2021 Smokey 3.0 Build
Discussion in '2.5 Gen Builds (2014-2021)' started by smokey_skippy, Nov 12, 2020.
  1. Nov 12, 2020 at 6:30 AM
    smokey_skippy
    smokey_skippy [OP] Currently Getting Stuck Somewhere
    Alexander
    2021 Toyota Tundra Platinum
    3.0 camburg/fox lift with coil overs/35x12.5r18 Toyo RT/18inch XD series rims/ and a lot of custom stuff
    25C9E053-5861-45E1-83AA-3727B81BE127.jpg A59B952A-DD08-48EB-9129-76DD1C617428.jpg Hey everybody, I am going to try and list all the build so far and keep updated with new stuff as it comes. I still have a ton of parts on the way, but they are back ordered.
    Ended up using my same wheels as before which are the XD 128 on a 18x9 25mm offset
    They are paired with a 3” mid travel lift.
    The front currently only has the shocks and UCA because everything is still on order.
    But it should have camburg uca, camburg spindles, fox shocks w/resi, deaver u487 springs, fox rear shocks w/resi, fox bump stops w/camburg mounts, and hellwig offset airbags for towing(pictures to come)
  2. Nov 12, 2020 at 6:43 AM
    smokey_skippy
    Alexander
    First thing I did, was the fun task of cutting into the floor to add this ESP box. It’s a pain and it hurts to take a knife to a truck with less than 500 miles on it, but it’s worth it.29034706-2E24-48DE-AA50-8EE2C16A5324.jpg
    The next thing I did was the wheel speed sensors were a slight concern when off roading, I had shredded one once before hitting a rock and I wanted to protect it this time. So I added some shield by Jomax
    3616E289-5434-4C7A-B0DD-062FEC649294.jpg 5F39B476-CE7A-4241-92F6-583579A991AC.jpg
    the next few things I did was I mocked up my dometic and some wavian Jerry cans in the back under my retrax. I’m still waiting on the slides for the dometic but I made some custom drop brackets for the gas cans out of some flatbar from Home Depot.DD3F8FEA-B042-44F8-946A-205B6C1FE995.jpg A008C7BF-E8AE-4573-858D-4658E04446C1.jpg 29F353CC-75AA-4183-975F-E8BBD2A46588.jpg
    NIOSH, Dingo716, ejl04 and 3 others like this.
  3. Nov 28, 2020 at 9:18 AM
    smokey_skippy
    Alexander
    Just a quick little update on the truck!
    Done a ton of stuff but will have a big update late next week.
    changed the grill for the pro, mainly to shift the sonar down for the C4 bumper
    also have prepped the rear tailgate area for the dometic, and tons of other stuff.
    This will be the power point. What you also don’t see is the tembo tusk slide for the dometic
    then I have a wiring disaster in the cab with a little sneak peak of what’s coming with a switch pros mounted in that awful document holder location
    83BF4980-C9D0-427F-B442-E4719E0B0F71.jpg 980D5D10-7863-4C18-8CA8-49F0813110E5.jpg
    I have a question for anyone that knows, who is running a 11lb propane mount and what is a good mount to get? I’d like to mount it on the inner truss of a bed rack.
    Thanks and stay put for more to
    Come!
  4. Jan 21, 2021 at 7:28 PM
    smokey_skippy
    Alexander
    Alright it’s been a hot minute since I’ve updated this, but here we go
    it started with the front and rear bumpers2BC1BB1C-9429-4F5B-ADBD-44BEED425B7A.jpg 0D952D2A-067E-4B94-A77B-5FB058BFF735.jpgAF40C121-5D8A-473F-AA61-1C9EEF53EF60.jpg
    drobb and Terndrerrr like this.
  5. Jan 21, 2021 at 7:29 PM
    smokey_skippy
    Alexander
    And here is the rear bumper
    drobb likes this.
  6. Jan 21, 2021 at 7:31 PM
    smokey_skippy
    Alexander
    Also managed to get the roof rack on with a light bar, going to put the side lights in this weekend
    2AF702A4-52A6-46A5-9E47-ADBBD369F992.jpg 5634DF38-2864-4488-A909-B95B6FAA37B6.jpg 50D9FB55-B57B-4E82-BCD5-C461E10E3EBC.jpg
    drobb and NIOSH like this.
  7. Jan 21, 2021 at 7:32 PM
    smokey_skippy
    Alexander
    And also put a fun toy on the truck
    Breaking just at 500HP
    This Harrop SC is a blast
    FC08054F-641E-4F08-996C-26D662A0D393.jpg ED492D0B-7296-4100-9F9C-620139CD4E6F.jpg 209E0BA4-4E03-4A64-9923-EC19CE52E1F8.jpg 741E13D7-6EC7-4CDB-88F1-2A1C17077752.jpg
  8. Jan 25, 2021 at 10:20 AM
    Predator Tundra
    Predator Tundra New Member
    Fallon, NV
    2020 Platinum
    Nice truck. I like the switch pro location. Think that may be the route I go.
  9. Jan 25, 2021 at 10:34 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Okay, okay I'm listening! Nicely done so far! :cheers:
    How did you manage tuning for that Harrop for your '21? Rumor had it that no one had it quite figured out yet?
