2021 front door speakers - simple upgrade needed
Discussion in 'Audio & Video' started by SSPey, Jun 8, 2021.
  1. Jun 8, 2021 at 10:00 AM
    SSPey
    SSPey [OP] .
    Oregon
    2021 DinoSR5
    Can someone please provide currently available speakers / spacers / mod info to replace just the front door speakers on a 2021 SR5?
    I have to remove the door panel for something else, and want to keep this simple. I realize there’s tons of threads on speaker upgrades, but unfortunately too much information for my pea brain, especially when seller fitment advice can be wrong. I just want decent speakers that are easy to install. I used to play the drums, so have inherently low IQ. I mostly listen to ROCK music. Thank you
    :rimshot:
  2. Jun 8, 2021 at 10:34 AM
    For direct plug into the factory connector, there is a brand called Focal. A couple of guys on here have them. There are other options like Kenwood or Pioneer where you would need an adapter plug or run speaker wire to an aftermarket amp. The easiest in your case would be the Focals if you just want a simple upgrade.
    SSPey[QUOTED][OP] likes this.
  3. Jun 8, 2021 at 10:36 AM
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    Every post about upgrading the speakers mostly end up with an upgraded head unit. Check the following posts:
    If you are still convinced that you want to upgrade your speakers check these posts
    Another good resource is your local stereo shop, go in and talk to them. They may have other recommendations for your truck audio upgrade.
    Vang530 and SSPey[OP] like this.
  4. Jun 8, 2021 at 10:48 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I upgraded to Infinity Kappas with xovers before adding amp and sub. I got mine from Crutchfield. They came with everything needed including wire adapters. I just cut holes in my sail panels. NP with a hole saw.. Not a whole lot of improvement until I added the amp. You can do speakers now and amp later.
    SSPey[OP] likes this.
  5. Jun 8, 2021 at 10:53 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    There are factors to consider when replacing just the front door speakers of your non-JBL Entune SR5.
    The main one;
    The front door speakers only have mids and lows from the underseat stock amp.
    The high end comes from the dash speakers that run off the HU.
    So just replacing the front door speakers may sound better, but you are not going to have a full range sound.
    Crutchfield sells those plug and play Focals, when they have them in stock..
    They came in a single 6X9 coaxial and this component set.
    I can't find the coaxial, which is what you'd need since you probably don't have a tweeter in your SR5 door sail.
    Focal Inside IS TOY 690 6"x9" component speaker system designed for select Toyota, Lexus, and Subaru vehicles at Crutchfield
    Good luck..
    Saltyhero13 and SSPey[OP] like this.
  6. Jun 8, 2021 at 10:54 AM
    AT x AT
    Jimmy
    Mods, what mods?
  7. Jun 8, 2021 at 10:57 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    RdKing and SSPey[OP] like this.
