2021 Roof rust spots
Discussion in '2.5 Gen Tundras (2014-2021)' started by cuaround, Oct 21, 2022.
  1. Oct 21, 2022 at 9:20 PM
    cuaround
    cuaround [OP] New Member
    I have 2021 tundra which I purchased new and found a couple rust spots on the roof. The dealership where I purchased the truck is trying to tell me the rust is a result of rock chips and mag chloride got in and is causing the rust. When I look really close it appears to me that it has bubbled under the paint and broke through to the surface, perhaps there was moisture or something on the surface prior to paint. I just have a hard time believing that a 1 year old truck would have rust issues like this, I’m not even located in the rust belt. I’m in Colorado and no salt is used. Any help would be appreciated on how to move forward with Toyota.
  2. Oct 21, 2022 at 9:56 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I'm not an expert at all but that is typically what is it looks like when rust starts. It bubbles out the paint from underneath. You sure they don't use salt in Colorado? You guys get a lot more snow than us on the east coast and they salt like crazy over here. Being that its on the roof and out of site might be a good thing for a cheap DIY fix with a little sanding, touch up paint, compound and polish. It wont look great but you wont see it and it wont get worse.
  3. Oct 21, 2022 at 10:31 PM
    MisterE
    MisterE Overcompensating
    2021 Tundra CrewMax TRD OffRoad MGM
    ESP Storage, TRD Pro Grill
    CDOT says it's still a good idea to wash off the mag chloride because it's still "less corrosive". I don't miss living in Aurora at all.
  4. Oct 21, 2022 at 10:32 PM
    cuaround
    I’m pretty sure it’s just mag chloride out here but I may be wrong. Even the under carriage is rust free, no signs of rust anywhere else. My concern is it’s a 2021 that saw one mild winter,I planned on keeping this truck for at least 10 years as I did with my previous truck's but what will it look like in 5 years. You don’t see much rust out here and that’s why I’m a bit nervous and hoping Toyota would take care of it. I understand that the spots are on the roof but I have never had issues like this in the past. I also have a 94 land cruiser that doesn’t have a sign of rust anywhere, guess we’ll see what Toyota says but I will have a hard time if they do not fix the issue.
  5. Oct 22, 2022 at 7:30 AM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    That's covered under warranty. I would get that fixed right away.
  6. Oct 22, 2022 at 7:38 AM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    yes Colorado only uses Mag Chloride, but that stuff is nasty also, look at the dead trees along all the mountain roads, it is from that stuff. It will also eat up the concrete in your driveway and garage. You know all that weird white filmy dust you clean out of your garage every spring? Mag Chloride.
    So while none of that has anything to do with rust on a 1 year old truck, it’s a good thing to run your vehicle through a car wash in between storms all winter long.
    Aurora sucks
    Take that truck back under warranty
    IsaiahCanada likes this.
  7. Oct 22, 2022 at 8:05 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    No way that's from a single rock chip and salt, esp on a 21.
  8. Oct 22, 2022 at 11:09 PM
    cuaround
    Appreciate all the reply’s. I’ve been waiting for a couple weeks for an answer from the dealership, last week I was told Toyota stated the pics are inconclusive and wanted additional pics which I sent over to them and I’m still waiting for an answer. Just not sure on how to move forward as this truck should not be rusting like this and a bit worried it may not be covered by the warranty.
  9. Oct 22, 2022 at 11:29 PM
    aguninc
    aguninc New Member
    WNY
    22 Tundra Platinum MGM, 21 Rav4 Prime
    take it to another dealership
    2mchfun, GODZILLA and IsaiahCanada like this.
  10. Oct 23, 2022 at 1:20 AM
    Blue By U
    Blue By U New Member
    I don't know how ya'll put up with this.
  11. Oct 23, 2022 at 3:35 PM
    Shamrock92
    Shamrock92 New Member
    Rock chips ? - on the ROOF ?? Without context of where it’s chipped - hard to say - but overall difficult to believe it’s stone chips from road debris on the roof (it’s a big truck - the hood and the windshield would be absolutely peppered before you’d expect to see any on the roof - and then only the leading edge above the windshield).
    THEN saying it’s a result of snow melt - again - how in the hell is that stuff getting kicked up that high ?!? Are you following a gravel truck 8 months of the year that’s untapped and then a snow plow the other 4 months of the year ? I’m calling BS on that excuse.
    It’s a combination of thin paint and thin metal. Obviously a roof is a thinner metal than most any part of the truck - as it doesn’t NEED to be heavier steel. Still - shouldn’t be doing this within 2 years (worst case let’s say your 21 was made in late 20). That needs to be stripped down/properly refinished and then a good coat of wax or ceramic coat applied.
    Hell I’d ceramic the entire truck seeing that happening so quickly - not just the usual spots. I’ve seen trucks driven in strip pits daily not show that level of damage so quickly.
  12. Jan 25, 2023 at 2:34 PM
    TownTRD
    TownTRD New Member
    Cris
    Bay Area, CA
    2020 Army Green TRD PRO CM
    Any updates from Toyota? I noticed a rust spot on the driver’s side bed panel of my 2020 Pro. Hard to make out on the picture but there’s definitely some orange developing on there.
  13. Jan 25, 2023 at 3:13 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    I found a chip on my 2020 roof last week when washing it, but it looks like an actual chip. OP's pic appears to have bubbling under the paint around it, which thankfully mine doesn't have. We used to live where they salted and/or used the liquid solution, and we never saw rust issues develop that fast (under paint penetration). Granted, we frequently ran them through carwashes with undercarriage wash in the winter - OP likely keeps his clean too I would guess.
    I think the OP's truck has to have something else going on - I would assume from an issue during prep/paint at the factory (but I'm no paint specialist by any means). Hope Toyota treats him right on this one.
  14. Jan 25, 2023 at 3:17 PM
    TownTRD
    TownTRD New Member
    Cris
    Bay Area, CA
    Thanks! Mine is definitely not bubbling as with OP’s truck, we’ll not yet at least, but definitely some rust there . I just don’t want it to get any worse and definitely don’t want to get the runaround with the Dealership.
  15. Jan 25, 2023 at 3:24 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Those chips and subsequent rust spots shouldn’t be happening until the clear coat wears down after many years, not a couple. I have a bug guard that keeps most of them off my hood but I can’t protect the roof.
  16. Jan 25, 2023 at 3:48 PM
    Jernik
    Jernik New Member
    Jeremy
    I cleaned the rust that was forming out best I could with the touch up paint pen/kit, then blobbed the paint on to seal it. It's not the prettiest, but being on the roof I was more concerned with stopping the damage. In a more visible location, you might ask you dealership who they have touch up rock chips on their used cars. I've used those guys in the past and (the skilled ones) do real good work. They typically prep the spot and air-brush it to match/blend. Used to be fairly cheap. Just another option to consider.
