2021 Limited suspension
Discussion in 'Suspension' started by Blk Fisher, Jun 3, 2021.
  1. Jun 3, 2021 at 4:52 PM
    Blk Fisher
    Blk Fisher [OP] New Member
    Turnersville, NJ
    Had the truck since March. Been doing a lot of research on coilovers and such. Here’s my plan. My only concern is the UCA’s and clearance of the tires. I want to fit 35’s x 12.5 R20. What would be a good offset to clear the UCA’s. If I’m missing anything or you want to add any input, that would be great.
    Front: Fox 2.5 with RR & DSC
    UCA: Icon or Camburg
    Rear: 2.5 with RR & DSC
    Differential drop
    Carrier bearing drop
    Coach builder 3” shackles
    BMC if needed
  2. Jun 3, 2021 at 9:51 PM
    cain0725
    cain0725 New Member
    u will probably need a little more lift , like a shim or something, factory wheels are usually plus 60 , so most people on here go with like a plus 25 or 35. Brand of tire also makes a difference. Front bumper shims help also.
  3. Jun 4, 2021 at 2:44 AM
    Blk Fisher
    Turnersville, NJ
    Thanks. I was going to do a bumper shim as well. The only real concern I had was with the UCA’s. I prefer not to us a shim on the wheel.
  4. Jun 4, 2021 at 3:32 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Good planning, plus the offset on your wheel choice will be a factor... Most 2.5-3.5" Coilovers lifts is a easy front flap removal and some heat on the front wheel well plastic, as in my case with a Toytec 3.5" aluma serie lift, with all the support listing you gave. I went with JBA's UCA, Vision wheels +25, Wildpeaks295/70/18s and sits perfectly...
    Good luck and post pixs when completed!!
  5. Jun 4, 2021 at 4:32 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    That tire will not clear the uca on factory wheels. You’ll need spacers or new, lower offset wheels.
  6. Jun 4, 2021 at 5:35 AM
    Blk Fisher
    Turnersville, NJ
    Thanks. I will post pics for sure. It might be awhile. I’m ordering everything and once it all comes in, will have it installed.
  7. Jun 4, 2021 at 5:36 AM
    Blk Fisher
    Turnersville, NJ
    I will be adding new Fuels in 20” size just not sure which ones yet.
  8. Jun 4, 2021 at 10:19 AM
    cain0725
    cain0725 New Member
    drop wheel size will provide better ride and if going above 2.5 i would do UCA. I went 2.5 6112 shocks but then dropped down to 1.9 for better ride. Plus truck was too high. I used SPC UCA just to be safe. They do stick out further than stock UCA.
    Blk Fisher[OP] likes this.
