2021 pro tires
Discussion in 'New Member Introductions' started by Hitz2021pro, Nov 12, 2020.
  1. Nov 12, 2020 at 7:22 AM
    Hitz2021pro
    Hitz2021pro [OP] New Member
    2021 Tundra Pro Crewmax
    Hello, I ordered a 2021 tundra pro crewmax that will be here in mid- December. The first and probably only thing that I want to do immediately is upgrade tires, keeping pro wheels, without any modifications to the truck, (besides removing front mud flap). Will I be safe with 285 75 18, or 295 70 18? Goodyear Duratrac? I’ll be on road over 90% of time, but would still like a semi aggressive look to them. Thanks so much!! Brian
    YardBird likes this.
  2. Nov 12, 2020 at 7:33 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
    Have a read through this thread - it’ll answer your questions on the Pro with bigger tires.
    https://www.tundras.com/threads/let’s-see-pics-stock-height-pro-with-295-70r18.31428/
    As for Duratracs, probably a bit of personal preference. I had a set on my 2008 that were awesome (almost 80k out of that set). Then the set I got after that were terrible for not being able to keep balanced, noisy, and wore terribly (most likely because of the balancing issue). I did find that neither set was worth a damn on wet pavement after about the first 10k miles - if I tried to get on it from a stop, they would just loose traction and spin.
    Hitz2021pro[OP] likes this.
  3. Nov 12, 2020 at 7:36 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  4. Nov 12, 2020 at 8:55 AM
  5. Nov 12, 2020 at 3:53 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  6. Nov 12, 2020 at 3:59 PM
    Welcome from NY.
  7. Nov 12, 2020 at 4:11 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! The answer to your question is yes. I prefer the 295/70....
  8. Nov 12, 2020 at 4:33 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Welcome from VA... search is your friend on Tundras.com. TONS of tire threads.
