at 1:45 PM
    manuel91744
    Manuel
    2021 Toyota tundra
    None
    The dealership has actually been great the truck was scheduled to be seen today which is the next day after I drop it off they brought it in the same day which was yesterday they call me tell me it was internal transmission leak some oil pump. It was an auto parts it would arrive probably in a couple days. My biggest concern is Built quality at this point something that I was thinking Toyota didn’t have a problem with
  7. Oct 21, 2021 at 3:19 PM
    ColoradoCub
    ColoradoCub New Member
    As far as build quality concerns, you aren’t driving a GM or Ford, just look at the many posts on this forum, look at how few of them actually relate to actual mechanical problems compared to the Big 3 forums. You just were unlucky , not much else can be said.
  8. Oct 21, 2021 at 6:28 PM
    manuel91744
    Manuel
    2021 Toyota tundra
    None
    Well I hope this is the only unlucky thing I get from her
  9. Oct 22, 2021 at 5:05 AM
    blanchard7684
    blanchard7684 New Member
    my gosh what happened to the bottom? looks like someone dragged that around a garage floor before installing.
    anyway...check coolant reservoir as this can also be symptom of coolant leak at throttle body.
  10. Nov 22, 2021 at 6:59 PM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Towel for a Seat Cover
    I made a thread about an identical leak on a 2021 with 200 miles
    Happened today and I am l taking it in ASAP to the Dealer
    Used your picture for my thread. Only difference was I had a drip just chilling there along evidence that it had dripped on the frame below when I discovered it.
  11. Nov 22, 2021 at 7:03 PM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    What eventually happened with your trans leak @manuel91744 ?
