2021 trd pro squealing noise
Discussion in '2.5 Gen Tundras (2014-2021)' started by Glennjc1978, Aug 22, 2021.
  1. Aug 22, 2021 at 6:49 PM
    Glennjc1978
    Glennjc1978 [OP] New Member
    Glenn
    2021 trd pro lunar rock
    Need a little help,I have a 2021 trd pro with 600 miles on it.I was driving home tonight and noticed a loud squealing noise coming from the rear area of the truck.The sound increases the faster i go and decrease as i slow down. If i come to a complete stop and start going again the sound goes away. I can drive 5 or 10 miles with no noise before it starts again.Everytime just before the sound starts again i hear a click and the noise starts again. Thanks for any help.
    Metro14536 likes this.
  2. Aug 22, 2021 at 7:00 PM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I'd take it back to the dealer asap. That's what the warranty is for.
  3. Aug 22, 2021 at 7:04 PM
    Glennjc1978
    Glenn
    I am going to call in the morning just wanted to make sure it wasnt something little and could let them know before it sits in the shop all week.
  4. Aug 22, 2021 at 7:12 PM
    IgotSR5onit
    IgotSR5onit New Member
    Definitely let the dealer do their job. Could check out the calipers. Ive gotten sticks and rocks caught in the caliper and you'd be surprised at how much noise something like that could make.
  5. Aug 22, 2021 at 7:42 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Check driveline and for debris caught under it.
  6. Sep 2, 2021 at 7:21 PM
    Glennjc1978
    Glenn
    The dealership is saying this dust cover flange is making the noise and ordering a new one.Just wondering if any guys that deal with rear diffs have replaced this.
  7. Sep 2, 2021 at 7:29 PM
    Glennjc1978
    Glenn
  8. Sep 2, 2021 at 7:30 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    The dust shields are on your rear brake rotors...it happens...not usually warranting a new one but rocks get in-between therefore and dust shield if you use it as a truck...
    **Edit: haha oh, wow, the photo didn't load when I read that...you're right, not the rear caliper dust shields...I'm It sure on the dif...QA/QC has gone downhill with everything these days...be glad you have warranty!!
  9. Sep 2, 2021 at 7:30 PM
    Glennjc1978
    Glenn
    This is the rear diff
    HulkSmurf14 likes this.
  10. Sep 2, 2021 at 7:33 PM
    IgotSR5onit
    Just curious, Why is the dealership not fixing it?
  11. Sep 2, 2021 at 7:35 PM
    HulkSmurf14
    2014 Tundra Limited
    They're ordering the part and repairing it...
  12. Sep 2, 2021 at 7:36 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Is it dented and making contact at some point? I would spray some PB Blaster in the groove where the rust is, and see if the noise goes away before letting the Dealership actually mess with it.
  13. Sep 2, 2021 at 7:37 PM
    Glennjc1978
    Glenn
    They are ordering the part,was just curious of what could be wrong with it. Plus just wanted some insight on could something be wrong with the ring and pinion.
  14. Sep 2, 2021 at 7:38 PM
    Glennjc1978
    Glenn
    Thats exactly what they did to make the noise go away.
  15. Sep 2, 2021 at 7:41 PM
    IgotSR5onit
    Seems to me itd be hard for someone to diagnose without being able to hear it. I guess if I was concerned about the diff Id just check and make sure it had gear oil. If it was me Id drive it and let the warranty do its thing. Still plenty of time on the clock.
  16. Sep 2, 2021 at 8:18 PM
    TILLY
    Massachusetts
    So they said the seal shield was actually causing the noise? Did they say why they thought this, and how replacing it would eliminate the squeal?
  17. Sep 2, 2021 at 8:21 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    This would make me very nervous as to why my brand spankin new of all tundras the lunar pro was squealing with 600 miles
  18. Sep 2, 2021 at 8:21 PM
    Glennjc1978
    Glenn
    They put it on the lift with a guy in the driver's seat.They had him speed up and slow down to duplicate the noise .Then they said exactly what you said. That it must be dented,so they sprayed lube on it and the noise went away.
    TILLY likes this.
  19. Sep 2, 2021 at 8:24 PM
    Glennjc1978
    Glenn
    It has me very nervous, plus they had to replace the rear driverside shock because it was leaking.My 2016 tundra never had one problem.
  20. Sep 2, 2021 at 8:47 PM
    TILLY
    Massachusetts
    As a former Tech myself, I understand the feelings you have, especially with a brand new truck. Give them a chance to make it right. Good luck, and let us know how you make out.
  21. Sep 3, 2021 at 4:14 AM
    Glennjc1978
    Glenn
    Thank you,just wondering is that all one piece from the housing to the drive shaft?Does the nut that holds that on have anything to with setting the ring and pinion?
  22. Sep 4, 2021 at 9:15 PM
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    A similar noise just appeared tonight on my brand new 2021 Platinum with only 250 miles on it. Not a great feeling...
  23. Sep 4, 2021 at 9:22 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Does this sound similar to the noise you had? It stopped when I came to a complete stop but would start again after gaining some speed.
    https://youtu.be/1TWiilbixPg
  24. Sep 4, 2021 at 9:25 PM
    TILLY
    Massachusetts
    Wow, that's very annoying, have you had it diagnosed, fixed?
  25. Sep 4, 2021 at 9:27 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    No I just made a quick trip to the store a hour ago and it started on the way to the store. Had the family out to the park earlier today and it was fine.
  26. Sep 4, 2021 at 10:46 PM
    Glennjc1978
    Glenn
    Yes that is the exact same noise.
  27. Sep 29, 2021 at 11:44 PM
    Joshiro
    Joshiro New Member
    Jeanette
    2021 Tundra Double Cab
    OMG, our truck did that too! Just got a 2021 SR5 and had to send it back to dealership to repair. It was that stupid dust cap.
  28. Sep 29, 2021 at 11:45 PM
    Joshiro
    Joshiro New Member
    Jeanette
    Dust cap by rear diff. We had to ship our truck back to dealership to repair. So annoying! Brand new!
  29. Sep 30, 2021 at 12:04 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Well I smell a potential supplier issue and TSB coming out for this one.
    The diffs are produced by hino. Usually solid products. But with employment issues and supply issues all these companies are feeling it.
    Y0TA PR0 likes this.
  30. Sep 30, 2021 at 4:55 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    I call it covid-quality.
    Rocko9999 likes this.
