2021 tundra a/c clunk noise on start up
Discussion in '2.5 Gen Tundras (2014-2021)' started by Al1970, May 17, 2022.
  1. May 17, 2022 at 4:24 PM
    Al1970
    Al1970 [OP] New Member
    2021 tundra sr5
    Was just curious if anyone else is experiencing a loud bang noise on start up
    Sounds like a cats under the hood and is jumping into the hood on start up
    I know it sounds silly but that’s the best way to explain it
  2. May 17, 2022 at 4:28 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    It's common. Seems to happen when cars cold and been sitting for few days. Other makes do it too. Lots of theories but no consensus. Seems to not be an issue though.
    If you turn on ac before you crank it won't happen.
  3. May 17, 2022 at 4:35 PM
    Al1970
    2021 tundra sr5
    I live in Florida and it seems worse when it was cold outside
    I have had a 2008 and 2018 tundra neither of those had that noise
    It just doesn’t sound very good and normal
    And concerns me from a brand new truck
  4. May 17, 2022 at 5:56 PM
    MadMaxCanon
    Is it a split second sound like a grind?
  5. May 17, 2022 at 6:31 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Mine does that too sometimes, especially if I haven't used it in a while.
  6. May 18, 2022 at 3:30 PM
    Al1970
    2021 tundra sr5
    It’s a loud bang noise
    Like something is hitting the hood real hard
  7. May 18, 2022 at 3:44 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    I don't have that in mine.
  8. May 18, 2022 at 4:26 PM
    Tundra21NS
    Tundra21NS New Member
    2021 Black Tundra limited Nightshade Edition
    I'm from WI and it's gets pretty cold here. Drive my truck maybe only twice a week. I never heard anything like that before.
  9. May 18, 2022 at 4:33 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I don’t drive my truck often but I consistently have gotten that “thud” when turning on the AC since I purchased it in May of 2020. It’s especially loud the longer the truck sits unused…
  10. May 18, 2022 at 4:36 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    This. If I remember to turn the A/C off before turning the truck off I won't get it next time I jump in. It concerned me when I first got the truck, but I know now that it's just a thing we do!
    @Al1970 give that a whirl once, and see if that yields any fruit.
    Oey12[QUOTED] likes this.
  11. May 18, 2022 at 4:43 PM
    MadMaxCanon
    I always turn ac off before turning off truck and I still get it if it sits a few days
  12. May 18, 2022 at 4:44 PM
    memario1214
    Colton
    Missoula, MT
    You might ACTUALLY have some cats jumping around under the hood
  13. May 18, 2022 at 5:01 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    You bring up an IMPORTANT point that I didn’t add…it only happens when I forget to turn the AC off when shutting down. Which for me is about 25% of the time.
    EDIT: I should not have used the word only. It significantly quieter is more accurate (turning on AC after truck started).
  14. May 18, 2022 at 5:46 PM
    ThatOneMarine0341
    ThatOneMarine0341 New Member
    South Carolina
    2021 Tundra TRD Crewmax
    Mine does it too when I start it up after leaving it alone for a night or two. Seems to be when I turn on A/C. No issues with it, just that initial ‘umph’.
    Oey12 likes this.
  15. May 18, 2022 at 7:33 PM
    MadMaxCanon
    I'll take it. No rodents at least.
  16. Mar 1, 2024 at 4:42 AM
    MountainHopper
    MountainHopper New Member
    2020 Tundra SR5
    The noise is caused by compressor oil collecting in the compressor and upon initial compressor
    engagement, the compressor must pump the oil out causing the “Bang” noise. Compressor
    engagements thereafter are normal and less audible as the collected oil has been pumped out.
    RECOMMENDATIONS
    This is a normal characteristic and no repairs are recommended.
    KNABORES likes this.
